Question about Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator
Water will not dispense. Water works for auto ice maker.
The water switch does not sound like it is making contact.
  • Anonymous Dec 25, 2008
    i changed the filter but still not work
  • 94 Answers
Dear gig
check the colour light indicator for your water filter if red then the water dispenser will stop working until you change it. you will need your manual to read the icon presses after you change it to reset the colour indicator back to green
hope this is your problem solved
Posted on Oct 25, 2008
The washer knob does not make contact, needs to hold manually
Hello sunbill - Sounds like the switch behind that knob is beginning to fail. Consult a professional to move forward accurately and properly replace the switch.
Feb 14, 2013 | Frigidaire FEX831CS Top Load Stacked...
Switch it on, light buzzing sound, feels loke motor is not workin
Check the water supply. Sounds like the solenoid has operated but water not flowing.
May 01, 2010 | Indesit 24 in. D63 Free-standing...
GE side by side refrig no ice or water at door.
go to partstown.com they have info on most manufactures including tech. support, oem litature, and parts. all you need is make and model to get the info. your problem sounds like a defective control board or relay. eventhough you here the lever switch click it might have pitted contacts that are not making contact. you can verify with a multimeter by checking continuity.
Jan 24, 2010 | Refrigerators
Washer fails to start. Power o.k. and water supply on. Filters cleaned. When set to start makes regular sound as if trying to start cycle. Any advice please?
Hi.
Check if the water is flowing inside machine or not.
If the tub is not filling, test the water level device (usually a float switch located on a side inside the tub).
Ensure that the switch is not stuck, and test the switch using a multimeter to ensure it is closing and opening. Disconnect power before testing the switch.
If water level is OK, then test the water valve.
The inlet valve is tested reading impedance on valve solenoid contacts. Disconnect power and remove the valve first.
If the valve solenoid is showing no continuity, then the valve must be replaced.
A dual valve sometimes can also be tested swapping hot and cold inlet contacts.
All test and repairing must be done by a professional.
To get a quote on repair, check warranty status or get parts, call Zanussi at the number listed on the owners manual.
Dec 29, 2009 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
I don't know where to put the water. Its been draining water but I don't know how to refill it.
It makes water on it's own , thats the condensation from the Air conditioning process itself.
Better not to use the small water condensation drawer, rather use a bucket with the drain hose supplyed with the system. it holds alot more water and you shouldn't ever get the P-1 error code because of having the drawer full of water or the drawer switch missaligned.
If you do use the water drawer be careful and gentle when putting it back in after emptying it. It has a switch in it that makes contacts for the AC unit to work in AC mode and not just fan Mode.
The fan will always turn on unless it goes out, but the AC when it is on will sound diffrent when working it should sound a bit like a air compresser at the gas station because that is basicly what it is.
Sep 04, 2009 | Everstar Portable Heater/Fan
Whirlpool ultimate care 2, will fill with water and then nothing else
It sounds like you could have a lid switch malfunction. This is a common occurence when the switch wears out. The switch may be loose or not making good contact. As you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it.
Replacement parts can be found at searspartsdirect.com. Just type in your model number as "110.22832100" and the lid switch will be located under the "Top and Cabinet" heading as item number 11 (part #3949247). The lid strike is listed as item 20 (part #358684). You may also check repairclinic.com. They carry the SAME parts and sometimes offer a better price. For instructions on how to replace a lid switch, click on the following link:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
This is a simple and inexpensive repair if you wish to accomplish this on your own. This total repair will cost you a little more than $40. Let me know if you require addtional assistance.
Aug 31, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Please help me!
If this is a dehumidifier make sure the water bucket is fully in place. The bucket makes contact with a switch allowing it to run. When the bucket becomes full its weight trips the switch and shuts the unit off.
Jun 17, 2008 | Dehumidifiers
Maytag Atlantis wont run
JC, sounds like the lid switch, check this first and post back..Catriver
Oct 30, 2006 | Maytag Atlantis MAV6451 Top Load Washer
Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator Logo
81 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
