Question about Grilling
Is adding a side burner to a Solaire 27XL grill possible, since they don't make one?
27XL cart mount w/ rotisserie, no back burner
  • dd12354 Feb 18, 2012
    After paying $2k buying a new one is not an option. Adding a T, grafting in an other brand may be possible ? I see many other stand alone sideburners on Google.
  • Paul Carew Feb 18, 2012
    There you go then you have your answer , Ask at Calgary bbq center .
  • 2,597 Answers
No not really don't know of anyone who just sells side burners plus you would have to be a gas fitter to do it , best to buy a new one with a sids burner ,
Posted on Feb 18, 2012
4 Suggested Answers
SOURCE: Rotisserie won't stay lit
With our Kenmore, you need to increase the gas flow another 1/4 turn once it's lit.
Posted on Jun 05, 2008
SOURCE: Jenn Air 720-0061-LP Gas Grill Rotisserie Problem
Hi all ,
I just bought a jenn air 720-0336 gas grill from bj's . the rear rotisserie burner would stop working after a few minutes .
hear is the deal , the rear inferred burner gets to HOT . they did not put any insulation between the ceramic blocks and the metal bezel.My fix was to remove the unit , drill out the 8 rivets holding the bezel on , carfully remove the bezel and install a fire proof gasket , i was abile to find the proper stuff at my local coal / wood stove retailer.it comes in a white sheet about 1/8 inch thick .
use steel rivets to reassemble . good luck . this took a week of trial and error to figure out .
Posted on Mar 30, 2010
  • 1015 Answers
SOURCE: rotisserie burner won't light
It could be a dirty or inop spark electrode. Also could be weak batteries in the spark igniter.
Before you start you should make sure that the ignition system has fresh batteries. The batteries are usually located within the igniter button but not always. Some BBQs will have a battery pack located somewhere on the BBQ and others you can remove the igniter button by turning it left to reveal the battery.
First verify that the rotisserie burner can be lit manually. Take a BBQ lighter or long stick match and then put the flame right at the base of the burner where the electrode is and then slowly turn on the burner valve. It should light within four seconds. If it does not then shut the burner off and check for any restrictions in the gas line for the burner.
If it does light with a match then the spark electrode could be dirty, out of position or simply the wire for the ignition system is loose. Press the igniter button and watch the electrode for a good bright spark at the burner. If you do not see any spark you can verify that the igniter wire has not come loose and also gently adjust the position of the electrode end a little bit closer to the burner using a pair of needle nose pliers(It should not be touching the burner). It does not need to touch the burner but have a really small gap.You can use a small wire brush to gently clean the electrode of any debris that might be causing a weak or no spark
If you are unable to remedy the non-spark issue all is not lost. You can still use the manual lighting procedure I described to light the burner. And remember to be careful when trying these procedures. I do not want you to get injured from delayed gas ignition. Be careful and have a safe holiday.
Posted on Jul 04, 2010
Jenn- Air rotisserie burner wont lite. Doesn't
Try removing the cover on the back of the grill hood and finding the orifice for the rear burner. Check to see if the orifice is plugged.
Jul 31, 2011 | Jenn-Air Grilling
My Blue Ember rotisserie only flames up and does not glow red. I have cleaned the ceramic tiles. what else can I do? Everett From Seekonk MA
Everett, it's not the ceramic plaques that are causing the problem, it's the burner that heats the plaques that's failed. Replacing the entire burner assembly is your only option.
It's interesting that you are still using that model Fiesta Gas Grill. It was recalled about 3 years ago.
http://bbq.about.com/b/2009/07/21/recall-alert-fiesta-blue-ember-gas-grill-2.htm but not for the problem you're having. If your model number is not mentioned in the link above. Don't worry about it.
You may be able to find a replacement burner from Fiesta or try Appliance Factory Parts
http://www.appliancefactoryparts.com/ Be sure to have the correct Model Number of your grill when looking for parts.
Hope this helped you. Please let me know and Happy Grilling!!
Jul 15, 2011 | Fiesta Blue Ember Gas Grill
Gets soaked after even light rain. The cart doors, which have no drain holes, but have side trays, fill with water, and the grill cart inside gets wet. The igniter on the rotisserie burner would not...
Grills, whether they are stainless steel or not, are not designed to keep out the weather, bird droppings, pollen, etc. Using the cover will help maintain the look and integrity of the grill, as well as the warranty. Warranties don't cover damage due to neglect. Impressing the neighbors with a nice looking stainless steel grill is one thing. Impressing them with the way if cooks is even better. Especially, if it works as it should each time.
Happy Grilling!!
Jun 30, 2011 | Alfresco ALX2-42N Stainless Steel Gas...
I just bought the Brinkman, and I am trying to figure out how to use the Rosterria. Can you help me?
Since a Rotisserie is an optional item for your model grill. I assume you have purchased one that is approved to be used on your model Brinkmann Grill Smoker. If not, I recommend that you Do Not use it. If it was approved, read and follow the directions that came with it regarding installation, setup and preparing to use the rotisserie.
The Rotisserie can only be used when you are not grilling anything else on the grill. Remove the grill grates directly in front of the rear infrared Rotisserie Burner. If you Don't, they will be in the way. In their place, you are going to use an aluminum pan (like a pie pan), as a drip pan for whatever you're cooking on the Rotisserie.Place that on top of the burner's flame tamers. Make sure the rotisserie motor is in place and you have electric power to it. Test the rotisserie spit, by inserting it into the motor's spit holder. If you have a Counter Balance, attach that near handle on the spit shaft just below the handle. If your rotisserie is missing the counter balance, you can not use the rotisserie.
Remove the rotisserie spit and place whatever you're planning to cook on it, following the directions that came with rotisserie kit. Make sure the spit forks are tightly embedded in the meat, whole chicken, etc. If a whole chicken, tie the legs together like a Thanksgiving Turkey around the spit..
Light the Rotisserie Burner and close the hood of the grill. Allow the temperature to reach a minimum of 250 degrees F, before opening the hood and installing the food loaded rotisserie spit.
Be careful, as the interior of the grill will be hot. Install the spit as you did earlier. Make sure it fits into both sides of the grill's hood correctly.
Turn the Rotisserie Motor ON and watch as the food turns. If it turns and then sort of bumps, when the spit turns around, adjust the counter balance to stop this. It should turn smoothly. Once all tha is completed, close the hood and allow the food to cook for whatever time, you would cook it in a kitchen oven. Rotisserie cooking is like smoking food. It's a low (temp) and slow (time) process. But, the flavor rewards are GREAT. Only check the food occasionally. The more you open the hood to peek, the longer it will take to cook. Each time you peek, add 10 minutes to the cooking time.
All of this, was sort of a thumbnail sketch of rotissering food. Search the web for recipes and techniques. You'll be amazed at what's out there.
Jun 22, 2011 | Brinkmann 5 Burner with Smoker 8101750S
I have a stainless steel Ducane BBQ with five burners plus side burner and a rottisserie burner , which does not work. It is approx 5 years old and I have never used the rottisserie till last week. I have...
Since you've never used it. It may simply be a case that the infrared rotisserie burner is dirty and clogged with grease from cooking on the main burners. In addition, the Thermocouple and the igniter for that burner may also have a grease build up. In which case it won't allow the burner to light.
The electronic igniter that lights the main burners, also ignites the the rotisserie burner. Are you geting the click noise on the main burner igniters? If not, the battery in the igniter button needs to be replaced. Be sure to take note of the way the old battery is facing, when you unscrew the igniter cap. Because, that's the way the new battery should face.
Also, try match lighting the rotisserie burner. To do this, turn the Rotisserie Burner's Control Knob to the ON position and push it in, as you touch the lit match to the burner. If the burner lights continue to hold the burner knob in for a couple of minutes. This allows the Thermocouple and the ceramic plaques to heat up completely. Then slowly release the burner knob and the burner should remain lit.
If it doesn't stay lit, clean the burner and the Thermocouple ,in the manner that is described in your Owner's Manual.
Hope this helps you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Jun 15, 2011 | Ducane 30400040 Stainless Steel Grill
I have a stainless steel grill. The Rotisserie will light, but the burners will not. I purchased the grill in 2005.I have taken the grill apart and the tubes are clear. There is NO spark going to them. I...
The ignitor wire to the burners my have come loose or has lost full contact. Trace the wiring from the Ignitor Button to the main burners. Note if it loose or has come completely off. Also, check inside the grill at each burner to see if the ingnitors are covered with grease. If that's the case, clean them with alcohol and either a rag or a cotton ball. If all this fails to solve your problem, change the battery in the Ignitor Button with a brand new Alkaline type battery.
Hope this helps solve your problem. Happy Grilling!
Feb 12, 2011 | Ducane 30400040 Stainless Steel Grill
Infrared rotisserie burner mounted on back will not stay lit.
I have the same problem - What I determined is first the gas safety valve button would not push in. I researched the problem and found that if you ever overheat your grill by "cleaning it" by placing foil over the grill, then the intense heat likely overheated the valve. ( in my case) which I replaced. After replacing the valve, my rotisserie would not stay on. I found that the thermocouple was defective. the TC is a piece of copper that attaches to the back of the safety valve and the other end has a probe that is up at the rotisserie burner. When you light the rotisserie, and press in the valve button, it should stay lite after about 10 seconds.
When the probe heats up, it sends and electrical signal to the electro magnet which operates and keeps the valve open. I bought my thermocouple from PEX supply for $9.50. DCS wants $56.00 for the same part which is manufactured by Robertshaw. Part number you want is 1980-072 thermocouple .
Dec 07, 2010 | DCS BGA48-BQAR (NG) All-in-One Grill /...
CalFlame 4-burner convection BBQ rear rotisserie burner does not work. Converted to natural gas. There is a spark but gas will not ignite. Held match to burner and it would light but would go out when...
Check the air shutter adjustment on the rotisserie burner. It may be starving for air. Also make sure the burner is properly positioned over the orifice. When it was converted, it may not have been put back into place correctly. Also, it's possible the orifice may have been re-drilled out at the wrong size for natural gas. If you know the rotisserie burner BTU rating, I can look up the correct orifice hole size to check if it's right. Douglas
Sep 12, 2010 | Cal Flame 5-Burner
Only the left side of the grill heats up. How do we get the right side to work again?
Make sure the grill is clean and the burner are not clog you can use oven cleaner to clean it
Mar 30, 2010 | Ducane 455 inch 2 - 3 Burner with...
When my grill heats up...the propane seems to blow out with a loud pop (explosion) what could be causing this.... the grill flames up.....so it is not useable....used to happen with one burner or two now...
you probably have debris in the burner remove the burner clean holes and dump the burner out if this doesnt work i can help more if i know what kind of grill it is
Aug 09, 2009 | Solaire Grilling
Grilling Logo
70 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
