Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Need "Data" save key for HCP-4752
Dear Person: I've entered factory menu & successfully adjusted the convergence...Problem is: I do not know the "Save data" button to push on the remote , so it does not get entered...It's a Samsung HCP-4752W...I do not have the exact manual & am working with a similar one...It does not have the correct info for "save data"...All I need is the correct button to push to save the data & this set is done...A quick reply IS needed as this customer is about to breathe fire down my neck....Thank you VERY much....RonM
  • ronm Oct 25, 2008
    Dear Person: NEVER MIND...I found it...ALL is ok...Thanks for looking ...:)
Baboso
Posted on Nov 01, 2008
Need code to enter on remote to engage multipoint convergence adjustments.Need save proceedure after adjustments are made & exit proceedure for RCA Projection TV Model # HD52W59, ITC 222A
To get the code to enter on your remote to engage multipoint convergence adjustments, you need to contact the rca customer care for that, you get them your model number and they will get your code for you.
To process and save the adjustment made, follow the steps below;
  1. Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  2. Enter the menu on your TV. Use the remote control and bring up the menu.
  3. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  4. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  5. Press "Enter." A crosshair pattern will appear on your screen.
  6. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  7. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  8. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  9. Repeat these steps for all colors.
Take care
Jul 06, 2010 | Televison & Video
Tip
HOW TO ENTER SERVICE MODE MENU TO PANASONIC TVs
This is the way to enter service mode menu to most of the Pansonic TVs.
1. Press and Hold Down the [Vol-ve] key, on the front panel of the TV set.
2. Press "Recall" button on the remote control three times.
The service menu window will appear.
3. Use digits [1] & [2] keys on the remote control to navigate Main Menu items.
4. Use digits [2] & 4] keys on the remote control to navigate sub Menus.
5. Press [Vol+ or Vol-ve] keys on the remote control to change the data value to selected item.
6. Power OFF the TV, by its main Power ON/OFF switch to save the adjusted value into memory and to exit from service menu. When you switch ON the set for the next time, it will come alive with adjusted parameters.
on May 20, 2012 | Panasonic Televison & Video
Sony kp-53xbr45 please let me know step by step how to enter in convergence service mode thank you
follow the below steps:
To Enter Service mode With the tv off and the remote in tv mode, press the following keys:[DISPLAY],[5],[VOL UP(+)],[POWER]
The tv will now display "3D-COMB" in the upper left hand corner.
Press the [2] or [5] keys to move up or down through the adjustment categories until you see "PJE" in the upper left hand corner(note that the letters will change to a different font).
Next press the [6] key twice, this will bring up a grid (crosshatch) without video behind it. When I refer to the [CENTER] key, It is located in the middle of the directional arrow keys on the remote.
When cursor is white, you can move it to an adjustment point using the arrow keys. Once you press the [CENTER] button, the cursor will lock to that adjustment point. It will now change to one of three colors ; Red, Green, or Blue. The color of the cursor will be the color you are adjusting. To change the color press the [3] key only when the cursor is locked to an adjustment point, pressing the [3] key when you are in navigation mode will have no effect. By Pressing the [CENTER] button again will switch you back to navigation mode.
To save your changes press the [MUTING] then [ENTER] keys on the remote.
Also, your tv may or may not have different convergence modes that you will have to adjust, if your tv is a hi-def you will need to converge the hi-def mode as well, With the cross hatch up you can press the [DISPLAY MODE] key to switch between the different modes. Make sure you save your changes before changing picture mode or your changes will be lost.
style="font: 7pt 'Times New Roman'"> On tv's that have different screen modes, you can try to copy the settings from the full mode once you have saved the setting by pressing [MUTING] then [ENTER] . To do this select the "ALCP" mode then change the data to "01" then press [MUTING] then [ENTER] again. the data from the full mode is then copied to all other modes. This procedure works for the "RA6" chassis, this procedure may be different in different models
Additional Information:
  1. Save changes often.
  2. The green crt is used to align the other two colors. If you need to get the grid straight, straighten up the green completely before adjusting the other colors. An overlay may be needed if the green is way off.
  3. After adjusting a point, you may throw another point out of convergence, Check for this.
  4. Start converging in the center and go out, don't start on the outside you will be fighting the convergence if you do.
  5. Avoid the tendency to adjust the worst point first, most likely one of the other smaller adjustments will get that badly converged point very close to where it needs to be. By adjusting that badly converged point first, you can throw off a well converged point somewhere else.
  6. If you are at the edge of the screen adjusting a point there, look at the opposite edge of the screen, you can throw a point off on the other side if you over adjust.
Good luck.
Jul 07, 2010 | Televison & Video
Akai PT5250A - I cannot converge correctly.
this fixed this problem
Plugs on the chassis coming from keyboard and side video input are switched (they have same plug)
redoo convergence save and auto focus in factory mode after switching plugs
Jan 13, 2009 | Akai PT5250A Television
Convergence problem
reset your tv with defaults settings.f chip and resstor blown then it need change.
Jan 06, 2009 | Philips 55PP9401 55" Rear Projection...
Samsung hcp-4752w
With power on, press Mute-1-8-3. That will get you into convergence mode. 1 sets factory default convergence. Avoid pressing 2 - it resets everything. 3 restores the last saved settings, 4 switches among fine adjust, line adjust and grid move. 7,8,9 - select R,G,B. The three keys below those turn RBG on/off.
Self-focus to save the settings. S-Mode to exit.
It can be a REAL headache, but take your time, and you'll get it done.
As an after thought....if you have a need to manually adjust the convergence, you probably have something wrong - unless you've just replaced parts and are doing the initial convergence.
Dec 02, 2008 | Samsung HC-P4752W 47" Rear Projection...
No color adjustment
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by avatar13.jpgejaparks on Mar 03, 2011
AdChoicesMajor Appliance Repair
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Overscan
For Factory Menu, press MENU 1 3 7 0
Service Adjustment Mode, press MENU 2 3 5 7
Convergence Mode, press MENU 2 3 5 9
Use the VIDEO or VIDEO buttons to enter two different groups of adjustments
Use the VIDEO / VIDEO buttons to toggle thru the adjustments
Use the + and - keys to adjust
When finished with adjustments, press ENTER to save
Press MENU twice to exit service mode
Hope this helps. You should look for the vertical height or size adjustment. Do not adjust anything you don't know about.
Dec 28, 2007 | Mitsubishi WS-65313 65" Rear Projection...
Convergence
Touch-up Convergence adjustments Enter the Digital Convergence Mode (DCM) by entering 0-6-2-5-9-7-(Status or Index) on the Remote control. The following menu will appear: Select an active channel or Aux Input. A signal must be applied to the set when performing convergence. If any Customer Adjustments need to be made, the Menu button can be used to toggle between the Customer Menu and DCM. The MPOSD ADJUST is used to center the Customer Convergence grid. A highlighted cross will appear along with the Convergence alignment grid. The highlighted cross should be centered onto the center of the Convergence grid. To perform a Touch Up Convergence, highlight SELECTION and press the right cursor button on the remote. The following menu will appear: Selections STORE, RESTORE FACTORY, and RESTORE DEFAULT are not shown after selecting SELECTION. Press the cursor down button on the Remote for these selections to appear. RESTORE FACTORY loads Convergence defaults from the Factory Loaded section of the Convergence Memory IC. RESTORE DEFAULT loads Convergence defaults from the sets software. To perform a Touch-up Convergence: 1. Enter the Convergence Mode and select RED TO GREEN or BLUE TO GREEN. Do not select GREEN (Green Geometry) without placing a Template over the screen. To perform Green Geometry, refer to the Complete in-depth Convergence. 2. Use the Cursor buttons on the Remote to Navigate from one adjustment point to another. Press the Status or Index button on the Remote to select ADJUST. Use the cursor buttons on the Remote to adjust the Red to Green or Blue to Green. Press the Status or Index button again to navigate to the next adjustment location. 3. After Convergence alignments are complete, press the Menu button on the Remote to return to the SELECTION menu. 4. Highlight the STORE selection and press the right cursor key on the Remote to save changes. 5. Use the GREEN TO RED or GREEN TO BLUE selections to perform convergence when the Green CRT has been replaced.
Aug 18, 2007 | Philips 60P8342 60" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
Henry  Thomas
Henry Thomas
