Question about Locks & Locksmithing
Manuel for 1000 unican **** to change code - Locks & Locksmithing
  • 963 Answers
You will find a link to download the manual for your model on this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
Hover your mouse over "PDF" under the "TIPS" column and the two choices of "Changing the Code/Combination" or "How to Reset a Lost or Unknown Combination" will appear--move your mouse over the appropriate one and click to download the info.
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader, if the file will not display for you.
Posted on Feb 22, 2012
5 Suggested Answers
  • 760 Answers
SOURCE: How do you change the handing on a unican 1000
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13&obj=1000
you can download a manual here. I assume you mean to change from left hand door to right hand door? The manual will describe how to do that.
Posted on Jul 13, 2010
sonicboomele
  • 1557 Answers
SOURCE: How do I change the combination on my Unican 1000
The door must be open.
On models with the passage feature, make sure the passage feature is disengaged: turn knob or key should be in vertical position (A) (see figure 1).
1. Insert the DF-59 control key (B) into the combination change plug
assembly (
C) and unscrew the cylinder by turning the key
c
ounterclockwise. Remove the combination change plug to gain access to the combination change sleeve (see figure 1).
2. Turn the outside knob/lever once clockwise (all the way, until it stops) then release. The latch should not retract (see figure 4).
3. Enter the existing combination. On new installations, use the factory- set combination: depress 2 and 4 simultaneously, (release), then 3
(r
elease). You should feel a slight click as each button is depressed.
4. Insert the spanner wrench as shown in figure 2 to engage the combina- tion change sleeve (A). Gently turn the spanner wrench clockwise to the stop position (a slight click should be felt), then turn the spanner wrench counter-clockwise to the stop position (A) (see figure 3). Remove the spanner wrench.
5. Turn the outside knob/lever once clockwise all the way until it stops, then release. The latch should not retract (see figure 4).
6. Choose your new combination, write it down, then enter the new combination-depress buttons carefully (a slight click should be felt as each button is depressed).
Note: You can use one button or all five for a combination, but each button can only be used once. You can depress two or more buttons simultaneously as a step in the combination.
7. Turn the outside knob/lever clockwise once, all the way, until it stops, hold in position and make sure the latch is retracted (see figure 5).
R
elease the knob/lever.
Note: If your lock is opening on every turn of the knob or lever, except upon entering a code, this may be a ZERO CODE. Before attempting to remove the lock from the door, refer to the troubleshooting procedures outlined at bottom of this document for a zero code symptom/solution.
1000/L1000 Series FAQ
hope this helps
and here is the link to the change code web site
http://www.locksonline.co.uk/files/pdf/Simplex_1000_CodeChange.pdf
good luck
please take the time to rank my advice
merry christmas
Posted on Dec 07, 2010
  • 963 Answers
SOURCE: Need to know how to reprogram the code on a
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF
SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE
DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE
O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE
THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS.
REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a
maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND
CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH
SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59
CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the
Simplex mechanical pushbutton locks:
aspx?id=13
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Good Luck!
Posted on Mar 06, 2011
  • 963 Answers
SOURCE: how do I change the combination to a Unican 1000
PROCEDURES TO CHANGE THE COMBINATION OF SIMPLEX 1000 SERIES CIPHER LOCKS
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Do not no the code to my unican 5 # lock
Aug 01, 2012 | Simplex Kaba Ilco Unican 1000 keyless...
I work in care home where we use unican 7000 series to lock our office. One of our service users know the code so I tried to find instructions of how to change the code.
This page will show you a grid; go across from the "7000" to the rightmost column "TIPS" and click on PDF there. The download for changing the code will appear.
This is a PDF file, requiring Adobe Reader is installed on your computer to open. There is a link on the same page to download Adobe reader if the file will not display for you.
Aug 04, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
I am trying to change the code on my 1000 lock but do not know what a spanner wrench looks like? i just started this job and dont seem to have all the things i need to change the code.
Jan 28, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
I am installing a 1000 series and the factory code works fine , but when I Go to change the code step by step in the manual nothing happens. When I use the spanner wrench to clear the code it don't make...
If you have correctly followed the instructions and it has not accepted the code change, you probably have a bad combination chamber. Take it to a locksmith for diagnosis and repair.
Dec 18, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Bought a house with a Unican 7000 series keyless lock on it. I have the current code but want to change it. Can someone tell me how I can change the code?
Yow will find a link to download the manual for your model on this page:
Oct 30, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Jul 13, 2010 | Simplex Kaba Ilco Unican LP1000...
Lost code for unican 1000 i have lock of but dont
Click below to get to the manual you need. when you get there find your model number and slide across the page till you get to the PDF under the Manuals column. Click again and either save or open the file.
Hope this Helps,
RSMITH972278
P.S. PLEASE RATE ME
Sep 29, 2009 | Locks & Locksmithing
Lost code for keyless unican lock
I just performed this on my lock and it's quite simple. The instructions are in the attached manual.
http://www.kaba-ilco.com/access_control/access_download.aspx?File=simplex_1000_installation_instructions_d8_pkg_2280.pdf&Attachment=True
Cheers.
May 16, 2009 | Simplex Kaba Ilco Unican 1000 keyless...
Bought house from bank and trying to retrive lock combination
I'm trying to remove a unican lock from my door but I can't see how to get the handle off. any suggestions?
Nov 12, 2008 | Simplex Kaba Ilco Unican 1000 keyless...
Locks & Locksmithing Logo
66 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
