Question about Siemens Lands Phones
A385 doesnt cut off when returned to cradle
Doesn't chirp when returned to cradle
  • 41 Answers
Its probably your cradle not connecting to the phone. if you have not dropped your phone or the hook ups on it are not bent or scratched you should take it back. you could check the cradle if you dont have a receipt, make sure all the connectors are receiving power and are not bent downward
Posted on Feb 16, 2012
Binatone bb200
I've had exactly the same problem. The connector that plugs into the docking cradle (or phone if you don't use the cradle) is faulty. Mine had a short circuit. Try gently moving the cable closest to the connector. Alternatively, turn off the charger at the mains socket, leave for 10 minutes or so then switch back on. If that doesn't prove it and you're lucky enough to have another charger, try that to see if the original is at fault.
Be warned that even though it's a 5.2V charger and a common USB type should work, getting hold of the identical USB connecting cable I found impossible. I had no luck sourcing a replacement Binatone charger either.
In the end I removed the sticker from the base of the cradle revealing the screw then undid it to dismantle the cradle. The cradle is very simple so don't worry. I cut the USB plug off the charger, bared & tinned the wires then soldered them directly to the docking contacts (wire with feint white broken line is +5V and should go to CH- solder pad, the plain black 0V wire goes to CH+). You'll have to cut a small notch in the lower edge of the cradle to pass the wires through before reassembly.
The soldering's very easy but don't overheat the pads otherwise the contacts will fall off which might be tricky to reposition. I'm quite handy with a soldering iron but if you're not, it's only a 5 minute job for anyone that's competent.
Jun 19, 2013 | Cell Phones
Brand new mower smoking on first start
tie a rope on the handle and allow it to run for 5-min with no load on it if it doesn't clear up then return it to the store you bought it at
Aug 04, 2012 | Garden
GE washer WCVH6800J1WW - fabric softener doesn't empty
see the causes and remedies:
It spins, but doesn't pump
drain lines clogged, repair+sock in outer tub port, if the lines is not clogge the problem is pump replace
It doesn't spin or pump
frozen pulley pump, replace
It pumps, but the water returns improve the draininin laundry, if have reaches 4 inches cut off the excess. if is lower install air/gap siphon break assembly.
God bless you
Jul 18, 2012 | Washing Machines
Kenmore washer not draining
drain line is clogged+some sock inside remove+pump defective, if lines is not clogged.
frozen pulley pump, replace,try to rotate manually, if donot replace
improve the drain line, if exceed 4 inches cut off the excess
God bless you
Sanyo 42'' tv no picture chirpping
CHIRPING MEANS SET IS IN PROTECTIVE SHUTDOWN---AND IT MAY BE RELATED TO THE POWER SUPPLY OR SOMETHING TRYING TO DESTROY THAT SUPPLY.
Jun 11, 2012 | Televison & Video
My horn doesn't chirp when I lock the doors.
My chevy doesn't chirp on the first press of the lock button, it just locks. If you press it again, then it chirps. To be honest, I like the fact that it doesn't chirp first - that just draws attention to the fact that you left your vehicle.
Nov 30, 2011 | 2004 GMC Envoy
I just bought a nuvi 1450. I also purchased a friction mount for the dash. It says to snap the cradle into the arm. It doesn't go easily and I'm afraid that I'll break it. Any suggestions?
The 2 wide bumps(not sure the technical name) of the cradle go on the bottom first then the two close bumps that have a lip go to the top of the 1450. Also the hole where the suction cup mount snaps into the cradle is closer to the bottom of the unit.
I have the same gps and the cradle is slightly different than the picture in the manual. I have attached a link to the manual and you can see the picture and diagram on page 2.
Thanks for using FixYa
http://www8.garmin.com/manuals/3130_OwnersManual.pdf
Jun 16, 2011 | Garmin nuvi 1450 GPS Receiver
Black doesnt print all other colors work, ink is full
Try printing a few test pages to get the ink flowing. It's likely clogged/dried out. If it's a new cartridge and doesn't work, you should be able to return it. Alternatively, you could carefully try wiping the nozzle with a lint-free cloth and some rubbing alcohol.
May 05, 2011 | Canon S520 InkJet Photo Printer
Lands Phones Logo
421 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
