Question about AudioBahn A4601T Car Audio Amplifier
Audiobahn A4601T, only 1 audio channel works
I just received a refurbished unit from the factory. Audiobahn is now out of business so I have no way to return it. I am only getting sound out of 1 audio channel. All of my RCA's work, I can put my old amp in place and every channel works. I tried swapping all the RCA channels and and speaker channels around. Only channel 1 plays any sound. I then bought a second unit, from the same place (refurbished) and it has the exact same problem. I can still put my old amp in and every channel works.
Any ideas?
  • chrisb111200 Oct 27, 2008
    Yes, it is the same channel in both amps that produce the output, Channel 1. I tried all options on the switches and pots. I put all the pots in the middle and changed each switch on each channel 1 at a time. I tried different speaker combinations and RCA combinations and only get audio through channel one. I am thinking it is a misswired compenent when inside it got refurbed?? Weird to have the same problem on 2 amps, then to test an amp 6 years old and have all channels work.
Absolutely. Thanks for your help. I will open it up some time this week and take a look. If I can't figure it out I will reply and give you my email so I can send you some pics.
Posted on Oct 27, 2008
  • 631 Answers
Is it the same channel in both amps that produces output?
Have you tried all combinations of setting for the switches and pots on both amps?
Posted on Oct 26, 2008
  • Perry Babin Oct 27, 2008
    It's possible that someone refurbing them did the same thing (wrong) twice.
    You should disconnect them from the power source and remove the covers to see if you can see anything obvious. If you can't, can you send me a set of good quality photos?
Audiobahn a1502dp amp only one channel is working. I need both to bridge it and get its full 1ohm potential. Where can I get this fixed? Preferably near kc
Audiobahn A1502DP True Digital Series 2-Channel Amplifier
www.sonicelectronix.com > ... > Car Amplifiers > Class-D Amplifiers
Rating: 4.5 - ‎4 reviews
Audiobahn A1502DP • True Digital Series 2-Channel Amplifier 1 ohm stereo stable 2 ohms bridged • True Digital Circuitry • Dual Cooling Fans • HP/LP ...
new amp, only one channel working?? help! [Archive ...
www.caraudioforum.com > ... > Car Audio: Installation Help
Apr 24, 2006 - 16 posts - ‎5 authors
the next step would be to try reversing the rca cables on the amp. ... unplug one wire, the one sub that is working, gets quieter, although it is still working. as ... It'saudiobahn, of course this could happen straight from the factory.Missing: a1502dp
[PDF]True Digital Full-Range Series - Audiobahn
audiobahn.com/.../Amplifiers/A752DP-A1502DP-A2502DP-A1004DP-...
A752DP/A1502DP/A2502DP ... Audiobahn was established in 1997 with one long-term goal in mind, ... Great products and proper installation are only a small piece of the puzzle when it ... from the smallest terminal, to power wires up to 0 gauge, and 4channel RCA cables. .... exceed the total value of fuses in the amp. 1 1 .
one channel not working [Solved] - Speakers - Audio
Jan 15, 2016 | AudioBahn Car Audio & Video
DUB2502 550w 2-channel a/b mosfet amplifier 1000 watts maual
not 550 watt,,250 x 2 ,,
  • 2-Channel Class-A/B Amplifier
  • RMS Power (4 ohms): 250 watts x 2 chan.
  • RMS Power (2 ohms): 375 watts x 2 chan.
  • Bridged RMS Power: 500 watts x 1 chan.
  • Min. Impedance Unbridged: 2 ohms
  • Min. Impedance Bridged: 4 ohms
  • Brushed Aluminum Chassis
  • Top Mount Controls with Blue Illumination
  • Cooling Fan
  • Chrome DUB Fan Grille
  • Glass Epoxy Circuit Board
  • PWM MOSFET Power Supply
  • THD: 0.02%
  • S/N Ratio: 95 dB
  • Input Sensitivity: 200mV - 4V
  • Frequency Response: 10 Hz - 40 kHz
  • Variable 18 dB/Oct. Hi-Pass / Low-Pass Crossover: 50 - 250 Hz
  • Bass Boost: On/Off 12 dB
  • 4-Way Protecion: Thermal, Short Circuit, Overload, and DC Offset
  • Dimensions: 8-1/4" W x 2-1/8" H x 10-3/4" L
  • Authorized Internet Dealer
Audiobahn DUB2502 2 Channel 250W 2 Class Amplifier at Onlinecarstereo com
http://www.audiobahn.com/index.php/help/tech-support/manuals/category/1-amplifiers
Feb 26, 2014 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
My receiver has no output from the CD channel. I have my pc plugged into the OPT1 connection. It worked fine until I think a power outage. Can I reset it somehow?
Press and hold vcr 1 button while then pressing power button this will reset the unit.Remember all settings will return to factory default.
Apr 16, 2010 | Onkyo TX-SR701 Receiver
How many watts is the audiobahn a2401t
i think it's 100watts on 2 channels,
so further explaining: 50 per channel, but if you bridge them, meaning connecting one wire of the speaker to the plus of one and the pother wire the minus of the other will result in 2 channels converting so to say in one channel and giving a 100 watt x 1 channel.
hope this is useful, and greetings,
Olivier.
Oct 20, 2009 | AudioBahn A2401T Car Audio Amplifier
Audiobahn powered subwoofer
yep, they dont make audiobahn any more i think they still make other subs to one of them is DUB subs, ebay is the best place for me to find audiobahn, and for parts...
Jul 24, 2008 | AudioBahn A2300HCT Car Audio Amplifier
Audiobahn dvd player and monitor for car roof
hi i bought 3 units of this on ebay for 7$ bucks fully working missin remote control if u want i can sell u one head unit for 10$
Jul 08, 2008 | AudioBahn AVM372DVD 7 in. Car Monitor
AUDIOBAHN A3351 WIRING HARNESS
you have to find one that somebody has audiobahn dosnt carry them any more i called them today for mine but no luck
Oct 30, 2007 | AudioBahn A3351 CD Player
Amp Problem
my first thought would be the rca's. make sure the rca's are in good condition and also make sure that their in the right spot from the head unit. (some head units have multiple rca outputs or inputs) and be sure that your gains and levels are all set right
Sep 12, 2006 | AudioBahn A4601T Car Audio Amplifier
AudioBahn A4601T Car Audio Amplifier Logo
98 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
matthew walsh
Level 1 Expert
Iron
Iron
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
