Question about Samsung LN-T4042H 40 in. LCD HDTV
On/Off loop on power up on Samsung LN-4042H LCD TV
Set was resetting to Channel 3 and high volume when turned on. Now it appears to be locked into an On/Off loop where it turns on and then off ever few seconds. The screen or sound never comes on
  • stevemokay Dec 07, 2008
    We've had this tv about 18 months. We've been happy with it. Recently, though, when we turn in on in the mornings, it goes through a series of turning on and off several times before it finally stays on, about ten sequences. We haven't had the problem of it turning on/off during the day, only the first thing in the morning. Any suggestions before it gets worse?
  • ccjr_11 Jan 08, 2009
    My Samsung has the same On/Off loop on power up. The first time it did it came on after holding the button in on the set. Now it just clicks no picture no sound.
5 Suggested Answers
SOURCE: Samsung LN-T4042H 40" LCD
This may not really be a solution to your problem, but here it goes. If you are not sitting a particular distance from your tv you will experience slight pixelation. I have this tv myself and I think it looks great. Now when I am sitting up close on a station that is broadcasting in 720p(which is pretty much every HD station) It looks only pretty good...I sit back and it is fantastic. The good rule of thumb is take the number or inches your TV is in yours and my case 40, divide by 10 and then multiply by 2...and that is the number of feet you should be for optimal viewing distance. So 8 feet, you would be surprised to see how sitting this magic number away makes a difference.
Posted on Feb 12, 2008
SOURCE: Samsung LCD Flat Screen TV LN-S2651D - Volume Problem
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
Posted on Mar 14, 2009
budmrtn
  • 11361 Answers
SOURCE: Samsung LN-T-4042H the picture is flashing. How
Look for screen setup for AUTO ASPECT in the setup menu, turn it OFF.
Posted on Nov 07, 2009
vinnyq
  • 157 Answers
SOURCE: When I try to turn on my Samsung LN-T4042H LCD
There is a problem with the power supply in your TV. The regulator switch is causing teh clicking sound you hear. In order to fix it, you will need to replace the power supply. This is done by taking off the back cover of the TV, locating the power supply which is usually a yellow board that will have many high voltage capicators on it and replacing it with a new one.
Posted on Nov 11, 2009
Volume bar stands at 200 every time i start my Samsung LCD
set the volume down extremely low power the tv down by plugging out and put on again should be then at set volume,the tv's now days have memory so it should start up at volume preset
Dec 21, 2013 | Samsung LN-S2651D 26 in. LCD Television
Forgot my password I cant watch any channels
The easiest way is to reset the TV. There are 3 possible resets for this TV. press and hold Action and Power on the TV until self check appears-- then unplug the TV wait for 30 sec. then plug back in. The reset should take care of any channel lock/ game guard settings
Also Volume down on unit and sleep on remote. Same process wait for self check then unplug for 30 sec. plug back in and turn on.
Last Volume down on the unit and RH-Split on the remote-- same process
hope this will be helpfull. Please rates me . Goodluck...................
Feb 03, 2011 | Panasonic TCL42U25 42 in HD-Ready LCD TV
Captions are locked on and guide cannot be accessed to turn them off. Also, volume is stuck at 0. When you adjust volume it goes immediately back to 0.
You might have the CHILD LOCK feature on.
Use the remote to access the MENU then SET UP then CHILD LOCK.
Set CHILD LOCK to OFF.
If this doesn't work, try holding down the MENU BUTTON on the front of the tv for 10 seconds until you hear a beep. This works for some models.
Or if all else fails, leave the power cord unplugged overnight and this shoud reset the internal memory back to default settings.
I tried to download the user manual at the following link but the site was temporarily down
http://www.samsung.com/ca/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=101&prd_mdl_cd=LNT4671FX%2FXAA&prd_mdl_name=LN-T4671F&srchword=LN-T4671F
Gppd luck and let us know how you make out.
Jan 22, 2011 | Samsung LN-T4671F 46 in. LCD Television
Nov 07, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
When I try to turn on my Samsung LN-T4042H LCD HDTV it is now constantly clicking in a continuous loop and will not immediately turn on. It started out small- a few clicks yesterday morning. Today it...
Nov 06, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
32 Inch Brand new Samsung 32" LCD showing subtitles / no volume??
I had a similar problem, checked all of the TV's control settings only to find out that my cable box had an independent "mute" function that automatically turned on the closed captions when activated. Once I found that and turned it off, all was fine.
Mar 18, 2009 | Samsung LN-R237W 23 in. LCD Television
Aug 24, 2008 | Samsung LN-S2651D 26 in. LCD Television
Samsung lcd tv
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 07, 2008 | Samsung LN-S2651D 26 in. LCD Television
Samsung lns4041dx/xaa
Same problem with my set. The volume was either fully up, or fully down (usually down), and other controls didn't work- like I couldn't access the menus and could not adjust the width of the screen/aspect ratio.
Jun 03, 2008 | Samsung LN-S4041D 40 in. LCD HDTV
Samsung LN-T4042H 40 in. LCD HDTV Logo
475 people viewed this question
Henry  Thomas
Henry Thomas
