Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
When I plugin the two relais on the power supply will swich on and off permanently ! Does anybody have an idea which board can cause this problem
  • Carlos Santana Feb 23, 2012
    Dear Francoise !
    So far I found out now, is the 12V instabile; it comes up, the relais swiches on, and then the 12V falls down, so the relais swiches off ... and so on.
    The transformer secondary diodes are OK, so it must be the regulator. Unfortunately do I not know how to get it: it is the Allegro STR-W6765.
    It contains the controller and Mosfet. Digikey does not have it; do you know a distributor in Europe ?
    Thanks a lot, regards !
  • francoise cleofas
    francoise cleofas Feb 24, 2012
    hi sir sorry for the delayed response i'm not so familiar with some parts distributor in europe, have you been tried to inquire at shopjimmy.com although usually they have available set or module but you can tried.
    President:
  • Toshiba Master
  • 1,779 Answers
It's hard to pull teeth over the net, however, I would suspect the power supply panel first. You can disconnect the inverter module and see if you get sound back. If its a high end set then the power supply will detect what you have done and not let the set start up completely but you will notice a change in the relay cycle. That will tell you that there's a short on the inverter board.
Posted on Feb 17, 2012
Testimonial: "Thanks for your help dear Jim ! I'll try this weekend and let you know ! Karl"
Tv swich off completley
The power supply has a fuse on it. If it's blown then you'll have to isolate the cause. TV Parts Universal TV Stands DLP Chips ShopJimmy has replacement parts and a board repair service.
Feb 27, 2016 | LG Televison & Video
Volkswagen golf 1998 the main relay become hot then stop the car no power to injector no spark
clean the conctact relais from your pins, and relais contacst.use the contacts cleaner. remember to disconnect the negative from battery for to avoid shock.i will be a good idea to replace the relais, the coil can be overheating.
God bless you
Jul 23, 2013 | Cars & Trucks
I got Gigabyte GA-81915P PRO Motherboard. Swich on the power there was a bang - power supply caps were blown. Got new power supply when I switch it on it immediately switches off - nothing on the monitor....
Have you tried checking if you motherboard had been damaged when your power supply exploded?
Cause theres a big chance that your motherboard will be damaged, cause explosion of power supply will trigger excessive voltage to your motherboard.
So if your motherboard is damaged,there will be no chance for your computer to turn on even if you change your Video and Memory Card.
Jul 04, 2011 | Gigabyte GA-8I945P-G Motherboard
I HAVE A PANASONIC PLASMA WONT COME ON, ONLY SOLID RED, I REPLACE THE POWER SUPPLY NO LUCK MODEL:TH-42PD25 OCT,2004 DOES ANYBODY KNOWS WHATS WRONG WITH IT
Hi
If you have changed your power supply then there is only one thing this can really be down to and i would say that is the main AV board as this sends a signal back to the power supply to tell it to turn on.
You AV board is the one with the scarts etc... This board also causes other problems of your TV powering up but no picture and no functions will work.
Change this board and im sure your problem will be solved.
There are no other boards in this set that control the start up side,so if you have changed the poiwer supply then it will be this board that needs replacing.
Hope this helps
Feb 02, 2011 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
My Pioneer DVR-520H DVD Player works fine but sometimes when it is powered off the power just goes completely. When this happens I plug it into a different socket or just pull out the power cable from the...
It seems problem with power supply board in Pioneer DVR-520H, possible causes for that symptoms are few dried up/ leaky capacitors, cold/ dry solder joints on circuit board or chip resistors would be devalued.
Local repair shop will help you to replace bad capacitors, chip resistors in power supply board to solve this issue if you are not familiar with soldering work in circuit board.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Jan 11, 2011 | Televison & Video
Wont turn on. when i try, it just 'clicks' non-stop
Power supply board,that the board where the power a/c cord plugin it.The power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 07, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Flasher unit on a 1992 jetta
pull them out one by one and read text. flasher will show something like 4x21w you can also swich on alarmlights and feel ticking problem is very oft the steeringswitch and not the relais. alarmblinks is diff. switch, but same relais
Feb 10, 2010 | 1992 Volkswagen Jetta
SAMSUNG PS42Q96HD PLASMA ,16 MONTHS OLD, RED LIGHT COMES ON WHEN STARTED UP BY PUSHING IN THE ON BUTTON, AND BEFORE A NANO SECOND IT THEN TURNS ITSELF OFF, ANY IDEAS PLEASE ANYBODY ????
Could be power board. Check for swollen capacitors . If ok next check buffer boards for burnt ic. With set unplugged unplug power board from sustain boards. Plug back in and see if it turns on. Unplug again and disconnect buffer boards from sus board plug power supply back into sus to see if it powers on. If it does then buffer boards bad. Isolate upper and lower to Determine which one is bad. Just always remember to disconnect power board from sus boards when disconnecting panel to buffers. Power supply stores a lot of energy and will burn these connectors while reconnecting them.
Nov 22, 2009 | Samsung LN-S4051D 40 in. LCD Television
L26W761 no power
PUSH GENTLY ON THE SCREEN WHILE THE SET IS ON. IS THERE A SLIGHT DISCOLORATION. IF SO THE PANEL IS ON AND YOU PROBABLY HAVE A BAD MAIN BOARD. IF NOT THE PANEL, INVERTER BOARD OR POWER SUPPLY HAVE A PROBLEM.
Mar 13, 2009 | Envision L32W761 32 in. LCD TV
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
196 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
