How to set up nad t760 receiver to 42inch lcd tv what leads and where they go receiver has no rdmi
  • 1,205 Answers
Sorry I am not sure what you mean- Icelandic is my first language, please explain.
all the best
kolla
Posted on Feb 16, 2012
I have a Nad T760 receiver/amp (not sure what the difference is). The remote cannot function. Is there a universal remote that I can buy? As this is quite an old piece of kit not sure if there is a
some remotes can be programmed by entering a manufacturers code using the numeric keys. i use a Sony RM-VLZ620 remote. it lists NAD as a supported receiver.
P.S. - a receiver is an amplifier with a built in radio tuner.
Nov 15, 2014 | NAD T760
NAD T760 FM stereo not working
Hello
There are three fuses with your NAD surround receiver.
Reference No Part Number Description
M751*AH 5120-0200-0 Fuse 5A 125V Time Lag 5x20 MM MITI/UL/CSA
M754*AH 5120-0052-0 Fuse 1.6A 250V Time Lag 5x20 MM UL/CSA
M752*C 5120-0024-0 Fuse 3.15A 250V Time Lag 5x20 MM SEMKO/VDE
Check them first and inform me which one has blown out. I'll give you detais after that. OK.
Oct 26, 2011 | NAD T760
The t760 is cannot switch on like normal, the LED is keep blinking without displaying any on the panel Any way to reset the protection.
Short of resollving the problem, no.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Apr 03, 2011 | NAD T760
The unit will not stay on
I got similar issue and managed to fix it with excellent tech support from NAD. Flashing LED means system goes in to protective mode. Most probable reason is presence of DC voltage on amplifier out puts. In my case it was both surround amps. It had faulty resistor and a dry jpint at power line
Dec 16, 2009 | NAD T760
No signal from sub connected to NAD T760 in test mode.
Try using front pre out to the sub from the receiver. the crossover is in the sub anyway. If this works change your settings on the receiver and test again. If sub is still inop, could be an internal issue with the sub amp. Does your sub amp have an on/auto/off switch or light? check that as well. Hope this helps, if you need further assistance, send a reply and I'll help some more
May 24, 2009 | NAD T760
NAD T760 remote control
You could buy a universal remote control and try the following NAD audio remote codes to program it with:
NAD
575 773 975
I read somewhere else that the 'Supplied Code for NAD receivers' was 033, but cannot confirm this. Try the first 3 first.
Universal remotes tend to be pretty cheap, certainly cheaper than buying one from NAD.
Good Luck
Chris (ziraffa)
Dec 20, 2008 | NAD T760
NAD T760
You should connect the RCA connectors from your turntable into the phono input of the preamp. Also, make sure you have the grounding wire from the TT connected to the grounding on the preamp (if you do not have a grounding point, then just connect it to one of the screws on the preamp). Then connect the output from the preamp to either the Tape or the CD points on the T760. On the front panel press tape monitor and you're done.
Check and let me know how it goes. My set up's working fine except for clarity, which still needs to be perfected. I'm using a normal step-up phono stage.
Regs/ Avinash
Mar 29, 2008 | NAD T760
DTS - no sub output
Did you go into the sub-menu to see if the NAD sub output is turned on?
Apr 14, 2007 | NAD T760
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Electro Med Services...
