Question about Whirlpool LER4634J Electric Dryer
Whirlpool electric dryer runs only when holding start switch
Hello. I have a whirlpool electric dryer (GEW9878PW0). Initially timed dry would only run for about 10 seconds, diminished to only running while holding the start switch and then stop. Next it started by itself when the timer was moved to timed mode and made a very faint beep. I removed the board and noticed a large resistor and a couple of smaller components were burned. I replaced the board. I entered diagnostic mode and all the tests ran OK however it only runs with the switched pressed. It's only a around 3 years old. Thanks in advance for any and all help.
  • Anonymous Mar 30, 2014
    F25 code also dryer runs past it's time
    Genius:
  • 1,028 Answers
If you've replaced the board replace the relay to right of bd the one with 2 blue wires to ck before replacing just switch relays the other one with red wires controls the heat
Posted on Oct 26, 2008
417.84052500 electric dry 05 model safe mode code. Everything lights up but won't run
Rocky, Could be door switch problem.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Bypass dryer door switch Whirlpool
Dryer Not Starting How to Test the Door Switch
. Whirlpool Kenmore Dryer Repair 01 Won Start or Run Door Switch 3406107...
http://www.selfhelpforums.com/archive/index.php/t-10060.html
Mar 13, 2016 | Kenmore Dryers
Whirlpool Dryer GEW9200LW1 skip digits when set to dry
If the clothing comes out dry within a normal time,usually 40 minutes or less. Whats happening is the computer is recatulacting the time remaining to dry a load of clothes as it senses they may still not completly dry or even will drop off some time if clotes are dry before time computer calculated at start of cycle.
Gene
Aug 16, 2011 | Whirlpool GEW9200L Electric Dryer
My whirlpool ler4634 electric dryer has electricity running to it but when turned on, the drum does not rotate. It only makes a loud humming noise. What can be the problem?
It sounds like you have a blown motot try holding down the door switch and push start and turn drum at same time see if it kicks in
Sep 22, 2010 | Whirlpool LER4634J Electric Dryer
Dry want start
you will nead a nother person to help you make this test.first open the dryer door,next put the timer on timed cycle.with your right hand hold in the door switch,next have someone push the start button and at the same time take your left hand and turn the tub clockwise.if it starts than you have a bad moter.the age of the dryer will determin wether it is worth fixing.
Jan 23, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool model no LEB6200KQ0 will only dry on the Very Dry Cycle. I have to run on the timer dry 3 to 4 times to get the clothes dry.
Judging from the model number, this is an electric dryer. There can be several things wrong with it. I would start with the vent. Make sure it is not clogged (especially at the end) or kinked behind the dryer. Also, check your breaker. Electric dryers can run with one half of the 220v breaker tripped. Try switching the breaker to the off position and then back on. That may solve your problem, but if it returns, you will need a qualified electrician or appliance service tech to see where the problem is originating. If neither of these help, you will need a tech to see whats going on inside the dryer. hope this helps
Nov 09, 2009 | Whirlpool LEB6200 Electric Dryer
The WHIRLPOOL TEDS840PQ0 dryer wont turn on. The
Check the house electrical panel dryer circuit breaker pair--push off, then on. Try the dryer again. If still nothing, measure the voltage across the two slanted slots in the dryer power socket. It should measure: ~230 volts AC. If at or near zero, either one of the breaker pair is defective, or a wire is open from the breaker to the socket. If you read ~230 volts, then the problem is within the dryer--motor runs, but drum doesn't turn (broken belt), or motor doesn't run (bad controller, motor, door switch, start switch. Does the unit get hot? Need more help on your end.
Oct 18, 2009 | Estate TEDS840JQ Electric Dryer
Whirlpool Ultimate Care II Quiet Dry I, LEQ9508PWO
I would suspect the timer is on it's way out the door. Do you have any areas the timer has dead spots? Check the exhaust for any plugging also.Is this only on a first time start up or is it after this dryer has been running? If after running it could be a high temp sensor, that by the time you are playing around with it, the temp has changed.
Jan 24, 2009 | Whirlpool LEQ9858P Electric Dryer
Whirlpool duet dryer will not start. Panel lights come on as usual and when press start machine clicks and will not start. Light on wet sensor lights and no drying action begins.
press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly. This is a secret test and reset for your dryers control, so please keep this between us. The whirlpool people would be heart broke if they see this posted on the web ;-) . If your dryer will still not start after this test, you may need a new control. If you need a part let me know and I can ship it right to you. Good luck and I hope this will fixYa and saves you the $400.00 it would cost for whirlpool to send a certified tech to come to your home.
Mike Anderson
Anderson Appliance Repair
9865)945-3808
Dec 01, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool Imperial Electric Dryer won't start
I have a problem with my Whirlpool IMperial electric dryer, not a Duet gas dryer.
Jul 12, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool LER4634J Electric Dryer Logo
153 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
