How to reset hp photosmart premium model 310a ink levels
  • 320 Answers
SOURCE: HP Deskjet F4280 Ink Level
when you refill the cardtridge, you can not reset the ink level... because refilling doesn't show the ink levels.. you no need to worry. if ink is there in the carttridge it will print...
Shouldn't worry about it. They are only a rough guide. The only time to worry about it is when the printer stops working and it has told you it's run out of ink! Thank you.......
Posted on Jan 29, 2009
  • 1550 Answers
SOURCE: how do I check the ink levels on my HP Photosmart
First plug the printer to the computer .
Click on the "Start" menu button which is located on bottom left hand corner of your screen.
Click on the control panel icon.
Look for the printer/fax icon in the control panel window. Double click on the printer icon.
Find the icon for your printer in the opened window and right click on the icon. Now click on the "Preferences" option.
Look for the menu box pop up with tabs near the top of the box. Click on the "Services" tab.
Click on "Service this device." You will find the button on the Services menu that you just activated.
Click on the estimated ink level tab and a graphic will appear indicating how much ink is left in the cartridge.
Posted on Mar 01, 2009
aicaxz
  • 511 Answers
SOURCE: I used to refill the ink cartridge of HP Deskjet D1460 by injecting ink. The problem is the level of ink is not resetted to full level, its still very low level. However, the printer prints normally
Close the top left pin at head contactor (1 pin only), with tape. Plug it in head carriage. Unplug it. Close to top rigtht with tape too. Plug the head. Unplug head. Remove all the tape cleanly. Plug again. See ink monitor.
Posted on May 31, 2009
  • 123 Answers
SOURCE: My refilled ink cartridge still displays empty and will not print
The ink cartridge is most likely chipped & you would not be able to reset the ink level. Purchase an original or a good compatible cartridge. Refiling newer cartridges is not a good idea.
Posted on Oct 21, 2009
SOURCE: How to reset the ink level for a HP 60 ink cartridge
I tried blowing through the holes whenever printing quality is not good and it sure did the trick. I do printing a lot. about 40 reams a week and consume just about 300ml of ink..
redilyn agub
Posted on Jan 27, 2010
HP C309a Photo Smart Premium how to reset ink level
I don't think so its resets though printer, now a days counter re setter devices are available, using the device you can resets the counter of cartridge memory..
Feb 03, 2012 | HP Photosmart Premium C309A All-In-One...
Hp photosmart all in one recognizes a full ink cartridge but will not use it
Its showing full but, not printing am I correct?.. Once installed new cartridge printer detects ink level, by chance if cartridge dried up, ink level shows full but it wont print, it might be happened in you case, try to clean the cartridge if not resolved replace the cartridge.Cleaning process you can find out in youtube demos.. do it give life to cartridge..
Sep 27, 2011 | HP Photosmart Premium C309A All-In-One...
Where does it show which ink cartridges (i.e. colour) need to be changed
Go to your computer and open HP Solution Center. On the home page in the upper right (next to the hp) a graph will open displaying estimated ink levels. Click an the graph to get cartridge information.
Dec 30, 2010 | HP Photosmart Premium C309A All-In-One...
Have a hp photosmart premium c309 and have changed the ink cartridge and the black ink is not printing well. All the other colors prink well
HP Photosmart Premium C309 not printing black
Got that problem also, Black would not print but dark grey would be printed ???
What i did and it worked was reset to factory settings, unpluging the printer for ± 25 seconds
holding 3 and # for and other 25 seconds went and after pitting power back on
then re-enterring your setting, all went fine
http://h30434.www3.hp.com/t5/Other-printing-questions/Photosmart-C309-suddenly-stopped-printing-black-ink-any-solution/m-p/495549#M30719
Hopping this will help others
Nov 10, 2010 | Office Equipment & Supplies
How do you reset ink cartridge to show full
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
Sep 29, 2010 | HP Photosmart Premium C309A All-In-One...
Why does my hp c309 Photosmart Premium printer require two black ink cartridges? Can I use just one?
The Photo Black is pigment ink (last much longer than dye ink), while the Black is dye ink. Have alook here: http://www.earthboundlight.com/phototips/dye-pigment-metamerism.html for detail explanation
May 13, 2010 | HP Photosmart Premium C309A All-In-One...
Oct 21, 2009 | HP Photosmart C4180 All-In-One InkJet...
76 people viewed this question
k24674
jasbo
jasbo
