Question about Master Lock Home Security
Master Lock 5401D wall mounted
I just installed, reset the combo, entered code and it opened. Closed and tried again and it will not open. The "open" latch does go all the way down but it is not releasing the door.
lobsterman72
  • 91 Answers
SOURCE: Door will only close when held down
That normally happens when the sensors aren't aligned. Both sensors have led lights on them the yellow/orange one will stay on all the time the green one will go out if it cant see the other sensor. Possibly theres a wire that's broken or the other sensor is really out of alignment. Check every inch of wiring from the sensor to the opener, remove wire nuts if present and check the connections. The wires that are used are small, solid and can break easily. Also see if there's a staple that's too tight, move the wire abit where it's stapled and look for damage.
Posted on Jun 27, 2008
  • 6 Answers
SOURCE: New Home, existing system, no information on what current access code is
Powering down for several hours should reset the code to 1234.
To power down, find where it plugs into the wall. It'll be a big plug, about the size of your fist ( a three-inch, block style plug), black, white or beige in color, probably a little screw holding it in. It may be directly below the panel or could be in the room on the other side of the wall of the panel. Otherwise, it may be in a garage, basement or attic. It may be in a weird place, like behind a couch in the living room or on the ceiling in the garage. Good luck finding it!
Next, disconnect the back up battery. This can be tricky because it's really easy to break the little tab that holds the compartment shut. With the cover open, look at the top of the panel or the sides/corners. CAREFULLY push the tab, open the cover and disconnect the battery.
Leave it powered down for 24 hours and then plug in the battery first, then plug it into the wall. The code should (hopefully) be 1234 now.
Posted on Nov 20, 2008
motor1258
  • 6674 Answers
SOURCE: 97 Camry - trunk will not latch closed
Sparay lock assy with lubricant, and look where release cable attaches to lock assy, and push/pry it one way or the other to get it to move, opposite of where it is. Lube cable too.
Posted on Jan 09, 2009
  • 244 Answers
SOURCE: remotes not working door won't go down
safety beam problems
Posted on Jan 15, 2009
SOURCE: door won't open after self-cleaning cycle is complete
Turns out that the latch is attached to a plastic piece (made by the manufacturer) and the spring melted! To boot, the fuse in the back which aids in heating the oven went out also. Repair man said this was typical after several uses in cleaning cycle. He recommended using a gentle steel wool pad with soap built in to gently remove backed on food instead of using cleaning cycle. It is just too hot for too long, and there seems to be a domino effect with things that will go wrong. Nothing like the old fashioned way and a little elbow grease!
Posted on Mar 20, 2009
How do I set up a Master Lock Key Safe with a new code
Open the box, with the existing combo, push the reset lever to the left and down, dial in your new combo, push the reset lever up and right to set.
Oct 04, 2014 | Master LOCK 5401D Combination Key Safe...
Reset GE magnetic key holder
www.masterlock.com/.../5400D_Instructi...
Jul 02, 2014 | Master Lock 5400d: Portable Select Access...
I cant open my nokia 6120 because someone try to enter incorrect password morethan 5 times and now i cant open it using my lock code
Network unlock having 5 tries ,But security unlock forgot means you can use the master reset code and reset it.You can get the master reset code from the site
www.simpleunlocking.com and reset the incorrect password or security lock.
Oct 19, 2011 | Nokia 6120 classic Cellular Phone
I doubt you can help me. I've moved into a flat with a Master Lock Select Access outside the front door. [5401D) I have the instructions but there is no record of the combination, and stupidly I've...
Unless the last occupant registered your Master Lock 5401d combination at Masterlockvault.com and can assist you to recover the combination, then you can only try every possible combination.
Masterlock themselves will not assist you as you are not the registered purchaser.
Jul 27, 2011 | Master Lock 5400d: Portable Select Access...
I messed up entering a new combo on my master lock speed dial thing, this is the second time I did this, how can I open my lock?
If you did not clear the lock before entering new code, you probably have a long combination: the old and new together. Squeeze the shackle twice, enter both codes as one new code and open.
Sep 18, 2010 | Office Equipment & Supplies
The combination our Master Lock Co Combination Lock Box Part # 5401D was changed by accident. How do we find the combination to open the box?
No joke... trial and error... its not going to be fun, but work out a system so you don't cover the same number twice.
Aug 30, 2010 | Master Lock 5400d: Portable Select Access...
Code change for trilogy lock D2700
First find out if you are dealing with a D2700 or the newer enhanced version. Press any 2 buttons and *,if you get a green LED and 6 beeps it is the new version. Old version remove battery and press any button. New version remove battery, press any number for 10 seconds,release, reconnect battery, press and hold the A button within 3 seconds, 6 beeps, release A button. the lock is at default and ready to program. To program new version 12345 A1A new combo A new combo this will set a new master code, if you are only using 1 code to open the lock this should suffice.
Jan 27, 2009 | Trilogy Alarm Lock T2 TRILOGY® Digital...
Home Security Logo
Top Master Lock Home Security Experts
Lawrence Oravetz
Are you a Master Lock Home Security Expert? Answer questions, earn points and help others
