Question about Porter Cable C2002 150 Psi 6 Gal Compressor
Replacing manifold on porter cable compressor
How do I get the actual compressor housing out of the way so I can remove and replace the manifold?
  • mesoclutch
    mesoclutch Jun 27, 2012
    Paul I am having the same problem. Did you figure out how to get the manifold on?
  • 7 Answers
SOURCE: My porter cable compressor isn't shutting off
Dear JG,
The probably is probably the pressure regulator switch. It's the box the 110 vac wires come from the outlet and go into. Reset the switch or replace it. Note! overfilling an air pressure tank is extremely Dangerous. The tank, fittings, compressor head and or related parts may explode resulting in property damage as well as serious and potentially fatal personal injury.
Good luck,
shag79
Posted on Nov 24, 2008
  • 1388 Answers
SOURCE: Crank bearing cap blew out on Porter cable air compressor
Your compressor is sold under various part #s depending on brand name. The link below is the breakdown for ac-0171.
http://www.devilbissparts.com/OilLubeStat%20PDF%20files/ac-0171.pdf. You will notice that there is no vent to release internal pressure. Most brands have a filler/dipstick which is also a vent. As the compressor wears there is a normal increase in crank pressure caused by pressure passing thru the rings. I have seen home made vents installed on the bearing cap. If you are creative you can make one yourself using the same cap or a metal cap (axel bearing cap) that fits the opening. A crankcase vent is a very simple device. A small hole to atmosphere with a bit of oil resistant foam behind to prevent oil from being blown out the hole. Works best when there is a vent tube about a couple of inches long to catch any oil and allowing it to run back down into crank. Remember that there is oil sloshing around inside the pump. Examine several brands of compressors for vent and try to recreate that on yours. One thing in common about vents is that they are usually located pretty high up above the crankshaft. You could also try lowering the cut-out pressure on your compressor to reduce back pressure. Good Luck on your repair.
Posted on Apr 23, 2009
webxcreation
  • 4 Answers
SOURCE: Porter cable pancake unit blows air after shut off.
tap on the check valve with a metal object. Its sticking open. The check valve is the brass fitting on top of the tank. When the valve sticks open it emits air from the area of the engine. If that doesn't work (which I would be surprised it doesn't), you'll need to purchase a new check valve. Good Luck!
Posted on Jul 02, 2009
atthings
  • 59 Answers
SOURCE: porter cable stand-up air compressor starts but air won't fill up
Might be the unloader valve is stuck. if so there will be hissing noise from switch assembly and you may have to get a new one.
Posted on Jun 06, 2010
mxc2
  • 146 Answers
SOURCE: The drain plug on my Porter Cable pancake
Yes...the drain valve on the bottom of the tank is just a standard 1/4 Drain Pedcock that you can purchase at most hardware store.
You can also find these in the hardware section of Lowes or Home Depot where they sell the Air Compressors.
Posted on Oct 24, 2010
Porter cable pancake compressor will not shut off replaced manifold, still the same.
I would look at the pressure switch which shuts the electric off when the air pressure reaches its limit also check all wires going to and from this switch. Best checked with a multi-meter.
Feb 07, 2015 | Porter Cable Air Tools & Compressors
Can i use existing drain plug for porter-cable pancake air compressor?
Yes use pipe thread seal. The center is turned to open and close no need to remove plug. If is frozen replace.
Feb 16, 2018 | Porter Cable C2002 150 Psi 6 Gal...
My Porter Cable pancake outlet regulator doesn't seem to work.
If your quick coupler is not jammed up, (remove & test) and assuming you are pulling the regulator knob out to adjust the pressure and it is not stripped, you will need a new manifold kit.
There are about 6 versions of this unit so you will need model and type to get the correct part. There are no individual regulator parts available for this unit.
Jul 02, 2013 | Porter Cable C2002 150 Psi 6 Gal...
How do I remove the motor housing on a C2002 compressor to make room to spin and remove the manifold
The housing has slots for the four legs on the tank to hold on to. At one (sometimes two) of those legs there is a small screw that keeps the housing from freely falling off the tank. If you remove the screw(s) the housing will slide easily to one side and come off the tank. Don't bend the four tabs as they could break off when you bend them back and will weaken the tank where they are attached to it.
Jun 25, 2012 | Porter Cable C2002 150 Psi 6 Gal...
The manifold which holds the Air Hoses and control valve and gauge is broken and I need a new one ,dont know the part number
We repair lots of compressors with broken manifolds. Most compressors now use a manifold with a built in pressure regulator. We are not able to find exact matches so we use a manifold from porter cable or make one out of pipe fittings. If your compressor was made in china, most likely the thread and tubing sizes are almost impossible to match. To use porter cable parts, go to dewalt service center or to porter cable dealer and find close match then use that model number for ordering your part. Check closely that parts/thread/fittings will work.
Jan 29, 2011 | Hdc Homer Hdc 2 Hp, 4 Gallon Pancake Air...
The regulator knob is broke. Where can I get a replacement? Replacement parts diagrams do not show the knob as replacement part.
You can't buy the regulator knob as a seperate part, you have to buy the entire manifold; Porter Cable part number N003001. Shop around on parts sites as these cost around $70 plus any shipping and handling. Depending on how often you have to change the regulated pressure output it may not be worth replacing.
Jan 20, 2011 | Porter Cable C2002 150 Psi 6 Gal...
Need a rod for an oil run porter cable air compressor model c3151
Ok, the post shows 2 model numbers, so I will provide links for both. Be sure to only pay attention to the model number you actually have.
For a model C3151, an oilless compressor, the only way to get the connecting rod is by buying a piston kit, there is no individual replacement. KK-4835 is the part number and it runs about 50.00.
It can be purchased here.
http://www.ereplacementparts.com/piston-cylinder-and-ring-replacement-kit-p-58708.html
Now if you have a C3551, an oiled compressor, the entire Eccentric Rod Assembly will have to be replaced. The part number is Z-D22207 and it runs about 100.00.
http://www.ereplacementparts.com/assembly-conrod-eccentri-p-62701.html
I hope this helps.
Dec 04, 2010 | Porter Cable 4 5 Gallons 150PSI Job Boss...
My porter cable c2002 150 psi gal compressor the pressure regulator is always set at 0 and no air at outlets, but the tank is fill of air 150psi. what could be the problem
According to Porter-Cable (Delta) themselves, they had lots of bad regulators on these compressors. I'm waiting for one myself. Same issue
Jul 10, 2010 | Porter Cable C2002 150 Psi 6 Gal...
How can i install the air manifold?
You might have to remove the motor. I had a devil of a time with the same problem with my Craftsman.
There are two screws on the bottom that allow removal - I guess you found those already.
Good luck
Thanks for your quesiton at FixYa.com
Jan 03, 2010 | Porter Cable 18 - Gauge Brad Nailer and...
Porter Cable C2002 150 Psi 6 Gal Compressor Logo
669 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
