Question about Electrolux EOG7330WN Gas Double Oven
Turning on grill blows fuse on Electrolux EOG7330WN
I am having a problem where my oven my oven will not turn on.  No clock, no gas releases and no igniting sparks - a dead oven. I replaced the fuse and the oven came back until I tried to turn the grill on.  This reliably blows the fuse immediately.  Looking inside the grill there doesn't seem to be anything out of place.  I had though that the igniter might be shorting, but it doesn't look like it.  Even when the fuse is replaced, although the main oven doesn't blow the fuse, it still doesn't seem to work.
Any ideas?
Chris
  • dmclau1030 Jan 19, 2009
    I have had a similar problem insofar as the oven is completely dead. I know it is not the fuse in the wall. Wonder if there is a fuse internally as well? I was part way through cooking something. Opened the hob extractor hood. It came on. I closed it and left the kitchen. About 20 minutes later when I came back noticed that the oven had stopped so not sure if my opening the hood blew a fuse then or maybe it wasn't related? Anyway all I know is it doens't work now!
    Top Expert:
  • Electrolux Master
  • 40,800 Answers
Get i an accredited electrician to check the grill element and fitting
there is a dead short in that area
Posted on Apr 23, 2017
3 Suggested Answers
comike187
  • 17 Answers
SOURCE: DIAGRAM FOR A ELECTROLUX EOG600BN
240v mains powered soloniod for the oven is probably burnt the only other possibilities are the cooling fan on top or even the reignition unit on the top
Posted on Aug 28, 2009
oldTech2332
  • 2341 Answers
SOURCE: I have an electrolux EOG6330
Hello dishboy,
There are 2 possibilites causing that
1) The electrode(spark plug) for the grill is is built up with a bunch of grime and not telling the spark module the burner is lit and turn off the spark. The electrode could be cleaned with the green srubby side if a kitchen sponge,or relpaced.
2) The electrode is telling the spark module to turn off but the spark module isn't responding, to turn off the spark. The spark module would need to be replaced
I hope this helps,
Gene
Posted on Aug 04, 2011
Hi, I have an Electrolux EOU 6330 electric grill/oven. In have only used it twice as i have just moved in to the house and after the second use during the cool down period it started rapidly clicking and...
Try turning the power off to the oven at the meter box and leaving it off for an hour or so. This will allow it to fully reset. When you power up again, reset the clock time and set to manual cooking , hopefully , all will work again.
Jun 27, 2014 | Ovens
WE HAVE AN ELECTROLUX DD060GA DOUBLE OVEN THE TOP OVEN IS WORKING BUT THE BOTTOM OVEN DOESN`T EVEN COME ON WHEN YOU TURN THE KNOB THERES NO GAS AND NO SPARK AND THE LIGHT WONT COME ON EITHER, CAN YOU...
Good Morning Friend,
I understand that your Electrolux double oven, model# DD060GA, is having trouble with the bottom oven coming on. I also see that your top oven works just fine. This appears to be a UK Electrolux double oven. I suggest contacting the manufacturer directly. They will be able to better assist you in getting your bottom oven functioning correctly.
-Best Regards-
WP
May 21, 2014 | Electrolux EOG7330WN Gas Double Oven
Replaced EOU43002X element, clock/timer now dead
Make sure there is power to the timer. Should be a fuse somewhere.
Mar 19, 2014 | Electrolux Ovens
Grill gas comes on but on release of grill knob, the gas goes off.
I would arrange a service call from a registered gas safe engineer.
Apr 13, 2017 | Electrolux Ovens
Aug 21, 2009 | Electrolux Ovens
Electrolux oven eog7330xn stopped working
Hi Chaps,
I have an 18 month old Electrolux Gas oven model No: EOG7330XN which worked for 14 days then died. There was no power displaying and I called Electrolux to service within the warranty period. The engineer removed the front control panel and replaced a fuse inside which brought it back to life.
Am I right this is possible, I have removed the panel but can't see any fuses?
Jul 30, 2009 | Electrolux Ovens
Where is the reset button
Hi.
thanks for request re your gas oven,unfortunately ,I have no experience of gas ovens, and am therefore unable to help solve your prob.
Check the experts, and see if there is one who is conversent with gas ovens.. Once again , sorry.
Jan 10, 2009 | Electrolux EOG7330WN Gas Double Oven
Electrolux oven wont heat up after power cut
hiya
sounds like the fan element could have blown, causing the electrics to trip out. best thing to do is remove all the racking
and then the rear panel that covers the fan and element. if he element has blown most of the time it will be visible.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 03, 2008 | Electrolux EOB6636X Ultrafan Electric...
Electrolux EOG7330 gas cooker - electric timer fails?
Pull off bottom knob of oven shine torch down at 45degrees u will see a red plate turn off power suply and use a small screwdriver to push the plate turn power back on job done.PS Check all vents are clear to stop it over heating good luck.
Jul 18, 2008 | Electrolux EOG7330WN Gas Double Oven
Tripped out
take off the oven knob, behind is a piece of plastic - the reset switch is behind that.
you have to poke a smal screwdriver in and should hear a small click
Sep 02, 2007 | Electrolux EOG7330WN Gas Double Oven
Electrolux EOG7330WN Gas Double Oven Logo
197 people viewed this question
Top Electrolux Ovens Experts
ashburton
John Tripp
John Tripp
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
