Question about Kenmore Dishwashers
Kenmore Elite Dishwasher #1396 code F2E2
Dishwasher has stopped working. Displays code F2E2. What does this mean?
4 Suggested Answers
SOURCE: kenmore elite dishwasher stopped in middle of cycle
My Smeg (never buying brand again) dishwasher UKSTX1 has error message e9 not covered in manual
Posted on Jan 26, 2009
  • 10865 Answers
SOURCE: kenmore elite dishwasher does not dry
one of the buttons on the door will give u heat, just push that button
Posted on Apr 19, 2009
iwillfixforu
  • 619 Answers
SOURCE: lights do not come on kenmore elite dishwasher
There is a thermal fuse on this model located on the control board. Remove control panel and you will see it attached to the board with 2 wires going to it. part number is 8193762. Hope this helps.
Posted on Feb 24, 2010
What does code F2E2 mean on the display
My Kenmore Elite dishwasher is showing code F2E2..What ...
www.shopyourway.com > Agafia Reutov > Questions
The F2E2 error can be frustrating. The problem is the User Interface is not communicating with the main control board. This error is mainly caused by a poor ...
Kenmore elite service code f2e2 ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Te hose came off the bottom of the washer, then I got the service code f2e2. ... I have a kenmore elite dishwasher model 665.1396 ERROR CODE F2E2 ?
Oct 22, 2015 | Dishwashers
What does code f2e2 mean
F2E2 is a failure to communicate with the user interface board. This is caused by either a faulty user interface (the board with the buttons) or quite commonly it can be the main wash pump as the main control uses the same wires to communicate with both and a bad pump will interfere with that communication.
There is no easy way to tell which one is the problem but i have found that any evidence of a leak on to the wash pump will cause it to fail.
Apr 11, 2015 | Kenmore Elite 24" Built-In Dishwasher with...
My kenmore dishwasher elite doesnt finsh and displays code E24
It means that your hose is not draining. this is yourdrainage pump shutting off because of the block. If it is under warranty I suggest you have them come out and check the hoses. as a preliminary, remove your filter and clean it. If you are mechanically inclined and skilled you will need to follow your hoses to the pump and disconnect them and look for any issues. be prepared for water to pour out. have a bucket ready under the hoses.
Dec 22, 2014 | Kenmore Dishwashers
How do I get error code f2e2 off my dishwasher?
"F2 - A water leak, which if detected will stop water from entering the dishwasher via the inlet valve. You will probably experience the dishwasher not filling properly during a cycle. Possibly caused by a faulty water level indicator, you can also try cleaning the filters and drain if you notice a lot of standing water remaining in the dishwasher basin."
"Look in the bottom of the unit. Something has it stuck, like food."
sorry if this doens't solve your problem. This is what turned up with your keywords in a quick search engine query.
Sep 18, 2014 | Kenmore Dishwashers
Dishwasher will not start
Unlock dishwasher if locked by holding heated dry button for about 4-5 seconds next quickly hit the following buttons in successive order heated dry, normal wash heated dry then normal wash this should run diagnosis of the unit. Wait about2 minutes then press the cancel/drain button this should reset it and restore operation be sure to check that water supply is on and the drain is clear or you may get the code again.
Dec 07, 2013 | Kenmore 24" Built-In Dishwasher with...
Washer stops mid cycle and displays F 02 error code.
it means that your pump is clogged you need to take that bottom panel off the washer and twist the white cap slowly so it can drain put plenty of towels down once it is done draining pull the cap and clean the trap behind it
Dec 25, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite front load washer
I HAVE A KENMORE ELITE WASHER AND IT STOPS IN THEN MIDDLE OF THE CYCLE AND DOESN'T RISNSE. THE DISPLAYS SHOWS F21. CAN YOU LET ME KNOW WHAT THIS MEANS?
Sep 22, 2008 | Kenmore Elite 45986 Front Load Washer
Dishwashers Logo
2,078 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
