Question about Bryant Electrical Supplies
Bryant panel issues
My house looses power off and on in different locations
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Habit-Forming:
  • 112 Answers
Check ur mains sounds like u are getting a loose connection or more likely u are loosing a phase of power which will kill one side of the panel or one phase at a time which would affect half the panel at a time
Posted on Aug 04, 2016
2 Suggested Answers
  • 760 Answers
SOURCE: is bryant breakers ok in a murray box
Look on the label inside the door on the circuit breaker panel. It should list part numbers for acceptable breaker. The key is the part number. Bryant is now owned by Westinghouse. Murry is now owned by Siemens. While many breakers will fit in other brand panels, they are only code compliant if they are listed for that panel in which they are installed. Since names have changed go by the breaker numbers. If the breaker number you have is listed on the label then it would be ok. Breakers aren't that expensive, if you have doubt, go to your supply house that carries Siemens and buy breakers listed for your panel.
Posted on Jul 11, 2010
Model numbers for Bryant AC difference between a model pa4zna048 & a rspma48
The difference is the sticker on the outside of the unit and the slightly higher price for parts on the Bryant. Go with the Rheem but don't be mad at me when it breaks down, the Bryant will too. Honestly it's luck!!!
Aug 30, 2017 | Bryant Heating & Cooling
Where is capacitor located on Bryant air handler? Cannot see on outside of blower.
you see where line voltage leaves house and goes into condenser panel it will be located there
Nov 07, 2016 | Bryant Heating & Cooling
How do I cut the power on a Bryant 200A load center?
there should be a quick disconnect where the line goes to the house by the unit, just pull the disconnect out of the box
Jan 08, 2016 | Bryant Electrical Supplies
My main breaker a bryant bj2200b breaker is buzzing why is that
This could be a loose internal breaker contact or connection between the electrical panel and the breaker itself. This is particularly troubling if the breaker is warm / hot. You should have it checked by a competent electrician.
Oct 04, 2013 | Bryant /murray Bj2200 Main Circuit Breaker...
I have older bryant 200 amp meter main panel and i need dead front
u would have to special order it if possible best thing would be to call supply houses and ask there sales reps. sometimes they will have things that they don't stock laying around or find one that is tore out, or getting torn out would be ur best chance
Feb 07, 2013 | Bryant Electrical Supplies
Where is the main switch to shut off the power in the house? I was vacuuming and the power went out in various areas around my condo. I think I have isolated the breaker and want to change it but I do not...
In some condos/apartments the main breakers are located outside. This is because the meter and incoming service are some distance from the local panel. Perhaps your breaker isn't bad, but the additional load of the vacuum caused it to "trip" Unlike some brands the Bryant don't show a trip indication other than the handle moving. Try turning this breaker completely off, ( if it was tripped, it will click) then turn it back on. If you do locate the main outside, and decide to change the breaker inside, be sure to "lock out" the main disconnect while you're working on the panel.
Nov 11, 2010 | Bryant /murray Bj2200 Main Circuit Breaker...
Is bryant breakers ok in a murray box
Jul 11, 2010 | Bryant /murray Bj2200 Main Circuit Breaker...
I have a Murray panel and Bryant circuit breakers. the service is approximately 40 years old. I tried to replace the Bryant 15/15 and 20/20 with a Cutler hammer and Murray circuit breakers but they just...
It used to be you could never install more than 42 circuit breakers in a panel. If you have that many spaces you cannot install "twin" breakers in the panel. There is a rejection feature for this. Some panels will have a portion that allows twins in part of tha panel, but not all locations so you cannot exceed 42 breakers. You can sometimes tell by the legend that willshow a space divided on some positions and others not. There are many different brands that will "fit" into your panel (GE,Bryant,Murry,Arrrow Hart, Crouse Hinds, Siemens), but only use breakers listed to be used in your panel, or you will not have the protection intended. If it's 40 years old maybe it's time for an upgrade. Be careful in that panel and be aware of arc fault protection when working on engergized equipment.
Jun 24, 2010 | Bryant /murray Bj2200 Main Circuit Breaker...
Electrical Supplies Logo
207 people viewed this question
Top Bryant Electrical Supplies Experts
john h
Gene Haynes
Tom Chichester
Are you a Bryant Electrical Supply Expert? Answer questions, earn points and help others
