Question about Coleman Electrical Supplies
I have an old coleman OHV 2800 in pristine condition. However it will run good about a minute to 1 1/2 minutes & shut down. Oil level & gas is good & clean.
Kawasaki engine. Just went through the carb & cleaned it out. Checked with gas cap loose also. Cranks with 1 to 2 pulls w/ choke on. Thanks---Doug
SOURCE: engine dies
Your carburator is gummed up !
Take the float bowl on the bottom of the carb and spray the main fuel jet out with cleaner, do this to the idle needle valve also. If that don't work pull the carb & take apart & soak overnight in parts cleaner & blow out all ports & orfices with compressed air.
Next time you store your generator with gas in it , use a fuel stabilizer !
Good luck !
Posted on Oct 08, 2008
SOURCE: 2003 focus engine died.
This exact same thing happened to me....it ended up being the Mass Airflow Sensor. Replaced that and it has not happened since.
Posted on Nov 16, 2008
ollie reece
  • 1167 Answers
SOURCE: Bayou 300 cranks then stops after a minute
ok buddy to stop the back firing on the carb will be a screw turn this in 1/4 of a turn and try this the mixture screw on pic below
Posted on Sep 18, 2009
jdlipscomb41
  • 157 Answers
SOURCE: Coleman Powermate 6875 genset will on run with 1/2 choke
nick just take the carb apart piece by piece and pay very close attn to where the parts are coming from if you have to write it down or take pics. use a standerd carb cleaner but be sure not to spray any of the rubber or plastic parts with it. i hope you luck my friend. jd in la
Posted on Sep 19, 2009
  • 274 Answers
SOURCE: Honda generator ei3000. Will run only a few mins
Tank filter not blocked? (Take tap off tank) Enough oil in motor? Try overfilling it slightly
Posted on Oct 23, 2009
My 3500 watt Coleman genset with a Briggs and S engine starts fine but shuts down after 10 mins to 1 hr of running. then starts again on the first pull??
Most likely oil sending unit or fuel vacuum lock. Easy to check. Run with gas cap loose to allow air into tank. if it still shuts down, temporarily disconnect oil sensor. If the oil sensor is giving false reading and shutting down the engine, just leave disconnected, however, be diligent about checking oil level. Good luck.
Feb 02, 2016 | Coleman Electrical Supplies
13 HP Engine GX390 OHV Horizontal Shaft. runs perfectly fine/pressure fine for 2 to 3 minutes then shuts off. Have to restart over and over and over. Checked oil, no smoke, took air filter off, cleaned...
Check that the fuel tank is not creating a vacuum. this will starve the engine. After it shuts down the vacuum dissipates and lets the fuel run into the carb again.
Sep 10, 2013 | 13 HP Engine GX390 OHV Horizontal Shaft
Natural gas generator shuts down after about 5 minutes and won't keep running.
How big a unit? Model number? Alarm codes? If it runs for 5 mins check the obvious, coolant level, oil pressure and sensor,
Nov 07, 2012 | Caterpillar Electrical Supplies
Coleman power ate 5000 generator, will start very easy, run for 1-2 minutes then shut down, what could be the problem?
Check oil level, and viscosity is correct 30W etc
Then check oil presure switch and wiring
Aug 28, 2012 | Coleman Electrical Supplies
Oil comeing out exhaust and gas in oil but runs for a few minutes and shuts down
sounds like the needle valve is not seating and over flowing the fuel into the crankcase change the valve and seat then change the oil a couple times
Apr 27, 2012 | Honda Horizontal Engine 8 HP OHV 2:1...
Getting fuel in oil on 19hp b&s motor. Cleaned carb and drained oil, fresh oil and started motor, motor ran for 3 or 4 minutes then had to use a little choke to keep running and then it started...
How long did it take to do this job..did you clean the the carb first...then the oil or vise versa...the reason I as is ma y if these motors are equipped with an electric valve on the carb that go bad or stuck allowing the gas to continue flowing after shut down eventually in the intake valves and into the crankcase...causing smoke and high crankcase pressure and out the carb and exhaust...no use changing it WILL happen again..the fix is simple put an inline gas shut off and shut it off if only shut down for minutes...happened to my 18 horse Briggs...just shut it off every time you turn the engine off..Hope this helps..good luck..
Sep 08, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
I have a powermate 5500 that shuts off after 10-15 minutes. I changed the oil, gas, spark plug and the filters. Help!!!
If the unit has a low oil shut down make sure the oil if filled to the proper full level.
If you have the proper level then you can locate the low oil shut down wire and remove the wire to test and see if the unit will run.
If the unit runs with the wire off then you either have low oil or a bad oil sending unit.
Oct 07, 2010 | Coleman Electrical Supplies
Generac 5623 GP6500 8000 Watt 389cc ohv will not stay running. Will only run for a few minutes then quit and then usually can't restart.
if the gerator runs pretty smooth up until then, i would suggest checking/changing your oil as the low oil level switch is picking up on a slight change in the oil level (easier to detect when oil is hot), if it start to give hesitation or reduction of power, check the choke, make sure its off.
Jun 19, 2010 | Generac 5623 GP Series GP6500 8,000 Watt...
Coleman Powermate 10 HP Generator shuts down after a few minutes.
I have an HM100 on a 5500 watt gen with the same problem. This motor calls for a J17 spark plug, but I found using a J19 (hotter) plug solved the problem. I think the J17 doesn't get hot enough for a complete combustion burn so it act like fuel starvation thus resulting in the black sooty and wet plug.
Sep 24, 2009 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
133 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
