RIcoh MP-4500 We are facing problem in copy quality and getting copy with back ground inspite of changing 2 times developer and copier made only 125000 copies. Original toner (4500E) , original developer type 26 is being used. lubsimram@yahoo.com Arif
  • Arif Sultan Oct 28, 2008
    Thank you but not rectified by replacing the cleaning blade, Is it not because of TD sensor
  • Arif Sultan Nov 02, 2008
    yes, we ran the calibration programme after replacement of developer
    President:
  • 903 Answers
You are using the wrong developer. Type 26 developer is for older models, like the 3045 and the 2045. The MP4500 uses a newer developer, part # B2969640. Not sure where you're getting the "4500E" toner from, but the toner should be type 4500A.
Empty out and clean the development unit, drum unit, and toner hopper, install the new DV and toner, run the developer initialization, and you should be okay.
Posted on Jun 10, 2010
  • 2,794 Answers
It's probably happening because the cleaning blade on the drum needs to be changed or replaced.
Posted on Oct 26, 2008
  • Tim Babcock
    Tim Babcock Oct 28, 2008
    Did you run the calibration programs in service mode when you replaced the developer?
I have a problem with my photocopier RICOH MP 5002 despite replacing new drum new cleaner blade and new developer my copier still copy very faint copies what could be the problem
when you replaced the developer, did you clean the "mag roll" of baked on toner? Very common problem on this model. Of course you initialized the SP mode 2-801, and 2-805 right? -Carl
Jul 29, 2016 | Ricoh Office Equipment & Supplies
RICOH MP4500 SC 390 DISPLAYS WHAT TO DO
Hello.
That error is related to TD sensor error.
I advise you to call a trained Technician
Mar 16, 2015 | Ricoh Savin Lanier Genuine Toner Type Mp...
HOW TO CLEAN RICOH AFICIO MPC2500 TONER PUMP? MY YELLOW COLOR PRINT QUALITY IS POOR. I FORCED TONER IT SEVERAL TIMES, BUT THE PRINT QUALITY IS STILL NOT GOOD AS WANTED.
have you check life of drum and developer powder. drum only good for 80,000 copies and developer for 160,000. that where i start for copy quality problem. toner pump function is to add toner which it is doing. because display is not saying out of toner.
Jan 12, 2012 | Ricoh Office Equipment & Supplies
My ricoh MP 2000 is printing blank documents when a print job is sent
is the copying ok? if yes then reload the print driver .it is causing the problem.if copying is also blankthen check the processing unit. the charge roller might be facing some problem or the developer gears might be worn out .
Sep 28, 2011 | Ricoh Aficio MP 2000 Black and White...
My copier ricoh aficio mp 2000 makes a continuous creaking like an broken or consumed gear. what's the problem?
MP2000s often have creaking and squeaking issues. Typically it's the brass bushings that ride on roller shafts, so if you can isolate it to an area and clean and lube the bushings, you might be able to fix the noise.
Aug 12, 2010 | Ricoh Aficio MP 2000 Black and White...
I have A problem of SC990 in the ricoh aficio 2035/45 and also I get light copies and over tonning problem.
The light copies and overtoning is probably caused by the developer going bad. Do you have a service contract on your copier? It's likely time for a whole PM (preventive maintenance) procedure.
The sc990 is probably caused by the copier's condition as well. Once you have the PM done (or at least replace the developer, rebuild the photoconductor unit, and clean or rebuild the transfer unit) the sc990 codes should go away along with the poor copy quality.
Jun 19, 2010 | Ricoh Aficio 1035 Copier
Adding developer to the new ricoh aficio mp 1500
Are you a tech? I suspect not. You need to remove the drum unit, disassemble, separate the drum from the development unit. Remove cover of developer unit, add developer, reassemble, and run SP2214 to calibrate.
This is NOT a procedure to be performed by an end user...no disrespect intended.
Apr 10, 2009 | Ricoh Aficio 2015 Copier
Want to know toner yield for the Ricoh Aticio MP 6500
43,000 copies/bottle (based on 5% coverage). For the extremely low cost per page of toner usage, why bother with toner save - you lose substantial quality
Mar 26, 2009 | Ricoh Office Equipment & Supplies
RICOH AFICIO MP 2000
you must clean developer and drum section. after that you must put new developer and initialize it. After that place in correct toner.
Oct 15, 2008 | Ricoh Aficio 1027 All-In-One Laser Printer
647 people viewed this question
k24674
