Question about Jensen Car Audio & Video
HI,have modle vm19311ts,,,,need to know what wires to hook to power to test,,,was a 2nd hand unit for sale,,,thank,s for any help
  • 1,586 Answers
You'll want to power the red (switched ignition - the one that turns the system off when the key is off) and the yellow (constant 12V - used to maintain memory settings and tone settings when the car is off). Ground the black wire. This will allow you to power up the unit, although with no speakers hooked up you won't hear whether the internal amplifier works.
Posted on Oct 25, 2008
I need a new lid
Without knowing make of blender can't help much but short term get a plastic bowl to hold ove top of blender, long term either look in 2nd hand shops or yard sales and hope to find the same model for sale cheap.
Jan 03, 2016 | Blenders
220 stove has nothing hooked up to the neutral
TURN OFF POWER TO THE STOVE OR UNPLUG IT IMMEDIATELY BEFORE TOUCHING **ANYTHING**. I need the make/model of your unit to help you accurately. HOWEVER, the first thing you need to do is(and this applies if I'm interpreting you correctly)replace the power cord--it will be connected to the terminal block--on the vast majority of ovens, you have a left-hand terminal, generally known as L1(a power wire), a center terminal(*normally* the neutral connection), and then the right-hand terminal, generally known as L2(2nd hot supply wire). Take a picture of the AC outlet so you can purchase the correct power cable for your stove. Also, take a picture of the terminal block in the rear of the stove just to make sure. I'm assuming that the wires are all connected in the stove but the neutral wire is either broken or missing from the power cord. Due to how most ovens operate, THIS IS A VERY DANGEROUS CONDITION. When the unit is plugged in, even though the oven is off, there is still 120v applied to the heating elements. When you turn on the oven, instead of being connected to a ground, the other side of the heating elements are simply connected to 120v from the other side of the panel, adding up to 240v and the elements heat up. I hope this helps you!
Aug 13, 2015 | Kitchen Ranges
How to connect hand brake cable on meos MC701B
if you can get to the hand brake, there is usually 1 wire coming off of it at the base, you will want to test it to make sure it is sending the ground pulse, just splice it into that wire. If you want to save yourself the headache, just put a switch to a ground (-) and hook that up to the handbrake wire (coming from the unit). It will do the exact same thing, but with a lot less work.
Apr 29, 2010 | Car Audio & Video
Turning on a Liteon power supply without being hooked up to compu
On the main plug there are several black wires(ground), and one green wire. Jumper any black wire to the green wire and there you go.
Dec 13, 2009 | Computers & Internet
In need of a Hobart N50 spiral hook
Hi. Goto globeequipment.com they have an ED hook for your N50.
If this solution has assisted you, please rate it. ricardok45
Apr 06, 2009 | Hobart N50 Stand Mixer
Power unit on test for Kenwood kgc 7043
should not need the head unit.open up unit and start testing continuity along wire an board.possible break in connection.
Feb 24, 2009 | Kenwood Car Audio & Video
No light at all
A couple of things you can try:
1. check for B+12 on the 1st and 2nd terminals of the Power Connector using a voltmeter;
2. temporarily put a jumper on the 1st & 2nd terminal of the Power Connector;
3. the usual, check for loose connection, fuses, wires, connectors.
if there is +12 on both terminal and amp is still dead, then it is internal;
if there is +12 on terminal 2 but none on 1, then it is the wiring from the head unit or the trigger of the head unit that is the issue;
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 14, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
How to install?What wires hook up to where?
Hi, Re the power wires - black is ground (or - of battery), red goes to the + terminal of the battery and the yellow would go to the Acc in the ignition switch of a car. If you are hooking it up on a spare "battery", you have to twist together the red and yellow and connect both to the + terminal. Good luck and kind regards.
Oct 10, 2007 | Pioneer DEH-P2000 CD Player
Durabrand dual 7c dvd replacement screen
I have a 2nd screen I don't need it email histnoi@mail.com
Oct 07, 2007 | Durabrand Portable DVD
Error 3001
I have brand new DV600E unit for sale, send me email for more information.
Apr 30, 2007 | JVC BR-DV600E VCR
Car Audio & Video Logo
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
