Question about Eureka Whirlwind 4383 Upright Vacuum
Filter replacement I have a used 4383 whirlwind upright but no manual. I want to replace the filters. I was told there are three different ones. Is that true and where can I gd=et them?
    President:
  • 1,901 Answers
Yes, it's true.
Here is a link to the manual:
http://www.eureka.com/service/manuals/70239B.pdf
Click on the link and then save it to your computer for future reference.
The filters are described on pages 15-16.
You can find them at any good appliance store, or google "vacuum filters". You'll get lots of options.
You can always go to www.eureka.com and click Customer Service.
If this solution has been helpful please take a moment to rate it. Thank you.
Posted on Oct 25, 2008
When I vacuum the dirt and trash come flying out the back of the vacuum, what can I do to fix this?
The filter behind the unit is out of alignment or damaged.
so remove and clean the collected dirt, replace the filter, look for damage here to make the sucked dirt fly over.
Sep 14, 2010 | Eureka Whirlwind 4388 Bagless Upright...
Is it worth trying to fix the end of the power cord that goes in the wall outlet? One of the metal prongs broke.
You can buy just the end at the local hardware store. This is the best way to fix it. It is also the safest way to do it and not risk electric shock.
Jun 26, 2010 | Eureka Whirlwind 4383 Upright Vacuum
How do the filters go back in my Eureka Whirlwind Lite 12 amp vaccum?
There are two filters for the this vacuum. The first goes behind the dump cup and there is a filter pack for that below.
Filter Value Pack. Eureka Part #60951A - Free Shipping
The second filter goes in the back of the machine the part you need is below:
Generic Eureka HEPA Filter Designed to Fit Style HF-5, Eureka Part # 61830 - Free Shipping
Apr 13, 2010 | Eureka Whirlwind 4388 Bagless Upright...
Beater bar is not turning... but vacuum is sucking fine.
Hello. Usually when the beater bar is not turning it is due to the belt breaking. The fix is to get a new belt and install it. Be sure to use a Eureka belt to get the best results.
Kindly rate my answer as helpful. Thanks. Joe
Feb 09, 2010 | Eureka Whirlwind 4383 Upright Vacuum
Where does the flat 'pre-motor' filter go. Mine
Although the manual says this model shouldn't have one, this one does. The flat perf metal plate goes at the bottom on the filter chamber. The top DOES have to be removed to put it in correctly and that was the problem. The plate had been removed during a prior dis-assembly and I'd forgotten exactly where it came from.
The filter itself fits over the perf metal plate, it's to keep birds and asphalt out of the blower 8-)
Now that the motor bearing are replaced ($5 for the bearings, $60 for a set of Torx and a bearing puller) later, it sounds much better. Of course it took awhile to find the bearing puller that will *just* slip under the bearing on teh short end. That armature is a bit close.
Tanks, Dave
Jan 30, 2010 | Eureka WhirlWind 4381 Upright Vacuum
Suction is very poor
I would start with replacing the back hepa filter, the yellow filter on the bagless tank and the white filter beneath the intake housing. If that does not solve your problem, you have a clog in the system
Aug 26, 2009 | Eureka Whirlwind 4388 Bagless Upright...
My Eureka Lite speed whirlwind has a bad odor when it runs.
It is either the filter or on the roller or belt.
  1. Eureka Parts Storewww.Eurekapartstore.com Unbeatable prices on Eureka Parts Largest site for Eureka parts.
  2. Eureka Partswww.ThinkVacuums.com/Eureka Eureka Central Vacuum Accessories Find Hoses, Tools, Nozzles & More! Google Checkout
  3. Eureka Part Storewww.vacuums24x7.com/Eureka-Parts Bags, Belts, Filters, Repair Parts. Complete Selection Eureka Parts.
Jul 06, 2009 | Eureka WhirlWind Litespeed 5844 Upright...
Eureka whirlwinde litespeed vacuum - model 5841
very simple under all three screws in the front (two on sides and one in back) once open--you can take off that panel...take brush out...take old belt out...put new belt on..around brush..place both inside...and make sure belt is around that little pole thing towards the back close panel, replace screws
Mar 22, 2008 | Eureka WhirlWind Litespeed 5844 Upright...
Install filaters
not sure which filters you have ... i will assume you have a replacement cassette micron filter -- goes in the compartment on the front of the vacuum just lift up the handle on the compartment and swing upwards it will pull out like one large piece the filter is on the back. the cassette door will be hinged at the bottom so just pull firmly from the top and snap back in place after replacing the filter. Replacement HEPA filter cartridge --- attaches to rear of Eureka upright vacuum cleaners. Here is a pictorial or changing the filters : http://www.eureka.com/servlet/FindOwnersGuide
Mar 08, 2008 | Eureka WhirlWind 4381 Upright Vacuum
Eureka Whirlwind 4383 Upright Vacuum Logo
239 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
