Question about Memorex Televison & Video
Sankey dvd player won't play usb
Won't play usb drive
vortash
  • 431 Answers
SOURCE: The DVD s recorded from the hard drive won t read
All dvds recorded on a diffrent player have to be finalised before they will play on a diffrent machine I think that you should find the finalise command in your menu ... hope this helps Reagrds Vortash
Posted on May 12, 2009
intower18
  • 957 Answers
SOURCE: the player won't play dvd
If that would be the case, I would strongly suggest to contact your manufacturer, because they can distinguish the issue or even replace your item if they found it defective.
Thanks.
Posted on May 13, 2011
  • 411 Answers
SOURCE: when i put in a
It's most likely dirty, though it could be failing. The lasers have an average life span of 3 years, under normal use.
Several companies make CD/DVD laser lens cleaners. You want the kind with optical quality brushes on the bottom side. You simply put it in, let is spin up and play, then take it out. It may not play the first couple times you put it in, but it will be cleaning the lens and pickups.
If that doesn't do it, I'd start looking at sales for a new player.
Posted on Jul 05, 2011
  • 118 Answers
SOURCE: The tray on player won't
It sounds like there is something inside the dvd player, that isn't supposed to be there, that is keeping the tray from retracting fully. Try unplugging the unit and gently turning it upside down and giving it a little shake. Not too hard. This might jar the item loose, you will hear it knocking around. If you do knock something loose turn the unit so the front is pointing up and let the foreign object fall to the back of the unit where it hopefully won't interfere with the operation of the mechanisms inside. If you don't hear something come loose, remove the screws on the bottom, sides and back of the unit to remove the top cover. Make sure you have unplugged the power before you do this. take a look and see if you can find something jammed in the track or the gears for the tray. If you do gently remove the item with your fingers or a pair of needle nose pliers. Once removed replace the cover and away you go. If there is nothing blocking the tray and the mechanism, you probably have a gear system to close the tray. At some point someone must have pulled fairly hard on the tray causing the gear teeth to jump, check and make sure they aren't damaged or stripped. You are going to have to them either remove one of the gears (or pull it up so it can turn without turning any other gears) push the tray back into the fully closed position and replace the gear. Once you have done this you will want to test to make sure the tray will function properly. Place the top cover back on, but don't secure it with the holding screws in case you need to open it back up again, plug the unit in and test the tray. If it works unplug it and secure all the screws for the cover and away you go. Otherwise you are going to have to play with the gears till it is back in the proper starting position. If your hearing some strange noises and its not working, then the gears are probably badly stripped. You can contact the manufacturer and see if they can sell you some spare parts or direct you to someone who can replace it. Though at this point simply replacing the unit may be less expensive.
Posted on Jul 26, 2011
tvtek
  • 1284 Answers
SOURCE: No matter what DVD I load in the player, it
The first thing to try is to clean the laser itself by using a cleaning disc. If that fails then most likely the pickup laser is no longer any good. This is usually obvious if you place an audio CD in the unit and it plays fine : )
Posted on Jul 27, 2011
Code for sankey on rca universal remote
Here is the RCA code finder:
http://goo.gl/Swc60s
Iit depends on the remote model, just select it on the drop-down list.
Jul 06, 2015 | RCA Televison & Video
Tevion Dvd player won't read burned cd's or dvd's.
Transfer your .avi movie files onto a USB stick & simply plug them into the Tevion DVD player.
Select the usb button on the remote to activate & choose which film to play from the menu that pops up.
Mar 10, 2013 | Televison & Video
Usb on bd610 lg won't work
I don't understand this term: "choose either dvd or usb menu". Do you mean instead ""choose either dvd or cd menu? I've used many usb hard drives and I've never seen such a "menu".
Feb 27, 2013 | LG BD610 BRay Disc Player
My LG DP122 will play some AVI files from a USB device but not others.
figured this out, lg dp122 uses DivX Home Theater profile, so the technical specs of the video must match that.
Those specs can be found here: http://www.divx.com/files/DivX-Profiles_Tech-Specs.pdf
Jan 23, 2013 | LG DP122 DVD Player, Multi Format...
WHY MY PORTABLE DVD WON'T PLAY
It won't play for one of two reasons:
1. There is something inside the DVD player, which keeps it from playing.
2. The DVD player's battery has run out of juice and can no longer play, meaning the player needs to be replaced.
Aug 06, 2012 | Curtis Sylvania SDVD7037 7-Inch Portable...
Music and video files from usb won't play on dvd
hi, the file format that you download in your usb drive is not compatible in the format in your dvd player. look for the file format that have been in your dvd then you can convert the video or audio in your usb to make it compatible in the dvd player. there are converter which you can download.
Jun 09, 2012 | Televison & Video
Compact Disc rewritable DVD player won't load or play
Check the data connector on the rear of the drive. If this doesn't work you may need a new drive, they are cheap and readily available.
Jan 19, 2012 | Lenovo Computers & Internet
My drive doesn't read all dvd that i inserted
There can be some reasons for this behavior:
1. If those are movie DVD's from a region that your player is not unlocked to play, it won't play it.
2. The DVD's have deep scratches.
3. There is some problem with your DVD player itself. You can get it repaired but its best to buy new.
Aug 15, 2011 | Computers & Internet
I JUST GOT A NEW DVD MOVIE TO WATCH IT WON'T PLAY IT I PUT ONE IN THAT I PLAY BEFORE IT WORKED TOOK IT BACK TO THE STORE THEY SAID THE PAYER NEEDED TO BE UP DATED,SO HOW DO YOU DO THIS?
If you follow the link below you can download the newest firmware for this Blu-ray player . You need to put this file on a USB drive , Do a reset on the Blu-Ray player and insert the USB drive into the USB port on the player it should then do the update. If it doesnt do it automatically just follow the on screen prompts
http://www.blu-ray.com/firmware/firmware.php?action=download&id=23
Jun 15, 2011 | Sharp BDHP20U Blu-Ray Player
Dvd player won't play disc
The DVD read head may need to be cleaned. Sometimes perfectly OK drives also fail to read certain discs. If the problem is persistent, i.e. the notebook won't read any discs, then clean the head (with a head cleaner) and try again. If it starts working, fine.. If not, then you may have to replace the DVD drive. If the problem is only related to playing one particular DVD, then its the DVD that is faulty.
Hope this helps.
May 25, 2011 | Toshiba Satellite P505D-S8935 Notebook
Televison & Video Logo
149 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
