Question about Bosch 24 in. SHU5305UC Built-in Dishwasher
My SHU 5305 UC has sporadically heating problems and runs forever. I left the door panel open to put gauges on the red wire (heating) and ran 4 cycles OK; the fifth times there was no heating current
Because the DW is 11-12 years old, the relay might or might not switch. I wanted to make sure that it wasn't the flow switch, for I also measured the voltage on the red wire. I know that the circuit board is ususally changed and not serviced. I am sitting with this US DW in Hungary and replacement parts are not easy (and not cheap either) I am inclined to change the relay. Did you make similar experience?
  • George Strobl May 13, 2014
    I fixed the DW by changing the heater relay. This relay was (probably) designed for european (240V) operation which runs at 5 Amps. On 120V operation however it will use 10 Amps. Because the relay is rated 10Amps max. no wonder that it quits after 10 years of service. On this DW this is the only problem I had in 13 years.
2 Suggested Answers
SOURCE: Bosch SHU 5300
Mine did that. I tried changing the timer but it didn't help. I noticed that the water level kept rising until the drain pump would be triggered by the overfill protection switch on the left side under the insulation. It turned out that the fill valve didn't close all the way and so the pan would never empty. A new fill valve (easy to install and cheap) fixed it!
Posted on Jun 19, 2008
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Oct 05, 2015 | Bosch Dishwashers
Dryer wouldn't shut off except with door open, now it won't run
More than likely the cycle timer is bad. Have it replaced and that should put you back in business. Hope this helps. Please re-post with up dates. Good luck. Thanks cj2176.
Jul 10, 2009 | Kenmore 62882 Electric Dryer
Burning plastic smell, big flash & now its dead - Bosch SHU8805UC
remove the water and, the burnt plastic that probanly melted on the dish drying heater coil
close and, lock the door turn the dishwasher back on and, reset the circuit breaker to see if the motor will run or, is damaged
Jul 01, 2009 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Need a radio wire diagram for 1989 ford mustang 5.0
Radio Connector:
Light Green / Yellow - Hot at all times (Fuse 8)
Yellow / Black - Hot in ACC or Run (Fuse 11)
Light Brown / Red - Goes to instrument panel dimming rheostat (Fuse 4)
Red - Ground
White / Purple - Hot in ACC or Run (Fuse 11)
Speaker Connector:
White / Light Green - (+) Right Instrument Panel & Door Speaker
Dark Green / Orange - (-) Right Instrument Panel & Door Speaker
Brown / Pink - (+) Right Rear Speaker
Pink / Light Brown - (-) Right Rear Speaker
Pink / Light Green - (+) Left Rear Speaker
Tan / Yellow - (-) Left Rear Speaker
Light Brown / White - (+) Left Instrument Panel & Door Speaker
Orange / Light Green - (-) Left Instrument Panel & Door Speaker
Apr 04, 2009 | Sony CDX-GT320 FM / AM / XM Radio / Sirius...
Ge dishwasher not drying
1 make sure heated dry is on.
2 run your cycle and when it says drying open the dishwasher. see if it has steam coming out.
3 give me your whole model number.
4. if heater is not turning on then you may have one of three issues.
1. Bad door switch
2. Wire off element or bad thermistat
3. No power going through the control. to the heating circuit.
Jan 07, 2009 | GE ADW1100N Built-in Dishwasher
Cycle not running correctly. sometimes won't start or if it does won't release the soap and may run without ever stopping on its own.
  • Test the timer motor
  • Test the heating element
  • Test the thermostat
  • The timer motor regulates the length of time power is routed to each component. If the timer motor does not function properly, it can result in a wide range of problems. Common symptoms include sticking in a cycle, cycle times running too long, or failure of the dishwasher to start at all.
    To service the timer motor, it is necessary to access the control panel in the door. Access varies by model; on some models you can remove just the control panel on others you must remove the interior or exterior panel of the door.
  • The heating element is used to heat the water and/or dry the dishes. If it does not function properly it can result in unsatisfactory cleansing of the dishes or the failure of a cycle to complete properly.
    First, open the door and look into the tub and locate the heating element (if it is covered, remove the lower dish rack and cover). The heating element has two terminals which extend through the bottom of the tub, note the general location where they go through.
    To access the heating element's wiring, remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel.
    Look into the lower access area and locate where the terminals come through the tub. Each terminal has a wire connected to it. Label the wires and the terminals so that they can be properly reconnected. Pull the wire off of each terminal; they are connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers. Inspect the connector and terminal for corrosion. If either is corroded they should
Aug 26, 2008 | Bosch Dishwashers
Self Clean won't start - Amana ACS3350AS Gas Kitchen Range
Our door on this oven is coming apart, so the oven door never truly closes.  When you set the self clean cycle, push the door shut until it locks... at least this has worked for me.  But I think all your problems, which are similar to mine, result from the oven door not truly closing... heat escapes, so the temp is not right and takes forever to heat up.  The heat melts the control panel, causing other problems.  In fact, our door is starting to fall open... a bit dangerous.
May 06, 2008 | Amana ACS3350AS Gas Kitchen Range
Kenmore Elite HE3t Front Loading Washer
Try holding 'end of cycle' button for 3 seconds. If not........
  • Door Lock Mechanism broken or removed from the door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
If you get the door to open try some WD40 on the door mechanism, not on door, and open/close a few times. "Plug should be off the wall" when trying this, and tinkering inside machine, caution.
Feb 05, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
My Dacor wont heat, broil or convection after self cleaning. No heat but everything else works
I also have a Dacor Model PCS130. This solution worked AND saved me from spending $50-$105 for a service technician to come out just to look at the problem. The high temperature sensor tripped when I kept the door open part way while broiling (never listen to friends who don't have the same oven as yours). Afterwards, I couldn't get the oven to go above the prebake temperature of 135°F using any of the settings (bake, broil, convection bake, etc...). I called Dacor customer service and they told me about the high temperature sensor but wouldn't say how to reset it. They suggested I call a third party technical service company and gave me their numbers. But, I'm glad I found this site... All you have to do is open the oven door and you'll see the grille/grate/steel cover plate where the door latch sticks out of. If you look inside, you can see the electronics that operate the door latch as well as the temperature sensor unit a little farther back. You can even see the RED reset button. But, it's a little too far back for you to press it without removing the cover plate. 6 screws is what holds my cover plate in place. Once that's off, you can reach in and press the RED reset button (I pressed it twice just to make sure) and you'll hear it click. Screw the cover plate back in place. Close the oven door and test it out. It took my oven about 5 minutes to heat up past 135°F so I was unsure if the problem was fixed or not during that time. But, once the oven heated up sufficiently, the temperature began climbing fairly quickly and I was able to breath a sigh of relief. It works! This is such an easy fix, I don't know why Dacor customer support doesn't just tell us how to do it ourselves instead of paying for a service tech to come out and do the same thing. Even better, maybe they should make the reset button more easily accessible (like on the control panel) if they're concerned about people getting in and messing up the other electrical connections when trying to reset the high temperature switch. Computers are far more technically advanced than your oven and THEY have reset/reboot buttons right in front.
Nov 11, 2006 | Dacor ECS127 Epicure Stainless Steel...
Bosch 24 in. SHU5305UC Built-in Dishwasher Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
