My machine is showing F08
I removed a blockage from the pump but the machine still shows fault F-08.
  • 41 Answers
Unplug it again for a minute when it shows and it should reset it.
Posted on Feb 16, 2012
I have a hotpoint ultima wf860 it was all fine then all of a sudden its saying the error code f-18 how can I fix this please as I havent enough money for a newone yet. many thanks x
Hi, The link below is a user manual for a hotpoint ultima wf860 and below that are the error codes, I wish you all the best......CHEERS...
file:///C:/Users/Steve/Desktop/4992cbf9-f956-4127-bdab-caa958e02377.pdf <---"NEED TO COPY AND PASTE"
Hotpoint Washer Error CodesF01 - Electronic circuit board fault
F02 - Motor circuit fault
F03 - Temperature sensing fault
F05 - Waste pipe blockage or pump issue
F06 - Door lock fault
F07 - Electronic circuit board fault / heating circuit fault
F08 - Heater fault
F09 - Software fault
F11 - Pump circuit fault
F12 - Electronic control fault
F13 - Dryer temperature sensing fault (washer dryers only)
F15 - Heater control fault (washing machines and washer dryers)
F16 - Drum lock position sensor fault (top loading machines only)
F18 - Internal data error
F19 - Fan motor or heating fault (washer dryers only)
Apr 01, 2016 | Hotpoint Washing Machines
Hotpoint washing machine - WF865 showing F-08 fault
F08: Heater control or NTC (Thermistor) temperature sensor problem.
Jan 23, 2010 | Hotpoint Ultima WF865 Front Load Washer
Machine is showing F-08 and has stopped
Error code F08 means that the heater relay can not be activated, check the following.
1-check all connections to module.
2-check the connections to the heater.
3- check the connections to the pressure switch. It is usually one of these components that is causing the error..
Hope this helps.
Dec 02, 2009 | Hotpoint Aquarius WD640 Front Load...
Wd640 showing f08
Code F08 indicates heater relay stuck.
  1. Check pressure switch connections.
  2. Check heater connections.
  3. Check control connections.
  4. Check and clean pump filter.
Please rate my sol;ution.
Thanks.
Nov 15, 2009 | Hotpoint Aquarius WD640 Front Load...
Screen display reads f-08
  1. Error code F08 indicates heater relay stuck
  2. Check pressure switch connections
  3. Check heater connections
  4. Check module connections.
  5. Check pump and or pump filter for blockage.
Please rate ,my solution.
Thanks.
Nov 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima washing machine is showing a fault
F 05 normally means there is a blockage or a fault with the pressure sensor. The common place for blockage is in the black pipe from the drum to the pump as it has a filter in here and clogs up. remove the pipe and clean the filter out and remove gunk from the pressure sensor on the side of the pipe as well. If that does not fix things the pressure switch could be faulty itself
Sep 13, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error code F-08
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I think you will find the pump comes on because the heater relay is stuck which then gives out the error F08, not the other way round. Check the heater, the pressure switch and the module connections (you will need a multi meter of some description) to check the connections.
Jul 09, 2009 | Washing Machines
Hot point f-08 fault code
F08 means that the heater relay cannot be activated.
Suggest you check heater, and or thermistor (thermostat) for a fault, replace as req'd.
Please rate my solujtion.
Thanks.
May 20, 2009 | Hotpoint Ultima WF860 Front Load Washer
F-08 flashing on screen
F08 fault means your heater relay is stuck.Remove plug and wait 5 mins {MACHINE MAY NEED TO DISCHARGE POWER BOARD} THEN CHECK heater connections and main powerboard connections. heater is located at back of machine and powerboard at back lhs
Mar 20, 2009 | Washing Machines
Fault codes for indesit washing machine, the display shows F-08
F08 means that the heater relay is stuck or cannot be activated for some reason, this has the effect of stopping the water heater from working.
The only thing you can do is to test the heater, and see if it is o/k.,if it is , then you there is not much else you can do, except call an engineer.
Plz rate my solution.
Thanks.
Jan 24, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
