Question about Haier BC112G Wine Cooler
How to temp. to cool - Haier BC112G Wine Cooler
    Problem Solver:
  • 9 Answers
Push & hold the red wine button & the white wine button. This will start the adjustment process. Let go of both & use the plus & minus buttons to control the temp. When you are done hit the light button & the unit will record the new temp.
Posted on Apr 01, 2012
Tip
Too cool or over cool in room
Indoor sensor to sense the room temp and must cut off the compressor by working. If sensor defective, compressor will continuously running resulting to over cool in room. And also 23 C degree setting temp is best cooling for office and bed rooms. If for peculiar instrument which should be kept under low temp, can be set as mentioned temp (say 18 C or 16 C )<br />
on Jan 10, 2011 | Heating & Cooling
Auto Camry 97 cooling fan is not switching on automatically, the temp gauge shows normal temp. Also both AC and cooling fan works when AC is switched on?
If the temp gauge shows normal, you would not expect the fan to be on much. It is controlled by the coolant temp sensor. If the fan will not come on when the car gets really hot, it is possible this sensor has failed.
It is normal for both AC and cooling fans to be on when you turn on AC to cool setting.
Oct 27, 2013 | 1994 Toyota Camry
What makes the cooling fans turn on?
there is a temperature sensor that feeds the ecm(computer)a signal to let it know if the motor requires cooling operation at a predermined temp,which the ecm sends a signal to the cooling fan relay to turn on the cooling fans.when the temp lowers to a predetermined temp the signal is turned off to the ecm and the ecm turns off the signal to the fan relay to turn off the cooling fans.
Sep 18, 2011 | 2000 Pontiac Grand Am GT
Can't get my Simple Comfort 7890-DHW thermostat to set on heat. Tried the mode/program and have made it worse.
Push up or down arrow once. H will flash, this is heat setting. Set your temp. Then C will flash, this cool temp. Set your cool temp. After short delay stat will go back to display room temp. Red light heat is on. Green light cool is on. Hope that helps
Mar 24, 2010 | Honeywell Electronic Programmable...
My ac will not stay on when its at a certain temperture or auto. only if its in on position
this is correct because if you set it to certin temp. when it reaches that temp. it will shut down to prevent over cooling when the temp in the room goes up a preset amount 2-5 deg.(preset by manafatuer) the unit should go back on to drop the temp. to your set temp. Auto works the same way, where just on will cool to the temp the system can cool efficently.
Jul 31, 2009 | Heating & Cooling
2003 malibu cooling fans don't work. I have replace the relay and the temp sensor and still nothing. When ever I disconnect the temp sensor the fans come on and work normally, but later in the day I see...
okay pull the temp sensor connector ( disconnect it) and turn car on if the fans run then its the temp sensor.... part # wt3000.
Theres also 3 relays that turn the fans on in the fuse box cooling mode fan relay @15 which is part number 7234. and cooling one # 1 which is 3604, and cooling fan #2 which is 7236.
I have the same car...give me a fan clutch cooling system anyway of the week. simple and efective no problems.
Feb 26, 2009 | 2003 Chevrolet Malibu
2001 malibu 3.1 v6 cooling fans run all the time and temp gage
replace thermostat, this fixed my car, cooling fans keep coolant below temp guage parameters.
Jan 01, 2009 | 2001 Chevrolet Malibu
Temp
Before an evaporation cooler will feel "cool" there has to be a greater difference in the outdoor and indoor temps and/or humidity. If the humidity is high and the temp cool < 80'f The "cool" wont feel cool because there is not much evaporation taking place.
Now if the temp goes to 90 or the humidity goes down under say 40% the cooling effect "feeling cool" will change and be more like its cooling. Part because of the difference in the temperature but also because the air can hold more humidity and it is pulling moisture off your skin.
When you talk about "feel" it is rather suggestive and always different for different people.
Aug 04, 2008 | Mastercool 67680 Evaporative Cooler Air...
Haier BC112G Wine Cooler Logo
166 people viewed this question
Top Haier Furniture Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Haier Furniture Expert? Answer questions, earn points and help others
