Question about Music
I need a manual for a digitech rp7 valve guitar audio processor
  • 1137 Answers
SOURCE: digitech rp6
Try contacting their service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply PS0912 which should still be available. Hope this helps.
Posted on May 26, 2009
  • 5603 Answers
SOURCE: Digitech RP3 Guitar signal processor only lights up.
Check that connectors are seated AND the input and output are correct.
Sometimes1/4 inch plugs are not seated correctely. The power adapter plugs are notorious for not making contact.
Posted on Oct 28, 2009
  • 1137 Answers
SOURCE: I NEED TAN ELECTRONIC SCHEMATIC
Here is a link to the manual:ftp://ftp.digitech.com/pub/PDFs/Manuals/RP1000/RP1000%20manual%2018-0597-A.pdf It is highly unlikely that you will find a schematic unless you know a service tech for a music store that deals Digitech. Also you will need some specialized tools. Here is their contact info:http://www.digitech.com/dealers/service_lookup.php If you are a tech you can always contact them.
Posted on Apr 09, 2010
  • 3 Answers
SOURCE: It lights up but doesnt put out sound
A friend of mine had the exact same problem. In his case the pedal is only good for hammering nails now. If it still has it warranty I'd say look into that, if not you've got nothing to lose. Open it up, look for unattached wires. Also, try using a battery instead of an AC adapter..
Posted on Aug 11, 2010
criss_michae
  • 63 Answers
SOURCE: The foot pedal (not the
All DigiTech expression pedals use an optical system instead of potentiometers.
Either the light is broke, or the filter.
The filter protrudes from the bottom of the pedal, and is darker at the top and gradually fades to clear at the bottom. If this breaks off, then there's nothing to limit the amount of light to the optical system.
If it is the light, then you'll have to have it serviced by someone qualified to work on it. Your local music shop should be able to help you out.
Hope that helps!
Posted on Feb 12, 2011
Hi I have a Digitech RP 300 Modeling Guitar Processor that lights up and will play the metronome tik but will not output the guitar, the guitar input is dead or semes to be. can any one help. thanks...
The metronome is built in software, but it proves that your output is working fine. That's good.
Try changing your patch cable from guitar>pedal. if that doesn't fix it, grab a screwdriver.
Open the pedal and check the input port - is there any bent pieces or blockages preventing the cable from contacting what it needs to? Is the solder broken, cracked, or missing? Are both contact points firm and in place?
May 11, 2011 | Music
I have RP7.WHILE I'M PLAYING THE VOLUME WILL TURN OFF EVERYTHING LOOKS AS IF IT'S WORKING .TURN POWER OFF AND ON REAL QUICK IT WORKS.WHAT IS CAUSING THIS .
Check for intermittent connections of cables. The vibration of turning it off and on MAY be fixing a poor connection. Verify the problem exists using new cables. Intermittent problems are tricky to find so we have to do tests to narrow the possibilities.
Apr 25, 2011 | Roland Boss Gt-10 Guitar Effects Processor...
I got a pretty good deal on a digitech RP7. The only problem is that its missing one of the four switch covers (pitch). can you tell me where I coul find one? thanks,
Such a special part will require going to Digitech, support, and parts. The part should be fairly inexpensive.
Jan 04, 2011 | Music
Hiwhat is the best way to connect my DigiTech RP10 to my Marshall MA100H Guitar Amplifier
Read your manuals for both pieces of gear carefully first. You only have one amp so you won't be able to take advantage of all the FX on the Digitech as a lot of them are designed for stereo. The Digitech manual shows guitar into the Digitech and output from the Digitech into input of any guitar amp. Since you have a Marshall and can already get some great sounds by running your guitar straight into the Marshalls input, you would probably be better off using your Digitech in the FX loop. Run a guitar cord out of the send on the loop into the input of the Digitech and a guitar cord out of the left / mono output jack on the Digitech into the effects return jack on the Marshall. Start out with the effects level on the Marshall all the way down. Do the same with the Digitech with both the input and output levels. (Read the manual carefully) I think the choice of the Digitech isn't that great because it is already trying to reproduce a lot of what you can already get with just your Marshall but with a little experimentation and some careful adjustments you should be able to add to the sound of the Marshall. Hope this helps.
Oct 23, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
I need instrution manual for a digitec rp100a guitar effect
The manual you are looking for can be found right here:
ftp://ftp.digitech.com/pub/PDFs/Manuals/RP100A%20Manual%2018-1867V-A.pdf
Would you kindly rate my answer please if this has helped resolve the problem - thanks :)
Oct 22, 2010 | DIGITECH Guitar Effects Model No Ddm
Apr 07, 2010 | Music
Oct 26, 2009 | Digi-Tech Digitech X-Series Synth Wah...
Oct 26, 2009 | Music
Hi! Im looking for the service manual or schematic for the Digitech Valve Fx guitar eff.proc. The unit can turn on, and in bypass mode has a clear sound, but in normal operation has terrybly noisy, It...
hello,
can be too late but one never knows:
http://mesnotices.fr/314159.php?k=b7e42b97c5e87d24451de2516f66eef9&ID=18334&q=DIGITECH%20VALVEFX
you must simply answer the questions to be able to download.
Philippe to France
Jun 10, 2009 | Digi-Tech Digitech Vocalist Live 4...
Music Logo
190 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
