Question about Whirlpool Washing Machines
Need wiring diagram for indisit tumble drier
Just need to know where wires go in conector where mains join tumble drier, its an indisit
Malcg
  • 32 Answers
SOURCE: wiring diagram
In the UK, to connect to the connection block of a fixed integrated oven in a Kitchen, you must be a Part P Registered electrician. Such an electrician will issue a Minor Works Certificate for this work on completion - otherwise they are not Registered!
Be aware that if the work is not done under Part P and a fire occurs, etc your insurance company are entitled to REFUSE to pay out for the damage including any consequential damage to neighbours property or for loss of life!!
The block has three terminals and the Live, Neutral and Earth are indicated by marks stamped on the metal back of the cooker (if a CE product).
L = Live and takes the Brown covered wire
N = Neutral and takes the Blue covered wire
52080c4.gifor E = Earth (CPC) and takes the green/yellow covered.
If the cable has an uncovered copper third wire or is coloured Red/Black it should be replaced from the connection accessory on the wall behind the cooker with a heat resistant 3-core Butyl cable of sufficient size to cope with the load of the oven.
If you let me know the rating of the oven (label on door) in amps or watts, I'll tell you what size of cable you need.
Posted on Apr 13, 2008
  • 625 Answers
go to autozone.com and you will find it there
Posted on Jun 01, 2008
SOURCE: Candy CIC60 01 Tumble drier
Hi you need a new heating unit which is behind the back casing. Price approx £42 plus labour
Posted on Oct 12, 2008
  • 62 Answers
SOURCE: i need the wiring diagram to wire up from heater
You should not be doing that one yourself, unless you are a LICENSED electrician.
There are VERY important safety issues here, or is the intent to electrocute yourself or others?
Posted on Apr 18, 2009
Defy Tumble Drier DTD 252 wiring diagram
Request the wiring diagram directly from Defy.
Dec 10, 2017 | Dryers
Wiring diagram for dtd313 tumble dryer
Here is a possible. I know this is where it is located on some of their driers. Disconnect dryer and in the back of dryer in top left hand corner is your diagram, looking from back of dryer, just remove the 6 screws from the top panel at the back of the dryer. Most appliances have them tucked away somewhere on the equipment itself
Apr 15, 2016 | Cell Phones
TUMBLE DRIER STOPPED HEATING
Gas dryer?
If so, probably bad gas solenoid valves. They can safely be replaced without fear of releasing gas. Two phillips screws, two pull off wire plugs. That's it. Cost about $30 bucks depending on where you buy them. They are a universal part and will fit 99.9% of machines.
www.repairclinic.com
Best of luck...
May 18, 2015 | Dryers
I need a wiring diagram for a hotpoint TVF770 tumble dryer. I've replaced the heater element and want to confirm where I plug in the wiring loom. Thank you for your help.
I am sure if you go on line and ask for
diagram or manual you will get it. Or go to
Hotpoint and it will be on site once you have
chosen the tumble drier you have.
Next time you do a job like that always make
a diagram of what you are doing.It pays every time.
LUCK
Sep 25, 2014 | Dryers
I need a wiring diagram for my altezza rs200
hi click the link i believe that is what your after scroll down the page is shows what wires are for what
hope this helps good luck
Wiring Diagram For Stereo Altezza Club
Jan 15, 2014 | Cars & Trucks
INDISIT TUMBLE DRYER MODEL 37374. HOW TO ACCESS THE DRIVE BELT TO REPLACE IT
You need to remove the lid and side panel on the side the motor is on, usually the right. If you have a vented drier then you need to wedge the drum apart from the front so there is a gap to allow the belt to get around it, then move it along to the motor and here you will need some elbow grease to stretch it over the motor spindle. If it a condensor drier then fit the belt on the drum the same way but to get it on the motor you need to remove the top housing on the rear fan attached to the motor and then remove the fan, should only be a clip holding it, and stretch the belt into place, sometimes located between tensioners. Any problems you may be able to see a video on www.espares.co.uk and look in the advice centre, the have a video of belt change, may not be you make but they are all similar. Hope tbis helps
Mar 01, 2011 | Indesit Dryers
Have just bought a new heater element for a CL432AV White Knight Duel Heat Tumble Drier it will not heat think I have wired it up wrong do not have a wiring diagram can you help.
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Feb 12, 2010 | Dryers
Jun 01, 2008 | Candy CDC266 Dryer
Chef cooktop wiring
make sure that the white wires are indeed line and not neutral and you probably have the right idea but without a wiring diagram or seeing the unit I cannot confirm this just make sure you aren't hooking up line voltage to the neutral on the unit. also your service has only three wires correct? this means you are piggy backing the neutral and chassis ground (green wire on appliance) not cool on a trailer or manufactured home be careful bud
Apr 19, 2008 | Cooktops
Need wiring diagram for emachines t2200 motherboard
If you are replacing the power supply and it has 4 pin 12v conector and your motherboard doesn't, just disregard the 4 pin plug. The 20 pin conector will supply sufficient power for the processor. Many of the older motherboards did not have a separate 12v supply for the processor.
Apr 18, 2008 | E-Machines eMachines Desktop PC
Washing Machines Logo
41 people viewed this question
Dan Webster
Dan Webster
Sal De
