Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Belt keeps coming off
As soon as I start the vacume, belt comes off. Bought a new belt, still comes off. Are all windtunnel belts same for all models?
  • 1 more comment
  • shellyathand Oct 25, 2008
    I had the wrong belt. Thank you! I went back and got the one you suggested and it works great.
  • carmenaleman Nov 09, 2008
    I need to see how to install the belts?
    Smoking is coming out of it
    I forgot how to put it back
    I purchase the parts at a hoover store
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    No they are not. The flat belt for your vacuum is is HOOVER part no. 38528035. Is that the belt you purchased and installed?
    President:
  • 1,901 Answers
Great. Glad to help.
If you would, take a moment to rate this solution. Thank you. Happy vacuuming. :-)
Posted on Oct 25, 2008
Hoover windtunnel vacum..belt is rotating..brush is not..plus belt keep coming off
More than likely, there is hair or fibres caught up in the bearings binding them. There are usually 2 screws you can remove on the bottom of the vaccume that allow you to remove the plate. The back part of the plate usually locks in with tabs. Remove the plate, then pull out the brush. The bearing will come out of slots. Remove the bearings, and more than likely you will find hair or fibers wrapped around the shaft on each end of the roller. Remove the material, reinstall the bearings, roller and plate and you should be good to go! :)
Oct 07, 2012 | Hoover U6437-900 / U6439-900 Windtunnel...
I have a Hoover WindTunnel with a bag that makes a burning smell. I cleaned the brush and the belt looks intact. It still smells really bad. Could it be as simple as needing a new belt?
yes it could be that simple. sometimes the belt will wear and stretch. Generally I advise my customers to replace the belt once per year, or as soon as something gets caught to stop the brush from turning.
Your belt number should be on the model/serial plate on the bottom of the unit there. 38528-###. I am guessing its a 38528-033 but could be 38528-040. Your model/serial plate will be more accurate.
Nov 05, 2010 | Hoover Ultra U6430-900 WindTunnel Bagged...
I have a windtunnel vacum cleaner. When I
It might be a slipping rubber belt, is the brush roller moving when you look underneath? If it's a self propelled machine there might be another slipping belt. Friction from fast rubbing rubber can smell like it is burning.
Jan 16, 2010 | Hoover Company Wind Tunnel U53019 Upright...
Hoover U6439: Belt keeps slipping off
The belt is stretched and you simply just need to replace it. You can get the belts you need for this model here:
http://www.vacbelts.com/hoover-self-propelled-windtunnel-belt.htm
Sep 28, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Windtunnel belt
I've successfully used a compatible belt - Royal 104425001 .It's still new, but for the time being at least - it works.
Jul 29, 2009 | Hoover S3765-040 WindTunnel Bagless...
The belt on my hoover will not stay on. It falls
Okay. I would suggest that you have a problem with your roller brush. If the roller becomes clogged with hair/debris, the bearings will sieze, and sometimes even melt the plastic. the roller then has a difficult time turning and will break the belt. If the belt is slipping off, I would suggest that you either have a worn belt, the wrong belt, Or, your "windtunnel" (the half cylindrical insert the roller sets in) is missing. this insert has a "belt guide" that keeps your belt aligned. hope this helps!!!
Jul 18, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hoover Windtunnel - the belt keeps coming off & it is the correct
One compatible belt that I use and works (at least while its new) is Royal 104425001. Try that.
Mar 01, 2009 | Hoover S3765-040 WindTunnel Bagless...
How do I change the fantom fury belt?
Fantom Vacuum site. Find the Model #-usually
on the back of this model,type it in and you can
read and look at diagram .Good Luck.
Belt ordered at Totalvac.com.
Dec 29, 2008 | Fantom Vacums XT450K Upright Vacuum
Had a problem with the brushroll now its burning up the flat belt
When you put the flat belt on, is the print on the outside of the belt? Is the brush correctly positioned?
Dec 21, 2008 | Hoover U6630-900 WindTunnel Bagless...
HOOVER WINDTUNNEL VACUUM MODEL U6454-900 BELT KEEPS COMING OFF
Have you put on a new belt or just keep using the old one. If you haven't replaced it in the last 6 months, then it has stretched to the point where it won't stay on. Another cause is catching throw rugs, towels or something that gets in there and knocks the belt off.
May 31, 2008 | Hoover Vacuums
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
265 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
