My zanussi zwd12270w starts then stops after 2 seconds , can you help
  • Chris Pouralli Feb 16, 2012
    if i hold button shows E73
    opened drain valve at bottom, everything seem ok
4 Suggested Answers
drapplian119
  • 11 Answers
SOURCE: i have a zanussi washer dryer zwd12270w and the
I would first check your line voltage to make sure its correct. Next I would try unplugging it for 10 minutes. If thats doesnt work I would then look at replacing the control board.
Posted on Jun 16, 2010
murdozzz
  • 41 Answers
SOURCE: I have a zanussi zwd12270w
it sounds like you may have a problem with the door interlock !
Has your machine displayed any error codes ?
regards
Ian
Posted on Apr 17, 2011
  • 7 Answers
SOURCE: I have a zwd12270w. Seven second after pressing
The problem is with the tumble drier heating element. If you remove the top of the machine (disconnect it from the electricity supply first!) you will find a big metal oblong "bar" that runs from the front to the rear of the machine. At the rear there are 4 white wires connected to the metal "bar". Make a note of where they go and remove them. You may need pliers to get a good grip of them. Once removed, the washing machine should work just fine but obviously the tumble drier will not. This is a well known fault and it may be worth contacting Zanussi as they MUST know about it!
Posted on Jul 26, 2011
Replace Zanussi ZWD12270W faulty dryer heating element
Just for the record, the heating element went on mine too and I'd only used it less than half a dozen times. The engineer said that it went because it hadn't been used enough (it gets moisture inside somewhere). He said if I didn't use it I would have the same problem after it had been replaced. So make sure you dry something every couple of weeks (he said at least once a month).
Nov 30, 2013 | Zanussi ZWD12270 Front Load Washer / Dryer
Zanussi zdc 67550w tumble dryer stopping after 10-30 seconds of the cycle
See if it is overloaded or the clothes are excessively wet... Take out 1/2 the clothes and try again.
Jan 12, 2013 | Zanussi Dryers
My Zanussi zwf1650w comes up with a message draining 0 0 after about 30 seconds of starting a wash cycle. The machine the stops and bleeps saying cycle ended, is there a solution to fix this?
zanussi zwf1650w washing machine. when starting any program after a few seconds machines stops and shows draining 0.0. have done diagnosis test and shows fault E91 & E48 fault codes also shows E34 code. any help much appreciated.
Nov 05, 2010 | Zanussi ZWF1650W Front Load Washer
I have a zanussi washer dryer zwd12270w and the lights just keep flashing and does nothing else
Jun 16, 2010 | Zanussi ZWD12270 Front Load Washer / Dryer
I have a Zanussi Electrolux Jetsystem Progress ZSF 6161 Dishwasher which, no matter what programme I use, stops after 2 seconds and a -10 flashes.
I have a Zanussi Jetsystem Progress ZSF 6161 Dishwasher stops after a few seconds and flashes -30 Any ideas? thanks!
Jul 28, 2009 | Zanussi Dishwashers
Jun 28, 2009 | Zanussi ZWD12270 Front Load Washer / Dryer
Zanussi ZWD14270W - Delay timer?
According to the Dixons website, the ZWD14270W (1400rpm) + ZWD16270W (1600rpm) do not come with a delay timer. However, the ZWD12270W (1200rpm) does.
Nov 19, 2007 | Washing Machines
Zanussi FLE 1015W
Any solution yet ? same problem here Zanussi IZ12
Jul 30, 2007 | Zanussi IZ12 Front Load Washer
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
