Question about Whirlpool Washing Machines
Repair Man Replaced Belt on Whirlpool Washing Machine Model# LA 780P and now the machine will not Agitate or Spin ?
Machine fills up with water ok but does not pump out or Spon at all ?
  • Patrick Feb 16, 2012
    This Washing Machine is an Older machine and has a regular Drive belt like in a car ? The Agitator and Spin worked for Two Days after the repair Guy fixed it and now it just sits and makes a lot of noise ! I, called the repair man back and he said rhis machine is too old but this is the first problem we have had with it and we owned it for 16 years now !
    Where can I, 'Download" a manual for Free ?
    Problem Solver:
  • 7 Answers
Go to home appliance parts site .check your make and model .there are parts print out that show the drive . you mite work it out form there.
Posted on Feb 16, 2012
3 Suggested Answers
  • 641 Answers
SOURCE: Whirlpool Ultimate Care HD Plus Model #LSR8233EQ0 won't agitate or spin
It sound like a belt issue. Open machine's cover and check that belt is not broken. Good luck!
Posted on Aug 04, 2007
SOURCE: no spin or agatae
Unplug machine. Change load type to medium. Clean door sensor. Set knob to drain and spin. Plug machine back in to powr. Open and close door 10 times in 15 seconds. Pull knob to activate drain and spin.
Posted on Nov 03, 2009
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
Nov 02, 2015 | Washing Machines
My washing machine doesn't spin but fills and drains can anyone help me
Sounds like what happened to ours. you need a belt. The belt is probably broken. Does it agitate at all? If not, it's definately the belt & if you are not handy: be ready to pay a repair man about $150. Plus parts.
Mar 19, 2013 | Washing Machines
Washing machine fills with water ok but won't agitate completely, will empty the water but will not spin.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Whirlpool 3.2 cu. ft. Plus Washer
Washing machine fills, but will not agitate, drain or spin
Coupling broken which joins the motor to the gear box. Look and see or listen if the motor is running then if nothing else is working coupling is broke, easy to replace.
Dec 05, 2009 | Whirlpool LSR5132PQ Top Load Washer
Replaced belt but machine will not agitate or spin , but does let water in it
if it is a topload u have a bad transmission thats what broke the belt was trying to spin and couldnt
Apr 16, 2009 | Washing Machines
Maytag washer will not fill with water. It does agitate and spin
My May Tag model LA 882 washing machine is not draining water. the water remains even after spining and the cycles are longer durations. any advise ?
Mar 31, 2009 | Maytag Washing Machines
Washing machine will not spin or agitate.
Replace the timer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Washing Machines
Washer does not agitate after filling with water
does it spin?
sounds like your coupling is broke.It takes the place of the belt if it breaks it won't spin or agitate. it will still pump though.
Part # 285753A
Nov 04, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will not agitate or spin
if hte machine is either a whirlpool or a kenmore sounds as if you have a bad motor coupling ( ths machines equivelent to a belt)
Mar 07, 2008 | Washing Machines
Washing machine doesn't agitate
If washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. Note: direct-drive washing machines do not have belts. 1) Check the spin cycle. If this works, the motor is operating and the belt is not broken. If it doesn't, the belt may be loose or broken. If you're fairly handy, tighten or replace the belt, otherwise call an appliance repairperson. 2) Check the lid switch and the tab on the lid that strikes it. If the plastic tab is broken, the washer may halt during certain cycles. Press and release the switch: if it doesn't click each time you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person. 3) Call a repairperson; there may be a problem with the controls or the agitator solenoid may be broken.
Jan 18, 2006 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
47 people viewed this question
Dan Webster
Dan Webster
Sal De
