Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums Post back what you see inside so we can guide you further and it will help out other people in the future also. http://en.wikipedia.org/wiki/Capacitor_plague http://www.badcaps.net
could be a few thing , have it put on a real time scanner, not a code reader, blue streak makes a good one, have someone monitor the engine activators and sensors, also hook up a furl pressure guage to monitor
Plug your monitor into another computer, If the line persists, it is your monitor, you need a new one. If it does not, It is your Video card, you need a new one. But it is one of the other...
This is going to seem dumb
If the streaks are in the direction of the lens travel
vaccum the thing out
If there is a dust crumb on the lens, it will show as a line, streak
Can you describe in a little more detail what the symptoms are? Are the streaks thin lines or are they large thick swashes of Blue? Is yur video still visible? Sounds like it may be the blue convergence amps or the resistor tied into the amps. is there anyway you can post a picture of your screen distortion?
I had this same problem with my ViewSonic LCD monitor. I tried turning the monitor off from the button on the front, and tried changing the settings for the monitor. That didn't help. But then I unplugged it from the power source, and the streaks immediately vanished!
