My wireless lg tv has no signal help - Televison & Video
MY late 1980's zenith space command TV clicks "off" everytime I try to turn ot on.
Posted on Oct 26, 2008
Hi I need help I have a LG 55LH95-UA.AUSVLJR WIRELESS TV.I CAN'T PICK UP THE A SIGNAL I HAVE REPLACED ALL THE BOARDS AND THE Wireless Intelligent AV Media Box.
Are you sure your TV has wireless?? it might not be compatible with the TV some bands dont work on TV. Check to see which your TV band it can access, then check your wireless router to see ifit sending out the right band signal.
Good luck
Dec 15, 2015 | LG Televison & Video
My lg tv does not recognise antenna socket/signal.
Check 2 items before going any further:
-- Make sure you have a good antenna signal by connecting it to another tv set.
-- Make sure you've switched input source of your tv to RF Antennae.
If the steps above didn't help your problem in TV tuner (assuming you're getting signal from other sources, i.e. DVD, VCR, etc). Have the unit serviced.
Mar 29, 2015 | LG Televison & Video
Connect headphones to tv
It sounds like you have wireless headphones so maybe its not tv maybe more like transmitter signal between headphones and reciever so hopefully you have a way to test siganal. However the default headphone jack on TV should work fine unless turned off in audio settings in TV. Hope some of this helps you.
Apr 15, 2014 | Panasonic Audio Players & Recorders
I have a 60LN5710 LG Smart TV. I want to connect to the internet. I plugged in an LG AN-WF100 dongle. At first I couldn't find my AP. A few days later I found it and connected to internet, however I...
Sometimes these types of issues are difficult to troubleshoot remotely (in this case, you've got 4 potential points to address: TV, dongle, router and ISP.)
If your TV and/or dongle utilize specific ports outside of the "norm," you may need to manually configure your router to allow for this.
Depending on the distance your AP/router is from the TV/dongle, the signal may not be strong enough. (Or, the signal coming from the AP may be present--you can confirm this with another wireless device--and maybe it's just the dongle itself has a poor range.)
Also, the dongle itself may be defective. Generally, there is some form of configuration that needs to be done, one way or the other, either on the computer, or on the TV itself (like a setup option).
Most likely, it's not an ISP-related issue.
Also, try to contact Sharp Technical support. They should be able to give you some recommendations that may prove helpful.
If all else fails, see if you can track down one of the dongles listed as being compatible in the TV manual, or find a dongle that's advertised as being compatible with your specific television, as that might be your best bet.
Good Luck!
Oct 12, 2013 | LG ANWF100 Wireless dongle
My lg tv didn't recognize a wifi dongle
http://www.lg.com/sg/support/product-help/CT20212004-CT20212005-1363223776114
Apr 10, 2013 | LG ANWF100 Wireless dongle
Lg 50pm4700 will not connet to the internet
I had a similiar problem and found a solution! :) im passing on my joy to you. Try getting a USB extension or just wrapping foil around the Dongle. It seems that the dongle or the TV causes interference of some sort to cause the tv to drop the internet. ON my tv it would say connected to the net sometimes but as soon as id try netcast it would drop. As soon as i got the extension it went away. At least try the foil thing. Wrap it like a Dog cone for injured dogs.
Jul 14, 2012 | LG ANWF100 Wireless dongle
My recently purchased LG 32LD550 TV is wireless ready. I purchased a LG AN-WF100 USB adapater but the wireless control input on the TV is of a different configuration. It seems to be a smaller connection...
The wireless control input on the back of the TV is not is not for a wireless adapter. It is used to connect a wireless media box, which you don't have. I have the same TV and use the wireless adapter. You want to plug your LG AN-WF100 into one of the USB ports on the left side of the TV.
Dec 23, 2010 | LG AN-WF100 (719192578838) Pre-802.11n...
Cant get signal or sound on wireless speakers. Which Audio Socket on TV do I use Audio/visual input or RGB DVI or Audio outlets on AV TV recorder Humax 9300T TV is LG model26LB75
you should be looking for the audio out socket from the tv as the signal is going out from the set to your speakers the other sockets are for input when connecting dvd or video into the tv. hope this helps ..A
Jul 21, 2010 | Anchor Audio/PA Systems: Liberty Sound...
TV saying no signal
The TV will flash this "No Signal" when it does not see a live signal at the selected input of your TV.
It sounds like the signal at the TV's input is not good to the TV, or the main board in the TV is having a problem and processing the signals correctly.
Try selecting a different woring device connected to the TV's input like HDMI1, Component1, or ..... to see if other inputs are working on the TV.
Good Luck.
Jun 27, 2010 | LG 42LH200C LCD TV
Televison & Video Logo
Top Televison & Video Experts
