Question about Canon PIXMA iP3000 InkJet Photo Printer
5 yellow blinks canon ip3000 - Canon PIXMA iP3000 InkJet Photo Printer
Canon inkjet PIXMA ip3000 wont print and has 5 blinking yellow lights
Canceled the jobs on PC and verify the inks.If you use the refill inks perform the head cleaning in the mantenance mode.
Feb 13, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
My canon pixma ip3000 in blining red and yellow led
write me your email to send you the service manual for ip3000
Mar 09, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
5 yellow blinlking lights. Power on/off doesn't clear the lights. Won't print. TIA...
Canon IP3000 INK counter reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Can try it may work all the best of luck
Feb 15, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Printhead is not recognizing the ink cartridges
1. Turn off printer
All The Best Pineworks
Dec 29, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Blinks green, yellow, green yellow
Anytime it flashes green and yellow there's a service error, but you need to count how many times it flashes between the longer green flashes, that tells us the error code.
Oct 28, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon Pixmar iP3000
the yellow light means you need to resume printing, hit the button on top right
Jun 14, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Can't switch up my Canon iP3000 printer
Problem solved - I bought a new printer. On a long run it is cheaper.   Thanks    Mila
Apr 10, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Error 5100
Hello! Try this:
1. Unplug the power cord
2. While pressing the ON button, plug the power cord back in.
The power light should flash an orange/yellow color.
Continue pressing the ON button, and press the RESUME button 4 times. The light changes every time you press it.
3. Release both buttons, and restart the printer.
The printer should now stop blinking and operate as usual.
I hope this works for you. OMS
Apr 05, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Problem with pixma ip3000
try to reinstall the driver for the printer, sometimes this helps fix small errors like this.
Jan 06, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
90 people viewed this question
old marine
old marine
