Question about Dual Electronics XDM6350 Car CD/ MP3 Player
My red wire has no power - Dual Electronics XDM6350 Car CD/ MP3 Player
  • 41 Answers
The radio or car has no power?
Posted on Feb 16, 2012
On my 1982 ford f-150 could my truck's blue wire with the glass fuse on it be my power wire and my accessory wire, if not which wire would be my radio's power wire and accessory wire?
Your power wire is Red and your accessory power wire will be red with a yellow line on it ?our red goes to your batery and the red and yellow goes to ingnition so that the radio only goes on when you turn the key
Mar 02, 2016 | 1982 Ford F 150
Red accessory wire
The red accessory wire goes to ignition or a switched power source. There should be a blue wire that goes to power antenna.
Dec 26, 2012 | JVC KD-R200 Car CD/ MP3 Player
I am trying to install a Pass & Seymour Harmony fan speed control switch. It has 2 red wires and 1 black. I hooked up the power to the red line and the black leading to the wiring for the fan. No...
Are you wiring for 3-way or single pole?
In other words, are you using 1 switch (single-pole) or 2 switches (3-way)
http://waterheatertimer.org/pdf/Pass-and-seymour-3-way-3-speed-fan-control.pdf
Before installing device, separate all wires in box and turn power on and then test each wire to bare ground wire >> tester will light up on Hot power source.
Black wire on device is connected to Hot power source.
Red wire on same side of device as black wire is capped off in single pole application.
Red wire on other side of device from black wire goes to the fan motor.
Green wire is ground.
Set fan on highest speed before connecting red wire to fan, and then do not adjust fan speed using pull chain.
I am unsure what volt-amp-testing will show for power output on either red wire, but certainly it will vary as the switch is adjusted to each speed.
Call 800-223-4185 for Legrand tech support.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 25, 2012 | Electrical Supplies
I JUST PURCHASED THIS AMP AND THERE IS NO WIRING DIGRAM WIYH IT.I NEED TO KNOW HOW TO WIRE THE POWER THERE ARE THREE WIRES RED,BLACK AND BLUE
Red goes to your battery, black gets grounded to the vehicle frame, and the blue wire is the remote turn on wire from the radio. There should be 3 power terminals together. The red wire goes to power or (+), the black wire goes to GRD or (-), and the blue wire goes to remote (usually between both the power and ground terminals). hope this helps
Aug 26, 2011 | Car Audio & Video
No blue power light and doesnt turn all the way on no starting beep gateway gt5220
I would suspect a bad power supply. Before doing anything make sure power is actually getting to the computer. Check the power cord with a volt meter. You should have around 115 volts. If all is well you need to see if the power supply is putting out the correct voltage. Open the PC up and set the multimeter to DC voltage.
  1. Turn off the PC, but do not unplug it. Open the system unit. Set the multimeter to read DC volts in the next range higher than 12 volts. Locate a power connector similar to the hard drive (or CD-ROM drive connector that is unused) and turn on the PC.
  2. You can also unplug a drive connector and use it. Turn on the PC and insert the BLACK probe into the power connector on one of the BLACK wires. Touch the RED probe to the YELLOW wire on the power connector.
  3. The multimeter reading should be +12 volts. Now touch the RED probe to the RED wire and the reading should be +5 volts. If no readings or different readings occurred, you’ll have to replace the power supply. If the readings were correct, you should check the P8 or P9 connectors at the motherboard. These connectors may also be named P4 and P5. To check these connectors, perform the following:
    • Insert the BLACK probe into P8 at one of the BLACK wires. Insert the RED probe into the P8 connector at the RED wire. The reading on the multimeter should be +5 volts.
    • Check the power going to the motherboard connections by inserting the RED probe into P8 at the YELLOW wire and you should get +12 volts. Leave the BLACK wire touching the BLACK wire at the P8 connector. Check the BLUE wire and the reading should be a -12 volts.
    • Now move the BLACK probe to the BLACK wire on the P9 connector. Test the WHITE wire by inserting the RED probe and the reading should be -5 volts. Check the RED wires on the P9 connector and you should get +5 volts on each red wire. You won’t get exactly 5 or 12 volts, but the readings will be very close, such as 5.02 volts.
    • If the Power Supply is a couple of volts off in either direction, such as when the RED wire should be reading -5 volts but it reads -8 volts, or if there are no readings, replace the power supply. Curtorsey: IT Professionals
Mar 09, 2010 | Gateway GT5220 PC Desktop
Aside from the power, ground and speaker wire's there are two wires I can't figure out a red one and a red with black stripe
red/black wire is the dimmer feed, for stereos that support that option, plain red wire is the switched main power positive (works with ignition on) The other power cable is the plain yellow one, which is energized even with the ignition turned off.
Oct 30, 2009 | 2002 Honda Accord
1995 toyota tacoma stereo installation - yellow 12v wire and red power wire - where do I connect these? Original radio was removed by previous owner. Factory connector cut but I have all wire showing. I...
Yellow (module memory) 12v wire needs constant power... any "always on" circuit in your car. Red power wire can be connected to your AUX fuse on your fuse panel.... or to the red power lead that powers your original radio.
Oct 12, 2009 | Pioneer CDJ-1000 CD Player
I am putting in a cd player and i don't understand why it won't get power. i hooked it up staight to battery and it works just don't know which wire is power from the fuse block
1995 Jeep Grand Cherokee Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Red/White
Radio Switched 12V+ Wire: Red/Gray
Radio Ground Wire: Black
Radio Illumination Wire: Blue/Red
Radio Dimmer Wire: Orange
Radio Power Antenna Trigger Wire: Green/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Green
Left Front Speaker Wire (-): Brown/Red
Right Front Speaker Wire (+): Purple/Yellow
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Doors
Left Rear Speaker Wire (+): Brown/Yellow
Left Rear Speaker Wire (-): Brown/Light Blue
Right Rear Speaker Wire (+): Blue/White
Right Rear Speaker Wire (-): Blue/Pink
Oct 01, 2009 | 1995 Jeep Cherokee
I have a plug outlet that's powered by a three
Red wire is the live wire, black wire is the dead wire, white wire is the earth wire.
Now its the black and the red wire we are to play with. take a two wire cable, let the wires be red and black in the new cable, connect the red and the black cables of the new cable to the corresponding red and black wires of the old cable i.e. the new cable is to be connected parallel to the old cable(the connections can be made by ripping the old cable from any point) now connect a switch to the other end of the red wire. attach the terminal of the bulb to:
1) the the other terminal of the switch
2) the other end of the black wire
Sep 02, 2009 | Christmas Lights Etc Santa's Toy Truck
Dual Electronics XDM6350 Car CD/ MP3 Player Logo
61 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
