Question about Panasonic Bagless Upright Vacuum Cleaner MCUL915
Need to replace small belt on Panasonic MC-UG302 upright vacuum cleaner
This has a bag - model MC-UG302
  • 1462 Answers
SOURCE: no suction in vacuum on a Panasonic MC-V7355
the device is a bypass which allows some air flow when there is a blockage. you have a blockage somewhere i suspect hence no suction. check all hoses carefully. take off the base and check the air duct away from the brush roll
Posted on May 03, 2007
reddevil6
  • 1673 Answers
SOURCE: panasonic MC-V7395 Belt overheating/snapping
With a belt on, make sure that the motor spindle is sitting straight and not being pulled down towars the brush roll. If it is then hte motor cover will have to be replaced, which may not be available anymore. Another is make sure that the brush roll spins freely and not froze up. Also make sure that where the brush roll sits in the slots, that it hasn't over heated there and damaged the noozle.
Posted on Jan 05, 2008
  • 389 Answers
SOURCE: Filters for panasonic vacuum cleaner MC-E468
Hi! Sometimes really hard to remember which of these models is which, so please forgive me if this is not a complete solution.  I'm pretty sure you will find there are two filters.  The first is a foam filter, and is located at the bottom of the bag compartment.  It pulls out to the front, and is washable (of course it must be completely dry before re-use).  The second (and here I'm on less secure ground) is a HEPA filter, and is located behind a removable panel on the front of the bag compartment door.  The HEPA filter is not washable, but rarely if ever needs to be changed unless the machine has been used for vacuuming a lot of extremely fine dust. I hope this helps, and I value your feedback. Please remember to rate my response.  Good luck!
Posted on Feb 24, 2009
ukvacfan
  • 328 Answers
SOURCE: Panasonic MC-E468 vacuum cleaner loss of suction
HI If the cleaner is loosing suction make sure to check all inspection tubes and the dirt channel hoses after the spinning brush. Also check the main hose for any clogging. One of the worst faults of this model is clogging hoses. Hope that helps you.
Posted on Feb 27, 2009
expertsarah
  • 70 Answers
SOURCE: How to open the vacuum cleaner to replace the bag?
pust the button on top flap will open.
Posted on Jun 22, 2009
Panasonic optiflow upright vaccum
Hello, Put the vac on its side and remove the screws holding the cover plate on. This exposes the beater bar and belt on the side. Pull the beater bar out and take the belt off. Reverse this to put the belt back in place.
May 30, 2014 | Panasonic MC-UG323 OptiFlow Upright Vacuum...
Panasonic Replace Belt MC-5127
The Panasonic MC-5100 Series takes this belt here:
Panasonic MC-5127 Replacement Belts
Dec 20, 2009 | Vacuums
Feb 27, 2009 | Panasonic MC-E583 Bagged Upright Vacuum
Order drive belt
Panasonic belt # MC-V2708 is the correct belt for model MC-V7395.
Dec 11, 2008 | Panasonic MC-V7395 Vacuum
Part numbers for washers and end caps of vacuum agitator brush
The part numbers for the washers and caps can only be found if you know the agitator brush number.
Mar 28, 2008 | Panasonic MC-V5745 Bagged Upright Vacuum
Lights are on but motor won't run?
I had the same problem, and i found this is the user guide: problem: Tripped circuit breaker/blown fuse at household service panel. Solution: Reset circuit breaker or replace fuse so, i've replaced the fuse (my friend did) and it solved it.
Sep 14, 2005 | Panasonic MC-V5005 Bagged Upright Vacuum
Panasonic Bagless Upright Vacuum Cleaner  MCUL915 Logo
397 people viewed this question
Top Panasonic Vacuums Experts
jasbo
jasbo
Joseph Hoffmann
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
