Question about GALAXY Microsystems 63702 Top Freezer Refrigerator
Leaking inside refridgerator
I have a top freezer galaxy refridgerator that has water leaking onto the shelves inside the fridge. what can cause this?
  • 68 Answers
Not shure as to the design of that brand, but it is usually caused from a bloked up drain
Posted on May 02, 2009
My Kenmore coldspot 71182100 which is almost 9 years old just started leaking water from the freezer onto the shelves in the fridge. I just cleaned out the freezer and got the ice out. There was not...
I have a Kenmore Coldspot Model #69207990 and have the same problem. Water from the freezer drains into the refridgerator onto the shelves and sheets of ice form. A repairman pointed out that the tube leading down from the freezer onto the drain pan was frozen. By pouring hot water down the tube, he reopened this drain line. Problem solved for six months and the drain line froze again. My question is how to stop this drain line from freezing up again.
Dec 16, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore Refridgerator leaking water into refridgerator compartment from freezer compartment
You most likely have a clogged drain. When you freezers goes into defrost every 8 to 10 hours. The frost that is melted during the defrost drains from the freezer either down through the fridge or out the back and down. Either way it drains into a pan under the fridge. This tube is either clogged or the drain it's self inside the freezer is. Most of the time I find peas stopping the water from draining from the freezer. When the water can't drain it leaks through the bottom of the freezer into the fresh food section of the fridge. You will need to fix this because it will cause other problems. The water that cant drain from the freezer refreezes and will end up destroying the foam in the bottom of the freezer. Water will also leak onto the controls located in the part between the freezer and fresh food section ruining you controls.
Please rate this solution
Sep 01, 2009 | Kenmore Refrigerators
Smelly Ice and water leaking into top shelf
Does water in door dispenser taste bad? If not, Try arm and hammer fridge deoderizer. It will help to absorb fridge odors which may be clinging to water molecules in ice maker tray. Ice maker tray is open to freezer area.Water is very medium to infiltrate with odors. Try this first
Jul 22, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is leaking on the top shelves in my kenmore refriderator water is leaking on the top shelves in my kenmore I have water leaking onto the top shelf of our Kenmore refrigerator. I believe it goes into...
During the defrost cycle heaters inside the walls of the freezer turn on to melt the frost. The melted frost "water" is supposed to drain into a pan under the fridge where it will evaporate. I think the drain line from the freezer to this pan may be blocked. I'd also check the seal on the freezer door. If it's not sealing well it lets a lot of moisture into the freezer which means more water during the defrost cycle. I'd also recommend checking to make sure the ice maker is not leaking.
May 31, 2009 | Kenmore 64802 Top Freezer Refrigerator
Water leaking inside of refrigerator from freezer
IT SEEMS LIKE YOU HAVE A CLOGGED DRAIN . CHECK YOUR CONDECER COILS BEHIND KICK PLATE .. AFTER THAT YOU CAN UNPLUG FRIDGE FOR 24 HRS WITH DOORS OPEN AND SOULD DEFROST ENOUGH TO CLEAR DRAIN . IF NOT . DEPENDING ON MODEL YOU SOULD BE ABLE TO GET THROUGH DRAIN THROUGH MOST FREEZERS .
Feb 03, 2009 | Kenmore Refrigerators
Refridgerator Leaks
I can't find this model number anywhere and am unfamiliar with the "Evolution" series. However, if it is a top/bottom unit (freezer on top, fridge on bottom) it sounds like you have a clogged drain.
If you pull the back panel off inside of the freezer (where the evaporator is housed) you will see a drain hole, usually in the rear center) that is probably full of ice. If this drain is plugged, it will cause the water to back up into the refrigerator, usually onto the top shelf or under the veggie bins, and possibly onto the floor.
You need to clear it out, and make sure that water flows through it freely, to the pan underneath the unit. The best way to do this is with a hair dryer and a copper wire, but be careful not to melt the inside of the freezer with it. When it's clear, you might want to take a hose and blow through it to make sure there's nothing trapped inside.
Please let me know if you need any further help with this issue.
Mar 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool top freezer leaking into refridgerator.
Sounds like you need to clean the drain again.. if Im understanding right you fixed it once already and lasted 3 weeks.. sound like it plugged up again.. make sure drip pan under evapurator is clean
Sep 24, 2007 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Refrigerator leaking water out
being in the uk, i don't know this appliance specifically so take this as guidence. there are two places where water can come from. at the rear of the fridge there should be a gully at the bottom of the evaporator wall - the part that frosts up. in the middle of this gully is a drain and this is likely blocked. push something flexible down it and check blockage is cleared by pouring a small amount of water in the gully and see it flows freely away. good idea to occasionly pour a small amount of dilute bleach down it now and again to keep it sweet. the other place for water to come from is if some of the contents of the fridge are touching the back wall. when it defrosts the water tends to divert onto the shelves
Apr 02, 2007 | Kenmore 74522 Top Freezer Refrigerator
GALAXY Microsystems 63702 Top Freezer Refrigerator Logo
234 people viewed this question
Top GALAXY Microsystems Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a GALAXY Microsystems Refrigerator Expert? Answer questions, earn points and help others
