Question about Ryobi Drills
Where can i get replacment cells for my ryobi lithium battery
Cell number sansung 1nr 18650-13q sd1
    President:
  • 261 Answers
Hicheck it on http://www.ebay.com/
Posted on Feb 16, 2012
Can a Ryoby Lithum battery can be repair or rejuvenate?
Yes. The first step is to open the battery and check the condition of the wiring for breaks, corrosion, etc. Also check the condition and voltage for the individual 18650 cells. Ryobi batteries are relatively easy to disassemble using available tools, see posting below.
https://www.ifixit.com/Guide/Cell+Re-balance+of+Ryobi+One%2B+18V+Li-ion+Battery+%28130501002%29/13286
Depending on the findings, some parts may need replacing. If you replace the 18650 cells, use new ones which are easily found on eBay.
Oct 12, 2014 | Ryobi Two 18V Lithium-Ion Batteries +...
I have a lithium ion battery and it won't charge. The red lights simply keeps flashing. I warmed up the battery, but so far no luck
There could be a variety of reasons for the battery malfunction, some of which are listed below:
a) low battery voltage due to long term storage without charging (>1 year, charger will not charge if the voltage is too low. What is the voltage?),
b) cell imbalance due to shorting out the terminals (was the battery used for other purpose than running power tools?),
c) internal corrosion caused by exposing the battery to damp environments during its life (need to open the battery and look for signs of corrosion on the cells. Was the battery left out in the rain at some point in time?),
d) battery age, ie, the cells may have reached their end-of-life based on the number of charge cycles (what are the estimated number of cycles?),
e) faulty charger (does the charger charge other batteries?),
f) internal battery damage with broken connections (has the battery been dropped or mishandled at some point?).
More details should be provided before suggesting possible solutions.
Jun 15, 2014 | Ryobi Two 18V Lithium-Ion Batteries +...
How to fix lithium battery got wet
The battery cells inside lithium ion batteries (and other types of batteries) tend to corrode if they become wet for a given period of time. They need to be dried out immediately to avoid corrosion. Unfortunately, it seems like it is too late to dry out yours. Your battery will need to be carefully disassembled using procedures on fixya and the corroded cells replaced with similar quality cells. The cells in Ryobi batteries are spotted welded in place and these welds need to be broken carefully using a Stanley knife. Replace the cell(s) with new ones or from other disassembled batteries and solder them in place. Check for cell voltage imbalance (see other solutions on fixya) and reassemble. Good quality Panasonic Li Ion cells can be purchased for about $4 each on ebay. If you go this route, I would recommend replacing all cells, not just the corroded ones.
May 13, 2014 | Ryobi Two 18V Lithium-Ion Batteries +...
Will the P110 charger charge a lithium ion battery
No, the P110, 18V NiCad battery charger, will not charge a 18V lithium ion battery. You need one of the dual-chemistry chargers. If you have the Ryobi ONE+ batteries, you can get the P117 charger ($30) or a charger with an extra battery (P126) from a store like Home Depot. A 6 battery charger and a 12V in-car charger are also available.
I wish that I had better news for you.
(who has the Ryobi 12V drill and charger, a few of the 4V tools, and a number of the ONE+ 18V devices and chargers. The single chemistry battery charger is not used much any more.)
Nov 24, 2012 | Ryobi Two 18V Lithium-Ion Batteries +...
Who rebuilds ryobi 18 volt li ion batteries
Rebuilding the Lithium batteries is a waste of time and money. For starters the cells cost a minimum of $5 ea and a low power pack takes 5, so now you are in for $25 without doing any work. You can pick up packs on eBay for around $30 - $40 if you shop around. If you know what you are doing, you can strip cells from bad packs and test them to find good ones and then rebuild with those. It can be tricky and you may get mixed results.
Aug 23, 2012 | Ryobi Two 18V Lithium-Ion Batteries +...
Ryobi one+ batteries - lots advertised from China.. Are these real Ryobi or counterfeit?
They are real Ryobi packs but are said to be used/rebuilt from warranty returns. Forum users have posted that they typically do work, but can be in very rough condition and may have off brand or used cells inside. Better to spend the money and get new ones when on sale.
Mar 19, 2012 | Ryobi Two 18V Lithium-Ion Batteries +...
Ryobi batteries P103 (2) or P104
The physical differences between two models of Ryobi batteries is:
- The P103 (Part Number 130429008) is a 1.5 Amp/Hour (a measure of how long a battery lasts on a charge) battery. If totally discharged it takes about 15-20 minutes to charge back to full. It is lighter than the P104 because it has half the cells inside. Lighter, quicker to recharge, quicker to discharge, shorter lifespan.
- The P104 (Part Number 130429017) is a 3.0 Amp/Hour battery. It takes about 30-35 minutes to charge it to full if fully discharged. Slightly heavier, longer time to discharge & recharge, longer lifespan.
Considerations:
- No difference between batteries in the performance of your tools.
- The number of times you discharge and recharge a battery determines a batteries lifespan. That's why most manuals will tell you to fully discharge a battery before putting it on a charger.
- If you only have one battery you cannot use your tools while it is recharging. On big projects you have to have two batteries.
- The weight difference between batteries is negligable unless you are working with the tool in your hand for extended periods.
Mar 04, 2012 | Ryobi Two 18V Lithium-Ion Batteries +...
One of my Ryobi 18v battery packs (1400672) won't charge, the chargers red and yellow lights stay on. How can I trick it into charging?
Use
AC / DC Power Adapter Replaces Ryobi One+ Batteryhttp://lcdpayless.com/ryobi_one_power_adapter.php
Oct 22, 2009 | Ryobi Drills
Drills Logo
Top Ryobi Drills Experts
JOHN LAPIER
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
