Ac adapter 0957-2231 - Computers & Internet
  • 400 Answers
Are you looking for an Ac adapter for your computer?
Then it is this one from HP:
http://www.amazon.com/HP-0957-2231-AC-Power-Adapter/dp/B000X4421Q
Posted on Feb 16, 2012
  • 1 more comment
  • Marcio RL Paiva Aug 13, 2013
    My HP Photosmart C4280 printer turns off by itself frequently. Then, if I briefly disconnect and reconnect the AC adapter from the mains, it turns back on. I'm tryimg to determine if the problem is on the printer or the AC adapter.
  • Fabio Aug 13, 2013
    Hi ,you can only determine this with another working adapter.
    Also try another power outlet ,you could take it to a computer shop and ask to test or measure the adapters current or you can do this yourself with a multimetre.
My laptop is not powering on help
1.Connect the Ac adapter to a known good power outlet. Check the Power LED indicator on AC adapter (without plugging into the Notebook). We are only checking the power AC adapter to see if that is working.
2.If LED on the AC adapter is not lit (when unplugged from notebook), reseat the AC adapter brick and cable. If still there is no light on AC Adapter replace AC adapter and Power cord.
3.If LED on the AC Adapter goes off only after connecting to Notebook, the issue is with the motherboard. Replace Motherboard, DC-In port (AC adapter connector).
4.If the AC Adapter LED is always ON, take a technician's help and reseat the Power Button Board. You can refer to the Service Manual for details on how to reseat the Power Button Board. (NOTE: Before the notebook chassis is opened ensure all the power connections including battery and external devices are disconnected)
Jun 07, 2014 | Dell Inspiron Laptop 1440
Laptop is turning on and off
Remove the AC adapter (Charger)
PROPER method is to disconnect the power cord of the AC adapter, from power; THEN unplug the AC adapter from the laptop.
Same thing in reverse to plug the AC adapter back in.
AC adapter is plugged into laptop, THEN AC adapter is plugged into power.
Unplugging the AC adapter from the laptop, while being plugged into power; can cause a Voltage Spike.
You may get away with it for years, and several laptops; and have no problems.
However it only takes ONCE, to fry out the SMD fuses, Multi-Layer Ceramic Capacitors, and Power MOSFET's, on the laptop motherboard's DC to DC circuit.
Jus sayin'.
Moving on........
AC adapter removed, remove the Battery.
Press the Power On button in, and hold in for a count of 10 seconds.
Let go.
Do this procedure 2 more times.
(Draining residual power)
Reinstall the Battery. Attach the AC adapter, plug AC adapter into power. Let the Battery charge 24 hours.
Then turn the laptop on, and tell me what happened.
Regards,
joecoolvette
Mar 15, 2013 | HP Pavilion Computers & Internet
I can't get my dell inspiron to power on. I will charge the battery using the wall charger but will not come on. What can I try?
Try this if will help.
Remove battery and unplug the ac adapter from laptop.
Without the power sources hold down the power button for 10 seconds.
Check the ac adapter from wall power socket if ac adapter LED is ON.
Plug back in the ac adapter to laptop then check the LED from the ac adapter if it stayed on.
If ac adapter LED turned off right after you plug in the ac adapter to laptop then you need to replace the ac adapter, motherboard and power daughter board.
Hold down the D key then Press Power Button once. Check if color display will appear in the screen.
if the ac adapter stays on you and still no power indicator from the laptop you need to replace motherboard and power daughter board.
Hope this helps.
Jun 02, 2011 | Dell Inspiron 6000 Notebook
Wii console light won't come on
One of two common possible problems. Either 1) Your AC adapter needs to be reset or 2) Your AC Adapter is bad.
Most power issues with the Wii can be fixed by resetting the AC adapter. You can easily reset the AC adapter by following these steps:
Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip).
The AC adapter must remain unplugged at both ends for a full 2 minutes.
After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked.
If it's not working, you can get a *new* NINTENDO brand AC adapter at the following page. Beware of cheaper knockoffs around the internet.
http://store.richspsxparts.com/ofniwiiacadr.html
May 24, 2010 | Nintendo Wii Console
Cannot get my computer to turn on
remove all external peripherals. remove laptop battery. remove ac adapter.
plug ac adapter to wall power socket without the laptop connected check if the ac adapter led will stays on. if yes then connect it to the laptop and check if the ac adapter led turns off. if yes motherboard laptop has problems and need to be replaced.
if ac adapter led stays off without connecting laptop, try different wall power socket, if still ac adapter led is off then replace the ac adapter.
if ac adapter has light stays on then connected to laptop but laptop cannot even power up even the ac adapter led is on then laptop motherboard needs to be replace.
Dec 09, 2009 | Dell Studio 15 Laptop
Battery has gone dead. When I plug the A/C cord in the light on the charger immediately goes out and won't charge battery.
try connecting ac adapter alone without the laptop, check if ac adapter light will stay green or blue.
try another power outlet using the ac adapter alone without the laptop check if the ac adapter light will stay as green or blue. if all fails replace ac adapter.
if ac adapter stays green or blue try connecting to the laptop without the batt, check if the ac adapter light will stay on, if yes then try connecting ac adapter to laptop with the batt plugin check if the light stays green. if not update the BIOS. if fails replace motherboard.
Oct 12, 2009 | Dell Latitude D610 Notebook
Toshiba Portege 7100 AC Adapter
all are not same but you buy through ebay you cant replace it go the shop and verfy onces
Jun 11, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
AC adapter supplied by a third party
No, Minolta cannot guarantee the compatibility of any third party AC Adapters. We recommend the use of Minolta AC Adapters, AC-1L, and AC-2L. Any damage caused to the camera as a result of use of a third party AC Adapter may void your warranty.
Sep 19, 2005 | Konica Minolta DiMAGE E201 Digital Camera
DiMAGE E201 overseas?
Yes. When using an AC adapter, please use the one suitable for the voltage level of your destination country. North America, Taiwan: AC adapter AC-1L; Europe (except UK) and Singapore: AC adapter AC-2L; UK and Hong Kong: AC adapter AC-2L; Japan: AC adapter AC-1L. You may have to switch video output mode between PAL and NTSC to view images on the television.
Open Questions:
Cloud Backup For Small Business 'Dataalign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Cloud Backup For Small Business technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Online Backup Pricing is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Server Cloud Backup Solution up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
Jun 19, 2018 | Quantum Computers & Internet
Computers & Internet Logo
136 people viewed this question
David Payne
David Payne
