Question about Xerox Phaser 6180DN Laser Printer
The printer does not want to print any more because it says the Transfer Unit is end of life. It takes approx. 30 days to get a new unit delivered, and the fuser will take even more (Fuser is "low" so needs to be replaced soon). I would like to be able to print while waiting for the unit, so I was thinking about resetting the counter. Can this be done? How do I do this? Thank you!
SOURCE: Paper jam at fuser
1. Faulty/blocked fuser exit sensor or faulty/blocked POB sensor. The printer thinks paper is present at one of these sensors when there should not be paper present
Verify that the fuser exit sensor is not stuck
If both sensors are working correctly, the most likely cause is the POB sensor is being blocked by the transfer unit. This can happen if the sensor is out of position, or if the transfer unit's white plastic baffle is out of position. Try bending the POB sensor bracket outward slightly to clear the baffle and retest.
Posted on Dec 19, 2007
SOURCE: Paper jam 2 fuser
1. Faulty/blocked fuser exit sensor or faulty/blocked POB sensor. The printer thinks paper is present at one of these sensors when there should not be paper present. Verify that the fuser exit sensor is not stuck Verify operation of the POB sensor If both sensors are working correctly, the most likely cause is the POB sensor is being blocked by the transfer unit. This can happen if the sensor is out of position, or if the transfer unit's white plastic baffle is out of position. Try bending the POB sensor bracket outward slightly to clear the baffle and retest
Posted on Dec 20, 2007
SOURCE: Fuser temp error
To test fuser out of circuit make sure lamp and thermal fuse are not open circuit, and thermister is neither open or shorted
Fuser repair procedure from tec manual.
Fuser Failure (U4-1, U4-2, & U4-3)
1 Switch off printer main power. Remove the Fuser Full Cover so you can observe the Heat Rods. Switch on printer main power and observe the ends of the Fuser Assembly. The Heat Rods glow.?
Y N
| Go to step 5.
2 Replace the Printer Engine Controller PWB (REP 4.10.6). The error message reappears.
Y N
| Problem solved.
3 Replace the Fuser Assembly The error message reappears.
Y N
| Problem solved.
4 Check for a broken wire or a loose connection
between components
5 Measure the AC voltage between J23-2 and J23-6 on the AC Driver PWB. There is 110VAC (or 220VAC if the printer is the 220VAC model) between J23-2 and J23-6.
Y N
| Go to step 7.
6 Replace the Fuser Assembly (REP 4.7.1). If the problem persists, replace the Printer Engine
7 The Fuser cycles up and down.
Y N
8 Measure the voltage between P401-1 and P 401-4 when the Fuser Fan cycles up and down. There is 24VDC between P401-1 and P401-4 when the fan is rotating and 0VDC when the fan is off.?
Y N
9 Replace the AC Driver PWB
Please rate solution to your question "How can I check that new Fuser unit is ok?"
Posted on Jan 10, 2008
SOURCE: Horz. streak approx.3/4 down on each page I print
From the service manual:
Dark Streaks in a Single Color or All Colors in the
Direction of Paper Travel
.There are dark lines running along the page in
the direction of paper travel from the leading
edge to the trailing edge
This is generally due to fuser, paper path roller
and/or exit guides contaminated with toner
debris.
Troubleshooting Procedure
Step Check Yes No
1 Run the Remove Print Smears routine from the
printers front panel.
Did this fix the problem?
Complete Go to step [2].
2 Are there any obstructions, dirt or debris in the
printer’s paper path.
Check for toner spills inside the printer.
Clean and
remove
obstructions.
Go to step [3].
3 Visual inspect the Imaging Units and rollers for
signs of damage.
Note: Exposure to light can damage the
Imaging Unit, examine the unit quickly
and out of direct sunlight.
Replace the
defective
Imaging Unit.
Go to step [4].
4 Check the Fuser where paper enters for spilled
toner or contamination.
Clean if dirty. Did this fix the problem?
Complete Go to step [5].
5 Verify the ribbon cables and wiring harnesses
on the LED Heads are seated, connected and
routed properly.
Go to step [6]. Reseat, reroute
or replace any
damaged wiring
harnesses.
6 Generate a service test print pattern from within
service diagnostics. This will test the Engine
Controller Board.
Did the test pattern print correctly?
Replace the
Image Processor
Board.
Replace Engine
Controller
Board.
Posted on Dec 09, 2008
SOURCE: Xerox Phaser 6250 fuser issue
I was stressing out to change the fuser. But, your directions were as simple as A-B-C. Thanks a lot!!!! It worked
Posted on Apr 17, 2009
Aug 27, 2014 | Dell 3130cn Color Laser Printer
Jan 29, 2013 | Oki Electric Industry Okidata C5500, C5800...
Jun 22, 2011 | Toshiba E-Studio 250 All-In-One Laser...
May 18, 2011 | Xerox Phaser 6110 Laser Printer
Apr 26, 2011 | Dell Compatible Maintenance Kit Dell...
Mar 30, 2010 | Xerox Phaser 6180N Laser Printer
Jul 10, 2009 | HP LaserJet 3700n Printer
Feb 14, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Sep 30, 2008 | Xerox Phaser 7700 Laser Printer
Apr 18, 2008 | HP Color LaserJet 3500 Printer
63 people viewed this question
