Question about Swisher Ride King Zero Turn Mower 23 Hp, 52" Cutting Deck
Rewiring an old Roper ride on mower
I need help to rewire an old Roper ride on mower. It has a B&S 8hp engine circa 1979 and a 5 pin switch. Step by step instructions would be really cool. I'm rebuilding the lawn tractor as a 'tug' only. There is no mower deck and there are two safety switches related to the mower that I wish to by-pass.
John deere wiring
It maybe charging lead. Goes to key switch.
Mar 11, 2014 | Garden
How do I drain the oil on a Briggs and Stratton 8hp 191702 ride on mower ? I can't seem to locate the oil drain plug.
if you follow the dip stick tube down to the base of the engine there is a square head bolt that is the drain plug
Jun 27, 2012 | Garden
Motor runs fine but can't go foward or backwards on Murray 8hp rear engine riding lawnmower
check the drive belt it might have broke or fell off a pulley
Apr 27, 2012 | Garden
I need a wiring schematic for a Kubota HK28L Excavator Please.
The brand you have does not post information on internet. But if give them your e-mail address. They will send it to you. www.messicks.com
Feb 21, 2012 | Garden
No spark to the plug Kohler 8hp lawnmower engine
Check ingition switch, check battery voltage 12-12 1/2 volts,check in run position same voltage, check in start position same voltage
We've check switch first. If not problem we've check the points for proper voltage and opening and closing.
Jan 17, 2012 | John Deere Garden
I have a old Snapper riding mower with an 8hp Briggs and Stratton engine, The other day it wouldn't crank so I changed the switch and the solenoid, the battery was fully charged and it still won't...
make sure thers power going into the starter
if there is then see if the starter is siezed, try turning the fly gear, but not just up against the flywheel but try turning the starter backwards to see if it moves
Jul 29, 2011 | Garden
I have a 13hp briggs and stratton model # 28m707 that has one extra wire that i can not idenify. ineed some help rewiring it.
Go to www.searspartsdirect.com . Enter your model number, get the owners manual download and inside there will be a page with the wiring schematic for it .Good luck!
Aug 23, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
No Spark - Cub Cadet model 71 with a Kohler 8hp
check condition of the magneto,located under the flywheel
Oct 06, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Rocker clearences
the book says 4-6 I always set them at 5
Aug 29, 2008 | Garden
Swisher Ride King Zero Turn Mower 23 Hp, 52" Cutting Deck Logo
176 people viewed this question
Top Swisher Garden Experts
Jim Parker
Jim Parker
Tim Whalen
ray gallant
Are you a Swisher Garden Expert? Answer questions, earn points and help others
