Question about JVC KS-AX4700 Car Audio Amplifier
JVC KS-AX4700 My JVC KS-AX4700 no longer works. When it is hooked up, very little power comes out (meaning subs barely hit, but some noise is heard). I have it apart, and I would love to fix it myself. Can someone help me out as to what the common parts that go are? What should I look for? Is it OK to dissassemble the board from the casing? Is it possible that there is still electricity stored in it (it was "undone" more than a month ago)? Any help would be appreciated. I am good at technical things, although I have very little electronics experience. A person posted an article that had help on making sure it is set up right. I am experienced in installing audio systems, I know it is the amp.
    Genius:
  • 1,139 Answers
It sounds like you have blown your Output amplifier MOSFETs (Metal Oxide Semiconductor Field Effect Transistors) You will see some components with metal tabs, these are some of those along with some secondary stage pre driver transistors also screwed to the metal case (heat sink). Ok you will need some pieces of equipment. First you will need a schematic of the unit (never work without a schematic), second you will need a volt ohmeter (yes I am old) you might call it a multimeter. Now this is the bare minimum of equipment you need. first open ope the scematic and find the main voltage rails and test points, these will be important as you traces the source of your problem down. I want you to take measure ments of the test points and compare them to the measurements in the schematic, the places where the diffences are dramatic are the places the problem may be. remeber take these measurements and compare them to the schematic and then try to isolate the problem down to the components that are truly bad. Also pick up a book on how to repair audio amplifiers. This is the best I can do over the internet, happy hunting my friend.
Posted on Sep 06, 2007
My jvc ks-ax4302 goes straight to protection when I turn it on, just curious what could be the cause and where could I find a schematic of the mother board?
If the Power/Protect LED is red, usually the speaker wiring has a short-circuit or the speaker total impedance is wrong for the system. The most common issue is a bare spot on a speaker wire that is coming in contact with part of the car or another bare wire. Sometimes, it just means that the system got too hot.
Before you look for a problem with the KS-AX4302 board, look at your wiring and replace any damaged wires.
I hope this helps.
Apr 11, 2015 | JVC Car Audio & Video
Jvc subwoofer sx pw22 working fine then just stopped working. power light is on and fuse is not blown. any suggestions?
First check all the connections. Something as simple as a loose wire will cause your sub to shut down. If all connections are secure, then your coils on the sub itself may have come apart. To test, try pushing in the center of the sub as it is playing. If sound comes out, it's your coils.
Hope this helps.
Dec 23, 2010 | JVC RX-778V
Everything is hooked up fine. the amp has power but no sound. I opened the amp and nothing looks burnt out.
Try you sub(s) on another amp...if they play off of it then its either your speaker outputs off of the amp or your rcas or wire from your radio are bad.
Nov 15, 2010 | JVC KS-AR7501D Car Amp
My jvc ax6300 amp is wired in and the protection light is on. no sound from the subs?
Try to rest amp (turn off power) be sure subs are disconnected. Se if protection light comes on. If it does the amp needs to be serviced porbably a burnt component. If the protection light does not come on, connect one sub at a time to see if either one surges. Could also be that the gain is turned up too much.
Nov 06, 2009 | JVC KS-AX6300 Car Audio Amplifier
Sub cutting out
Check the 12v wire running from the battery to the amplifier. Also the sony explode is a garbage subwoofer compared to the Alpine.. sony (they say 1200w max but its more like 100w to power the thing) Amp could be going. Is the amplifier hot when running. If there is a burnt smell comming from the amp, its the amplifier
Mar 27, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Color code for speaker out on a JVC KS R140 car casette player
White - left front
Grey - right front
Green - left rear
Purple - right rear
Yellow - memory power
Blue - remote power (power ant, amp or eq power)
Mar 20, 2009 | JVC KS-F150 Cassette Player
Jvc ks-ax4500 will not stay on.
check the remote terminal for a dissapearing voltage...it should stay at +12vdc for all the time it is ON. hope it helps.
Oct 14, 2008 | JVC KS-AX4500 Car Audio Amplifier
JVC KS-AX4700 doesnt work
Check this out: http://www.techlore.com/article/14696/
Aug 16, 2006 | JVC KS-AX4700 Car Audio Amplifier
JVC KS-AX4700 Car Audio Amplifier Logo
227 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
