Question about Symbol Cobra LS 1902T Handheld
Symbol LS1902T need enter after scan barcode
I am scanning barcodes and I want it to go down to the next line after the scan. Like hiting ENTER on your keyboard.
Thanks for your help.
I have the manual fot it.
Please email the souution to
The scanner needs to be programmed to hit the enter for you. Motorola Solutions article ADC-00316 has a link to the barcodes you need to scan: Scan Options, Data Suffix and Enter. This link should take you there: portal motorolasolutions com
Aug 11, 2014 | Symbol LS 4278 Barcode Scanner
Symbol ls1902t-1000 scans extra characters when scanning a barcode
Download the quick start guide from and reset to default by scanning the code from the PDF manual. This could either be a programmed ASCII prefix, or an error in the codes you are scanning. Have you seen the same problem with more than one scanner?
Oct 29, 2012 | Symbol LS1902T-1000 Handheld Laser Barcode...
After scanning it is automatically not going to the next line
Symbol barcode scanners by default do not add a return after a scan. You need to program the scanner to add a suffix.
Download the manual from Motorola/Symbol here
-Print Pages 224 and 225
-Scan the Barcode "Scan Options"
-Scan the Barcode " "
-Scan the Barcode "Enter"
Scan a barcode
Feb 26, 2011 | Symbol LS2208 Handheld
Add carraiage return after scanning
The Motorola support site has an FAQ (ADC-01589) that contains the barcodes to get the LS1902 to add a CRLF after the barcode: Scan Options, Data Suffix, Enter. If the article is no longer there just download the LS1902 or LS1900 series Product Reference Guide to print the barcodes from there. They are usually in the Miscellaneous section.
Jan 28, 2011 | Symbol LS1902T Handheld
Barcode line enter problem
This is a custom setting. You will find on the user manual (and also at the bottom of the Quick Start guide) a special barcode that, when scanned, toggles between "CR after barcode" and "No CR after barcode".
Mar 15, 2010 | Symbol DS6707 Wired Barcode Scanner
I want to my m2004 to enter barcode scan after each scan automati
Print Adobe pages 128 and 129 of 302 of the M2000 Series Product Reference Guide and scan the "Scan Options" "Data Suffix" and "Enter" barcodes. The scanner will give two beeps after the first barcode, two beeps after the second and a warble after the third programming (Enter) barcode.
The manual can be downloaded from this link:
Jul 12, 2009 | Symbol M2004 Barcode Scanner
Need instructions
it depends on the configuration of your host and scanner. Usually there it works like this:
Connect the scanner to USB or per Keyboard Wedge Select the correct language set for your Scanner Try to scan your barcode if this will not work - enable the barcode you need to scan with the programming barcode from Manual
The Barcodes needed to set up the device are listed in the Reference Guide at
Jan 14, 2008 | Symbol LS1902T Handheld
Enter function
Hi Lee,
It can be done by programming the scanning the 'Send Enter Key' barcode twice, from the owners manual.
Scan the barcodes -
Send All Data, Send Enter Key, Send Enter Key, Save
Oct 17, 2007 | Symbol LS 4278 Barcode Scanner
Symbol Cobra LS 1902T Handheld Logo
806 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
