Question about BenQ PB6100-REMOTE
Remote control for VCR won't work so I Tried to fix it by taking it apart and cleaning with alcohol.Still doesn't work and now it is hot where the batteries are. Can't get a new one as the RCA VCR was made in 1985.Not even a model number inside the control. HELP.
  • uselect Oct 25, 2008
    Thank you for your attention.You are right on.I'm not an expert,so I will try to find someone to help.
    I was worried that it would explode.
I have a problem i need sonething to find a sooftware for me,,,,,,,,,,,,, thanj fir
for.give.m.mowlana@hotmail.co.uk
Posted on Oct 25, 2008
  • 586 Answers
I think you have lost your precious Remote because you don't do it by yourself if you have not any experience about electronics. You made a mistake to wash it out with alcohol and i think you didn't give time to dry it.And moisture was still there and you you connect batteries with it too.That's why you feel hot.It means that a short circuit has been occurred in it.My advise is to contact any expert nearby to you and avoid any new experiment on it.It can be repaired yet.
Thanks.
Does anyone know how to fix the Sony RDR-VX560 DVD Recorder/VCR so that the DVD door closes? It closes but immediately pops back open and won't stay closed.
try a factory reset to see if that will help, but first take the batteries out of your remote, to see if this is causing the problem, if it is the remote you may have to take it apart and clean the board with alcohol.
May 02, 2016 | Sony Televison & Video
The volume control is not working properly on my CT-90319 remote controller.
Take the remote apart and clean all the rubber pads beneath and the PC board with the black resistive ink on it with a Q tip and isopropynol alcohol.
Then clean with a soft pink pencil eraser, and clean again with the q tip and alcohol.
It is best to do all of the buttons once apart, but if you only wish to get that one working, then just do the volume control buttons.
Don't be afraid to do this.........it is easier than it seems!
That will get you up and running again pending there is no small fractures in the resistive ink. 90% chance of working!
I hope this helps you!
William R!
Mar 02, 2015 | Televison & Video
Vcr remote control not working.
Hi! Bella , more research needed .... do you match each remote to its own VCR model?...did they ever work ?...have you put batteries in wrong polarity ?...are the VCR's at fault or blinded by ambient light ?.....are you pointing remotes correctly ?.....try your remotes on dealer's VCR's @ his shop & get dealer to try his remotes on your VCR's , or find a friend with same gear & do the tests there.......that should identify the problem[s] .... take careful notes of the results... & go from there.......jimbanjo
Jan 11, 2015 | JVC Televison & Video
Some remote control buttons not working
The pads in the remote are worn out, only option, take it apart clean rubber pad and circuit board with rubbing alcohol and paper towels, sometimes this will add new life.
May 14, 2012 | Funai PY90VG DVD Player/VCR
2 Button On Wii Remote Doesn't Work
Have you tried washing the button out with regular rubbing alcohol then let it dry overnight. this should do it, if it don't you will need to take the controller apart to clean the contactor more thoroughlly.
Apr 29, 2012 | Nintendo Wii Original Wireless Remote...
Hello, I synched my RCA universal remote, model#- RCU403, that I had bought, with my television. The remote worked fine and the controlled all of the available functions associtaed with the television....
You can try taking it apart with out battiers in it and then clean inside Pads and board with rubbing alcohol Clean let Dry and Put remote back together and see if it works OR You can go to the Dollar Store Buy A Brand New Remote Control Hand 4 in 1 unit with code Book inside For $6.00
Jan 08, 2010 | Televison & Video
Buttons do not work on my URC-8910
Most modern infrared remotes have a tendancy, after much use, for the contact between the button and the pad to get dirty or greasy or tarnished, etc.. I've serviced many of them and I take them apart (some not easy--have to remove a screw--maybe not). Anyway the pad surface has to be cleaned. I use a cloth dampened with alcohol and wipe over them and in some cases I need to take a soft pencil eraser and polish them. Hardest part is getting the unit apart.
Dec 31, 2008 | One For All URC-8910 LCD Remote Control
Sanyo DS32424
Could be a bad remote, bad contact on that button. You could try taking it apart and cleaning it with alcohol. You could also try hooking the unit up to your VCR (if you have one). The other option would be to buy a channel 3 modulator.
Hope that helps...
Geno
Feb 27, 2008 | Sanyo DS31590 31" TV
Battery busted in remote
Take apart and clean with alcohol and scrap all batt. acid off let dry and put back together.
Aug 27, 2007 | Hitachi CLU-5713TSI Remote Control
BenQ PB6100-REMOTE Logo
131 people viewed this question
Top BenQ Televison & Video Experts
Electro Med Services...
Are you a BenQ Televison and Video Expert? Answer questions, earn points and help others
