Question about Acer Aspire Computers & Internet
Turn on acer laptop and it goes to black screen that says no bootable device
When I turn laptop on, it goes to a black screen, than says No Bootable Device. I do not have any recovery discs. How can I fix this. I can't even get to the startup
  • Acer Master
  • 32,281 Answers
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Posted on Feb 17, 2012
  • 192 Answers
SOURCE: NO BOOTABLE DEVICE ,INSERT BOOT DISK
Generally this is an indication that your hard drive has gone bad, and is no longer visible to the computer. If your still under warranty, call Acer for service; if not, either order and replace the Hard Drive, or take it to a local shop, and they should be able to help you.
In this type of situation, chance are that the drive has died in such a manor that you won't be able to recover any data from it, but you could always ask the shop to try.
Posted on Jan 20, 2010
  • 114 Answers
SOURCE: no boot disc
Yes bunnydawg could be indeed correct. Although also make sure you don't have a flash drive, external hard drive, or any CD/DVD left in the drive first. As they could try to boot from the device and fail (because they are not setup and formatted as bootable) and it will report the very same message.
Posted on Jan 30, 2009
SOURCE: my acer aspire one says no bootable device
This sounds awful, but a friend just had the same problem - no bootable device. He had dropped it, hitting keyboard first. Now he thumped it on the opposite side and IT WORKED! Must have been a loose connector
Posted on Jan 16, 2010
  • 45 Answers
SOURCE: my acer aspire 4810t says no bootable device
enter BIOS - you will see a mesage when you first turn on laptop tellign you to press a key to enter setup. Do this and make sure HDD is listed. if it is, you might have todo a recovery.
Turn on laptop, then immediatly press ALT + F10 keep finger on ALT and press F10 a few times, this will start the recovery process. some ask if you want to re-install windows or full factory reset. Windows install will only repair it - full factory reset will delete any data you have! so be careful
Posted on Feb 14, 2010
shaky120
  • 310 Answers
SOURCE: no bootable disc?
it will be because your hard drive is faulty or you have deleted the software, but more than likely faulty hard drive very common problem.
Posted on May 13, 2010
No bootable divice please restart system
this screen appears when
hard drive has been removed, dislodged or stop working
to rule out the 1st two options
if your technical enough
turn power off remove charger and battery from laptop then try to reseat the hard drive
Apr 21, 2013 | Acer Aspire Computers & Internet
Whats wrong with my Acer Laptop when i turn on its black with white letters saying PXE-E63:Error while initializing its saying no bootable device can someone help me step by step please
If you want to pay a tech for help End willing to pay for step buy step instructions $70 per hour ,End in total for about 6 or more hours to get it working again.
Oct 25, 2012 | Acer Aspire One Netbook 8.9" Notebook
No bootable device PXE-M0F
You need to disable booting from the device in the Bios. It will be under the Boot options menu. Uncheck it from the list of devices to boot from.
Aug 22, 2012 | Acer Aspire 9300-5349 Notebook
Acer aspire 5935G laptop wont start
Reasons for this issue:- Contact acer tech support and ask for the operating system cd, you may need to re-install your computer- Possible Hard disk problem and it need replacement.
Mar 14, 2012 | Computers & Internet
Screen reads no bootable device
Your hard drive has an error, it has either lost it's boot sector or the drive has failed, If you don't have much technical computer experience i would advise getting a computer tech to look at it.
Mar 11, 2012 | Computers & Internet
Acer aspire 5253 error message no botable device after laptop was dropped on carpet
No bootable device suggests that your Acer Aspire hard disk may have been damaged when the computer was dropped.
You should try opening the cover on the base of the laptop where the hard drive is fitted and check to make sure that the drive is seated firmly and has not come loose with the drop. See the Acer Aspire 5253 Quick Start Guide for the location of the drive cover.
If reseating the drive does not help, then you would need to find any recovery discs that you may have made or received with the laptop plus need to buy and install a replacement hard drive.
Jan 10, 2012 | Acer Computers & Internet
When I turn on my laptop it goes to a black screen that tells me... Intel UNDI, PXE-2.0 (build 083) Copyright (C) 1997-2000 Intel Corporation For Atheros PCIE Ethernet Controller...
based the message that you encounter, it may pertain to boot priority or to BIOS configuration.
My recommendation is for you to access and reset the BIOS settings on your computer.
May 10, 2011 | Acer Computers & Internet
It's boots up and show the acer home screen then turns black and says t press f2 but nothing happens
It's having problems looking for a bootable media ( like optical drive, harddrive, bootable flash drive).
Try these steps:
  1. Unplug any external devices, including memory cards.
  2. Turn of the computer, remove the ac adapter & battery, then hold down the power button for 10 seconds. Reconnect the ac adapter and battery. Turn it back on.
  3. Set the first boot device to harddrive
If problem still persist, please revert back to me or call an authorized Acer technician
Feb 05, 2011 | Computers & Internet
My acer aspire 4810t says no bootable device
Feb 14, 2010 | Acer Computers & Internet
How do i resrore my acer aspire laptop without the dvd drive working?
youe have to have any bootable device either usb bootable drive or any other optical device that can be used as bootable device
Oct 09, 2009 | Acer Aspire 5100 Notebook
Computers & Internet Logo
181 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
