Question about Maxent MX-42HPT51 42 in. Plasma TV
Tv is hooked to cable but still gets no picture or sound...only a blank blue screen
  • 1,583 Answers
Verify that the source is set to "Tuner", "Cable", "Antenna" or "TV". (I don't know which of these names Maxent uses, and the site formerly used for their downloads is now a generic search page.) Make sure the TV format is correct for your region (in the US it should be ATSC, sometimes called HDTV).
If you have a portable TV, bring it over and connect the cable to it to verify that the cable connection is good.
Check the other inputs to verify that the internal video switch is functioning properly. If you don't find a problem with any of these tests, you likely have a tuner problem. Note: do not use a tool to tighten the cable on the tuner connection. I've seen a lot of tuners broken that way, including some with the circuit board ripped apart inside. Use your fingers, and just make the nut snug enough to hold the cable in place and secure the ground connection made through the nut.
Posted on Feb 17, 2012
My 19 inch Emerson tv screen has went blue an no picture isn't showing
Sounds like a bad connection to whatever you have it connected to (cable box, dvd player, etc). Check the connection and then replace cables.
Feb 13, 2015 | Emerson LD195EM8 19 in. LCD TV
Hooked game system PS3 to tv-cannot get picture or sound
What input are you trying?
Banana Pins or HDMA Cable
Nov 28, 2013 | Televison & Video
Wd65738 blue screen
blue screen means no video signal, if the source is on hdmi ensure the cable is rca or in simple audio video jacks which u will have to connect in the dvi input of the tv reason is hdmi means high definition interface and transmits by hdcp like the data of an internet meaning its digital platform which the tv can only process thru the dvi inputs or component y,p,b
Jul 17, 2013 | Televison & Video
Wii powers up doesnt have a picture or sound tv screen.
    • With the yellow, white, and red AV cables that came with your system:
      • Did you have to use the red/green/blue inputs on your TV because it doesn't have the standard (yellow) AV inputs? If so,click here for complete information on doing this type of hook up.
      • If this is your first time hooking up the Wii console or have you moved it to another TV, please click here to review our step-by-step connection guide. Our experience shows that many times this issue can be solved by double-checking your connection and finding the correct Input Select for your TV or VCR.
    • With the blue, green, white, and red component cables (sold separately):
      • Review our step-by-step Wii Component Cable connection guide to make sure the cables are properly inserted and that your TV is set to the proper input.
    If you have verified the connection is correct, and are still receiving a blank or black and white screen when powering on your Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700
Dec 29, 2010 | Nintendo Wii Console
Sony Wega Trinitron HDTV Blue Screen with Sound
Had similar problems with HD cable on dvd. swapping with another cable solved the problem.
Aug 11, 2009 | Televison & Video
Nothig bu a blue screen shows when turned on
Blue screen of Death?
No, this is not windoze.
can you change channels?
a blue screen usually means that you don't have a signal.
Is it hooked up through dvd/vcr player?
Try a straight connection to cable or antenna.
If it remains, then it requires surgery.
Sep 30, 2008 | LG 42LC2D 42 in. LCD HDTV
Blue Screen
I just wanted to suggest some things for you to try, if you have not done them already. Try hooking up a known good signal, such as the main input cable from your cable or dish, hook it straight to your tv, and see if you can change channels, and get a picture on low band...2 thru 6, and then if not, how about any picture above channel 6, if you get picture on 2 thru 13 now, it could be whatever you have hooked in between the input cable and the tv...be sure you have the tv on the right channel for your receiver, usually 3 or 4, or if you are using another type of video input cable, make sure you have tv on the right input for that cable and that cable is good...check the in and out of your component unit, for correct cable hookup as well as your cables, in reference to using RCA video and audio left and right in and out...a lot of sets and vcr's will go to a blue screen if they lose signal to them....I hope this helps you out some.If you cannot get a picture from hooking your signal straight to your tv, it could be the tuner got a spike from a thunderstorm, or has lost the B Plus source for the tuner circuit. Be sure that it is not selected for an input signal,other than the cable or antenna mode, the onscreen text should verify this, if you can change channels with or without getting video...a picture....Good luck with it. T.
Jan 15, 2008 | JVC AV-27S33 27" TV
Blue screen, no picture
Sounds like you switch the tv from pal to ntc or around.
Dec 07, 2007 | Vizio L37 Television
Horizontal Lines and Blue Tint on my Sony KDP 57XBR2
ok,your porblem is very simple,reheat or resolder the main board your tv.
Oct 22, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Problem with brand new TV
The reason you're getting a blue screen is that you're not getting a signal. Newer TV's have this "blanking" feature to "kill" the snow in the absence of a signal. Check the connector at the end of the cable where it screws onto the set. Stargazer
Feb 04, 2007 | Sanyo DS24425 24" TV
Maxent MX-42HPT51 42 in. Plasma TV Logo
129 people viewed this question
Top Maxent Televison & Video Experts
Michael Harrier
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
