Question about Maytag PYE2300AY Electric Dryer
Dryer won't start
Symptoms: 4.5 yr old dryer will not start. Worked perfectly in present location/setup for 1 yr, as recently as yesterday evening. I've checked to be sure that the wiring is connected properly, plugged in properly and that the breaker is not tripped. Door is securly closed; lent filter and exhaust free of debris. Pushing "start" knob fails to start machine.
  • Bill Hahn Aug 21, 2006
    Checked it witha Multimeter Friday evening, and sure enough that was it. Called a local appliance shop, got the part and was doing laundry by saturday morning. Thanks for the help.
  • Anonymous Mar 22, 2014
    dryer will not run when push the start knob firmly, the hosue poer supply circuit is okay, door is closed properly,power supply switch is ok, question- how to replace the time delay fuse?
    President:
  • 878 Answers
/WK, sounds like a thermal fuse. Pop the top of the dryer by pushing on the clips in right and left front top. In the back you are going to see the heater and on the right side about 4 inches down a small thermal fuse. You can ohm it out or jump it to verify that is the problem. If you jump it, don't leave it that way, it's a safety device. Part number for fuse is LA 1053, Catriver..post back.
Posted on Aug 17, 2006
My roper dryer worked fine yesterday. It won't work today
remove back cover then locate the blower housing in the back,its round on this is a thermal fuse appx. 1" X 1/4" with 2 wires from it,this is the thermal fuse test it,if its open on continuity its bad and the dryer wont operate the pat number is FSR# 3392519
May 21, 2012 | Roper REX3614KW Electric Dryer
I've got a 4 yr old Roper electric dryer that won't start up. The belt is fine and the drum spins freely. When you push the button to start it will hum but won't turn the drum. I've got...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 03, 2011 | Roper RGX4634KQ Gas Dryer
I have a GE front loading dryer model # DBVH512EF0WW. It's about 1 1/2 to 2 years old. It has worked perfectly up until this point. When we push the start button, it just beeps twice, but does not...
heatman101
Jun 13, 2011 | GE DCVH515GF Gas Dryer
Dryer worked fine yesterday, started it today and the display turns on, push button to start, it beeps (like it usually does) and nothing happens. No sound from the dryer at all. I thought maybe the belt...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Mar 14, 2011 | Dryers
About two weeks ago, my Kenmore 600 dryer which by the way is only 1 yr old, wasn't heating to dry the clothes, we discovered there was blown fuse, so we changed it and it worked fine until yesterday, it...
could be the thermal fuse it is usualy white about 1 in long located in the rear of the dryer at the bottom around the exaust fan if no continuity it is bad
Jan 06, 2011 | Dryers
I am having trouble with my dryer. It powers on ok and when I hit the start button I hear a "click" but the dryer does not fire up and start. The control panel shows "Cycle;drying"....
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 17, 2010 | Samsung DV218AEW Electric Dryer
Squeaky 4-yr old Frigidaire gas dryer
it's most likely the rear bearing that the drum rides on in the rear of dryer,you'll need the model number located around the door opening to order the right part.
Apr 25, 2010 | Frigidaire Dryers
Dryer won't start
your light should be working regardless of badtimer even, id check the incoming power supply, adn the connection behind the unit itself
Apr 12, 2008 | Maytag Performa PAV2200
Maytag PYE2300AY Electric Dryer Logo
130 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
