Question about Fisher Price Rainforest Bouncer
How do i fix the frog that gets stuck?
The frog that goes up and down gets stuck and clicks real loud over and over again as it tries to go back down. when lightly touched it goes but happens again before it goes down again. How do I fix it? im about to break it off!
  • Megan Zorich
    Megan Zorich Mar 21, 2016
    I don't suppose you figured this out?
Electrolux dryer getting 'stuck' at times
the belt is frayed and catching at times. mine was split in half. right down the middle.gets caught on tention pulley as it goes around,,,sometimes
May 10, 2014 | Dryers
HP 2410 Photosmart All in One Printer
the clicking sound is coming most likely from the printhead carriage, if you open the printer so you can see the cartridges, is the carriage stuck? trying to move to a direction and makeing the sound?
Sep 30, 2008 | HP PSC 2210 All-In-One InkJet Printer
Wrong gas in a 2 cycle snow blower, made a loud sequel and stopped running. what now?
Hi Jim,if the piston is stuck you maybe able to save it.Remove the spark plug then spray a good amount of W-D4O inside.Next get a strong small round wooden dowel that will fit in the spark plug hole it should be about 10 inches long, then tap it with a hammer to drive the piston down so the W-D40 can lube the piston walls, now pull the string slowly- not to snap it.If the piston does not go up give it more W-D and try again, if it goes up and down the add a new spark plug and right gas mix. If the piston is stuck its not worth having it fixed you can get a used one cheep on Craigslist
Jan 05, 2014 | Garden
LeapPad stuck on Leap Frog screen.
I have the same problem. did you ever find an answer???
Feb 17, 2012 | LeapFrog Leappad Plus Writing
Model #17-1381. We just bought our bike at Canadian Tire. The chain is very loud. We tried to change gears but it clicks and then goes back to being loud again and also clicks periodically.
Model numbers are irrelevant as all bike makers use commonly available components manufactured by a small handful of companies.
This problem is why bikes should be purchased at real Bicycle Shops - setup is right and there is usually a follow-up after break-in.
You get to learn how to DIY because you HAVE to.
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
Key to all of this is OBSERVATION. Noises need to be localized. Something is rubbing somewhere.
Use a search engine for "how to shift a bicycle", "bicycle chain makes noise" and any other questions you might think of and you will find many videos.
Jun 29, 2011 | Schwinn Cycling
Bugaboo Frog Handle Won't Lock in Place
Hi
Visit www.buggypitstop.co.uk/ they can help
thanks
May 05, 2010 | Bugaboo Cameleon Jogger
Tv won't turn on. red power light is out
red light is on, but when the tv is turned on, it immediately shut down and goes back to the red light setting. It is like it blows a fuse or something to that effect.Post Solution
Mar 02, 2010 | LG 50PC3D 50 in. Plasma Television
My bugaboo frog frame will not fold down
CONTACT WWW.BUGGYPITSTOP.CO.UK THEY DO REPAIRS TO ALL BRANDS OF PUSHCHAIRS AND CAN GIVE YOU GOOD ADVISE
Jan 03, 2010 | Bugaboo Frog Stroller
Popping & hardly any volume
i had the first problem and you can probably fix it by turning the volume knob all the way up and down about 20 times. it worked for me. supposedly the potentiometers in the z-5300 get dirty or worn out, somehow this might fix it. for the second problem maybe try plugging it into the laptop and unplugging it again seeing if it goes back to normal?maybe its a problem with the amp?
May 07, 2008 | Logitech Z-5300 Computer Speakers
Fisher Price Rainforest Bouncer Logo
244 people viewed this question
Top Fisher Price Baby Gear Experts
romney2012
Lyle Siemens
Lyle Siemens
Josh Whitehead
Josh Whitehead
Are you a Fisher Price Baby Gear Expert? Answer questions, earn points and help others
