Question about Panasonic Car Audio & Video
Cq-rx200u amplifier install - Panasonic Car Audio & Video
Hi, how do I select the line in function on the cq-c1401U car cd player? I cannot get any display that states the rca line in has been selected, and I cannot get any sound from my ipod to run through the...
Hi, unfortunately this head unit has no line in function. The RCA jacks are preamp output to connect an amplifier. To read complete specs and/or obtain a user manual, go to
http://www.crutchfield.com/p_133C1401/Panasonic-MXE-CQ-C1401U.html?tp=5684&tab=features_and_specs
Aug 26, 2011 | Panasonic CQ-C1401U CD Player
I need schematic diagram for panasonic CQ-DF802U, I have problems with the Amplifier
Added a link for the manual with wiring diagram and spec's on pages 61, 62, 63 may be of assistance you here. http://a248.e.akamai.net/pix.crutchfield.com/Manuals/133/133DF802.PDF
Hope it helps, good luck with it.
Mar 28, 2011 | Panasonic CQ-DF802U CD Player
I have a panasonic cq-c7301u and i was wondering what the brown with white wire is and the 2 blue ones.
the brown/white is probably phone mute. the blue is power antenna remote turn on and the blue/white is amplifier remote turn on.
Mar 22, 2011 | Panasonic CQ-C7301U CD Player
Hi I have a Panosonic CQ-C1405W cd/mp3 player. I can play radio and hear the sound, great! But when I play a CD theres no sound its playing you can skip the tracks watch it counting the seconds and no...
are you using an amplifier? if so, it sounds like you are using the blue wire (power antenna remote turn on) instead of the blue/white wire (amplifier remote turn on) to turn your amp on. the power antenna remote wire turns off when you leave tuner mode.
Mar 17, 2011 | Panasonic Car radio CD CQ-C1110GN CD...
Panasonic cq-c1011n car stereo
It has 1 pre out for amplifiers, if you use this with an amplifier with a built in filter then it will be fine.
Jan 03, 2010 | Panasonic CQ-C1011NW CD Player
Battery in vehicle died, how do I reset clock and
go to the link to download user manual, the info is in there, the file is PDF, it was slow to download, so be patient.
http://service.us.panasonic.com/OPERMANPDF/CQRX100U.PDF
Nov 12, 2009 | Panasonic CQ-RX200U Car CD/ MP3 Player
Volume won't turn upon my panasonic cq-vad7200u car stereo
this may be a pre amp only deck
and if it is ou have to buy amplifiers to make the speakers work
May 07, 2009 | Panasonic CQ-VAD7200U Car DVD Player
Panasonic CQ C1100U amp output?
Yes, the Panasonic CQ-C1100U can be connected to a 2-channel amp. It has a single set of preamp outputs. I'm attaching an image of the connection shown in the Panasonic user manual. The appropriate connection is the one without the dashed line. The dashed line showing a 2nd set of outputs only applies to the 1110, 1120, and 1200 models.
Hope this helps. If it does, please rate as "FixYa". Thanks!
Mar 30, 2009 | Panasonic CQ-C1100U CD Player
MY panasonic CQ-C9700u starts to skip sound threw the speakers when i put it over 25 on the volume but the bass box still goes until 40?
Hi Lando,
Your Sub box gets its signal from the PReamp output. This means your problem stems from the CQ-C9700U amplifier section. You may need service from Panasonic on this one, or a new Head unit. I cannot think of any adjustment that you can do to eliminate a skip sound.
Dec 02, 2007 | Panasonic CQ-C9700U CD Player
Car Audio & Video Logo
20 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
