Question about Baby Gear
Instructions for the baby weavers shuffle sp isofix car seat emo black
  • 3 Answers
SOURCE: fitting cabriofix car seat with seatbelt only
yeah i had a cabrio and just fitted it in car with the seat belt the part of the seat belt that would go around your waist goes over the front of the carseat and over were the baby would be sitting there is clips at either side just below the carryhandle put the seat belt through them then put the part of the seat belt that would go around your neck round the back there should be another clip in the middle of the back above the storage part if you put the seat belt throgh it then clip the buckle in and pull tight the car seat should be secure hope i explained it easy to follow.
Posted on Nov 03, 2008
SOURCE: Lost one of the yellow connectors for isofix for Maxi-Cosi Priori
The 'Isofix guides' are available to buy from Dorel UK LTD (01842 767965) (See maxicosi website/customer services) for £7.99+P&P @ £3.99.
When I called (as one of mine is broken) they told me they are not essential to fit the car seat safely - they are simply 'guides' and if the actual forks on the seat are not damaged in anyway; not having the guides will not affect the car seat performance in any way.
Kindest regards
Glitterbabe628
Posted on Jul 29, 2009
  • 419 Answers
SOURCE: what's the difference between Easybase (non
The Easy Fix Base is used for cars which have isofix points in their car. The Easy Base fits into your car using the seatbelt.
Both of these bases can be used ONLY for the CabrioFix Carseat and cannot be used for the next stage seat (Group 1).
I hope this helps.
Posted on Oct 12, 2009
SOURCE: how to use recline function for britax kidfix seat?
A bit late to reply, but check out the video here;
http://www.britax.co.uk/car-seats/kidfix
Recline only works for ISO fit, basically put your hand into seat slot and grab the handle, push/pull to recline the seat
Posted on Jun 05, 2010
  • 286 Answers
SOURCE: Can a maxi cosi cabriofix
hi yes you can here is a video showing you how to fit in a car
http://www.youtube.com/user/Kiddicare#p/search/17/vO51Ev2c2Ok
Posted on Feb 17, 2011
Remove isofix base
Hi
Please contact us via the Facebook page with a PM so that we can send you instructions on removal of the base from the vehicle.
Jan 28, 2014 | Maxi-Cosi CabrioFix (Black Reflection)...
Please help. I have been handed down a britax ASIs car seat which has isofix. Problem is my car does not have isofix. Can I still use it? And do I need to take isofix off? Thanks
Usually the ISOFIX is simply an easier way to tether the seat to the car. Some believe it is safer than tradional tether methods.
You can simply use you car's seatbelts to hold the car seat in. The car seat has 2 large holes behind the childs lower back and that is where your car seat belts slide thru and then click into their connections.
Here is a link to Britax info on the Isofix and Isofit
Britax Info
Apr 25, 2012 | Britax Baby Gear
Need fitting instructions using seat belt for maxi cosi pebble in ford mondeo,our daughter has an isofix in her car.we are taking the baby out in our car and have to use seat belts and unsure how to fix...
Good Afternoon
Please go to www.maxi-cosi.com and ensure you are on the UK page. Then select the carseat you require fitting instructions for and you can download a replacement manual which shows directions and also there is a video available for how to fit with seatbelt.
Oct 26, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Hi, I just installed the isofix base Maxi cosy isofix without the yellow adapter. Know I am worried this could be a problem without using the, Does all users have these on? Is it necessary?
Hi - The yellow plastic guides are only for your conveniance if you need them. Some cars have very prominant IsoFix points and you do not need to use the guides - this is fine. As long as the indicators go green to show correct fitting it is fine.
Sep 24, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
How do you remove the isofix base from the car seat?
Every ISOFIX base has a button which you can press and release the base from the car seat.
Usually it's a round one at the junction of the ISOFIX base and it's LEG
Jul 29, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
I have lost the yellow plastic parts that make the isofix seat work. where can i get replacements?
Good Evening
The yellow plastic IsoFix guides can be ordered via your local retailer or direct with the customer service department on 01284 413 141 Mon-Fri 8.30-4.30. The RRP is £10 (set of 2) with £3.99 p+p if you order direct.
Bear in mind that these are guides only and may not be required. Some cars have the IsoFix points very prominant and quite high up so you can slot the IsoFix connections on without the guides; They are only to help if needed, if the IsoFix points are located quite deeply within the cushion of the vehicle seat.
May 20, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Does my car have isofix? ford focus zetec 55 plate ,3 door
Probably not, what it will likely have is the mount points under the seats which you can attach the isofix mount to. Apparently the isofix mount is £16. we have the 5 door 55plate zetec, just investigating car seats myself...
Apr 03, 2010 | Britax Baby Gear
Have purchased Maxi Cosi baby restraint with Easy Base - Iso fix,
The Maxi Cosi CabrioFix and EasyFix can only be used with IsoFix or the seat belt on (preferrably) the back seat. Please don't alter the mounting system of the seat as it will give unpredicable results!
The Commodore name has been around since 1978 so it is possible when you own an older Commodore you won't have any means to fix the Maxi Cosi seat.
If you do have IsoFix and/or seat belts in the back seat then please elaborate on the exact nature of the problem.
With kind regards,
Babycare.nl
Erwin de Raad
Jun 17, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Baby Gear Logo
109 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
