Question about Maxent MX-42HPT51 42 in. Plasma TV
Troubleshooting for maxent mx-42hpt51
Tv comes on with only a blue screen...no picture or sound when hooked up to cable
  • Maxent Master
  • 1,205 Answers
Are you sure that the scart cables are in the right place at both ends.
hope thus works for you
kolla
Posted on Feb 16, 2012
    Novelist:
  • 181 Answers
Hello!
Blue screen(bright blue) indicates an absence of signal. If you have "on screen" display characters: menu, channel ##, volume bar, etc, your set might be configured for digital antenna settings, or DTV, "air" mode. Then, you won't be able to get cable channels through. If your "blue screen" is dim and there is no any characters, then your Y-sustain module is bad. Especially, if you have encountered loud "pop" shortly before "blue screen" appeared. Then, it's a major repair with board(s?) replacement. If you can handle that, get back to me in a next session. I will guide yourself "how to".
Thanks,
Alex.
5 Suggested Answers
  • 71 Answers
SOURCE: Maxent MX-26X3
More than probably is the LCD control board, but this one is coming with the LCD panel. Could be the main PCB too and I suggest you to call a tech for a exact diagnosys because the parts implied are very expansive.
Posted on Jan 26, 2008
pilot210
  • 39 Answers
SOURCE: Picture problem with Maxent Plasma MX-42HPM20
Very common problem on these sets caused by bad surface mount caps. Check on ebay for a repair kit it's the only place I know where one exists.
Posted on May 18, 2009
SOURCE: Maxent MX-42VM10 42 I have sound but no
i can get sound but no pic can u help 42vm
Posted on Aug 23, 2009
hulk917
  • 247 Answers
SOURCE: I have a Maxent Product
Of course you should have not issues, you can either go hdmi or component that particular model has 1080 i technology so you should be fine.
Posted on May 30, 2011
How do I get a user's guide?
http://static.highspeedbackbone.net/pdf/Maxent-MX-42HPT51-Manual.pdf
May 13, 2015 | Maxent MX-42HPT51 42 in. Plasma TV
Screen goes blue and reads no support
I would if not tried remove the set AND ANY box inline with it from power for several minutes and then power back all units=it sounds like it does not like whatever is hooked up for signal.
Dec 12, 2012 | Maxent MX-42HPT51 42 in. Plasma TV
Tv is hooked to cable but still gets no picture or sound...only a blank blue screen
Verify that the source is set to "Tuner", "Cable", "Antenna" or "TV". (I don't know which of these names Maxent uses, and the site formerly used for their downloads is now a generic search page.) Make sure the TV format is correct for your region (in the US it should be ATSC, sometimes called HDTV).
If you have a portable TV, bring it over and connect the cable to it to verify that the cable connection is good.
Check the other inputs to verify that the internal video switch is functioning properly. If you don't find a problem with any of these tests, you likely have a tuner problem. Note: do not use a tool to tighten the cable on the tuner connection. I've seen a lot of tuners broken that way, including some with the circuit board ripped apart inside. Use your fingers, and just make the nut snug enough to hold the cable in place and secure the ground connection made through the nut.
Feb 16, 2012 | Maxent MX-42HPT51 42 in. Plasma TV
The picture doesn't fill the screen.
Well this may indeed just be a setting, you need to look in your manual, with regards to Aspect Ratios and Screen Sizing. There are screen adjustments that can be made to make the image fill the screen. However the actual way in which it is done is individual to each unit.
Jul 05, 2011 | Maxent MX-42HPT51 42 in. Plasma TV
I have a Maxent Product Name mx-42HPT51 Model Number P4202YD02 Will it support a Blue Ray DVD player?
May 30, 2011 | Maxent MX-42HPT51 42 in. Plasma TV
Looking for a manual to download for Maxent TV Model #P4202YD02 Product # MX-42HPT52
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 19, 2011 | Maxent MX-42HPT51 42 in. Plasma TV
Turn tv on green light on but no picture or sound
Check the cables, make sure that the cables are properly plugged in. This means that your TV is not receiving any signal.
Nov 08, 2009 | Maxent MX-42HPT51 42 in. Plasma TV
Need code for my maxent tv
Maxent is sometimes the same as SAMPO. Try 746...
Mar 30, 2009 | Maxent MX-42V1 42 in. Plasma Television
Feb 23, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Maxent MX-42HPT51 42 in. Plasma TV Logo
240 people viewed this question
Top Maxent Televison & Video Experts
Michael Harrier
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
