Question about Refrigerators
Whirlpool Refr. GB22DK lower freezer- not defrosting/Minin glacier developing under sliding basket. Has been leaking water onto floor. .
  • Refrigerators Master
  • 4,654 Answers
Water forming is due to a defrost condensate drain being blocked by ice or gunk. Click Here=> Leaking Refrigerators Just What may Be Happening
Whirlpool Refr. GB22DK lower freezer- not defrosti - 2_17_2012_6_21_01_am.jpg
To see a larger image click Here=> Defrost Condensate Drain Blockage Read more on how to fix and repair this problem here=> Leaking Refrigerators! I will be here should you have questions, Thanks Sea Breeze
Posted on Feb 17, 2012
2 Suggested Answers
  • 1151 Answers
SOURCE: how to set temp on traulsen refr rth132dut-hhs commercial
https://feg.hobartcorp.com/resourcecenter/ProductDocumentation/TR35748%20G-Manual%20(3-09).pdf
https://feg.hobartcorp.com/resourcecenter/ProductDocumentation/TR35748%20Rev%201004.PDF
Check this web sites. It has manuals for your unit based on when it was build.
Let me know if I can be of any further help,.
Posted on Jun 27, 2010
Whirlpool GX2SHBXVY05 refrigerator leaking from bottom freezer onto floor.
if it has an ice maker check the water feed hose for leaks.
also I have a freezer that ices up twice a year. poor design. have to defrost every now and then.
Jun 09, 2015 | Refrigerators
Water leaking onto the floor of the freezer covering the bottom with ice. Every few days we have to crack the ice and get rid of it .
the drain tube hole behind the inner rear panel in the freezer has plugged up and when it defrosts the water cant drain down to the condensate pan at the lower rear of the unit to evaporate
Apr 08, 2013 | Whirlpool GX5FHTXVA Bottom Freezer French...
How do I remove the drip pan from under the freezer? It's full and leaking onto the floor?
There should be a decorative kick panel underneath that will snap out revealing the drip pan which will then slide forward and out to pour the water off.
Nov 25, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Bottom pull out freezer is leaking water onto the floor from on top of both feet of the unit. The freezer also has frozen water in the bottom of the unit. I have removed the frozen water in hopes that...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 15, 2011 | Whirlpool GI5FSAXVY Stainless Steel ...
Our Hotpoint Ice Diamond fridge/ freezer has developed a slow leak, or rather, it collects water condensate on its floor in the upper compartment which then oozes out onto the floor. I don't have a...
Thier are 2 possible thing causing that leak.
1 ) a blocked defrost drain..this tip i wrote will tell ya how to clear the defrost drain
FREEZER ON THE TOP OR BOTTOM http://www.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
SIDE BY SIDE http://www.fixya.com/support/r9991618-wrong_when_side_side_refrig_leaks_from
2) the water inlet valve that distributes water to icemaker and in door dispenser (if equipped) hasa pinhole in it and spraying water onto the floor...to check that gotta pull out ref.from the wall and remove lower rear service plate and inspect the valve for a pinhole
GENE
Aug 31, 2011 | Hotpoint Refrigerators
I have a Whrilpool refrigerator, model #
the drain hose to the base is plugged that sends water to the lower area by the floor to evaporate
Aug 01, 2010 | Whirlpool Refrigerators
Whirlpool 106.52562100 Side by Side. Leaking
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jan 19, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
Water leaking
Hi
There are several things to check for: The condensing defrost tray under the fridge can crack or develop a hole and leak onto the floor. A door gasket not closing properly may cause sweating and leak onto the floor. Some fridge's have a humidity switch inside the fridge that should be turned on to prevent sweating on the center bar between the fridge and freezer section. If your fridge has developed a frost free failure problem, often the frost will travel down the suction line at the back of the fridge and drip water on the floor. The heat exchanger tubing can separate and also sweat and drip on the floor. A kit to repair a separated heat exchanger line, comes with instructions as well. Ice maker and chilled water fill lines can crack and leak as well, this is fairly common with the plastic lines as they can dry out and crack.
Please revert for any clarification.
A Fixya rating would be appreciated if you found this to be helpful.
Thanks
Rylee
Feb 16, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Admiral HMG 62163 water leaking internally & freezing in lower basket
good attempt, its actually a clogged drain thats backing up and your drain water is not able to leave refrig so it falls to bottom of freezer floor and eventually out the door. romve the items from the freezer and take the lower back wall off form inside, directly under the evaporator under all that ice there is a drain hole, youll need to clear that hole of iec( pouring boiling water down until you get a free flow of water then you can reassemble uint problem solved
Oct 25, 2008 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
124 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
